Hi, i'm new to the Arduino programming, I've been trying to make this vu-meter with peak hold and make the top led to fall down slowly, the code works but the top led falls too fast. Can someone help me please?. Thanks!
Here is the code:
int value=0;
int audioValue; // Analog value read from audio channel
int maxAudioValue = 0; // Maximum analog value read from audio channel
int ledLevel;
const int ledCount = 10;
const int numReadings = 20;
int readings[numReadings];
int peak =0;
boolean showPeak = false;
int peakValue = 0;
long lastPeak = 0;
void setup (){
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
void loop (){
int ledPins[] = {2,3,4,5,6,7,8,9,10,11};
for (int i = 0; i < ledCount; i++)
pinMode(ledPins[i], OUTPUT);
value = analogRead(A1);
if (value > maxAudioValue)
maxAudioValue = value;
ledLevel = map(value, 0, 1023, 0, 50)-1;
if (ledLevel > ledCount) {
ledLevel = ledCount;
if (millis() > (lastPeak + 2000))
peakValue = peakValue -1;
if (ledLevel > peakValue)
peakValue = ledLevel;
lastPeak = millis();
for (int i=0; i<10; i++) {
if (peakValue > ledLevel) {
digitalWrite(ledPins[i], (i <= ledLevel || (!showPeak && i == peakValue-1)));
delay(1);
else{
digitalWrite(ledPins[i], LOW);
delay(5);
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
It would be a whole lot simpler if you used an envelope follower, then you can control the decay with the value of what is shown as 100K.
Thanks everyone.
I got it to work with the Adafruit's microphone and code from:
Tech-Zen.tv - For those interested here is the code.
An a video Led VU-METER with Peak hold Arduino Uno and mic. - YouTube
Update: New Video with more effects. Arduino VU-Meter 16 Leds with 8 modes and Microphone. - YouTube
Enjoy it!
//Arduino UNO vu-meter with Adafruit's Microphone and code.
//Also code from http://tech-zen.tv/index.php?option=com_content&view=article&id=265:vu-meter-episode-23&catid=20&Itemid=204
//Modified by Wilson Carvajal https://www.youtube.com/watch?v=C5gmt7x1QWI
#define DC_OFFSET 6 // DC offset in mic signal - if unsure, leave 0
#define NOISE 10 // Noise/hum/interference in mic signal
#define SAMPLES 60 // Length of buffer for dynamic level adjustment
#define TOP 10 // Allow dot to go slightly off scale
int
vol[SAMPLES], // Collection of prior volume samples
lvl = 10, // Current "dampened" audio level
minLvlAvg = 0, // For dynamic adjustment of graph low & high
maxLvlAvg = 512;
int value=0;
int ledLevel;
int peakValue = 0;
long lastPeak = 0;
void setup (){
analogReference(EXTERNAL);
void loop (){
uint8_t i;
uint16_t minLvl, maxLvl;
int n, height;
n = analogRead(A0); // Raw reading from mic
n = abs(n - 512 - DC_OFFSET); // Center on zero
n = (n <= NOISE) ? 0 : (n - NOISE); // Remove noise/hum
lvl = ((lvl * 7) + n) >> 3; // "Dampened" reading (else looks twitchy)
// Calculate bar height based on dynamic min/max levels (fixed point):
height = TOP * (lvl - minLvlAvg) / (long)(maxLvlAvg - minLvlAvg);
//value = analogRead(A1);
if (n > maxAudioValue)
maxAudioValue = n;
ledLevel = map(n, 0, 1023, 0, 500)-1;
if (millis() > (lastPeak + 1000))
delayMicroseconds(4150);
