I’m trying to read the info from the P1 port of a Landys&Gyr E360 smart meter. I want to use the power injection output to control some household appliances.
So far, I have tried several codes using both softSerial and altSoftSerial.
Nothing seems to work: for some reason softSerial.available() remains zero, and softSerial.read() gives -1 (which is consistent with the available() remaining low.
The fact that none of the codes seems to works seems to point to my hardware.
I have the RX signal of the RJ11 connected to a pull-up resistor, and then I’m inverting it using a CD4069. The data request pin is also high, and according to the grid operator’ website, my port is opened.
Worse still: it has worked for some time with an UNO, but that gives different problems having just one serial port. now I’m using a mega, and no code seems to do anything. all help appreciated!
The SUART works well at 9600 and NOT at 115200. So, you use Serial1 or Serial2 of MEGA at 115200 Bd to communicate with your Smart Meter.
You can first check the functionality of Serial2 Port of MEGA by a loop back connection.
1. Short TX2 and RX2 of MEGA. 2. Upload the following sketch (untested) and check that whatever you enter from keyboard appears on the outputbox of Serial Monitor.
Serial2.begin(115200); //charcater length 8-bit, no parity, 1-stopBit = default
byte y = Serial.available();
if (y != 0)
char ch1 = Serial.read();
Serial2.write(ch1);
byte z = Serial2.available();
if (z != 0)
char ch2 = Serial2.read();
Serial.print(ch2);
I'm about to have something like this meter fitted when the RTS dual rate system has the plug pulled on it.
Is the P1 port an RJ45 type? From what I've read so far, is that the port has to be activated by the supplier. It would certainly be useful for getting usage and time of day data.
I don't have a meter. I wrote code for a friend and it uses 7E1.
Maybe he's using other meters but I have not had complaints that it did not work. Hence my 7E1.
I did check the DSMR specs (both V4 and V5) and they indeed specify 8N1 so your were correct. I could not find the 115200/8N1 in the link that you provided.
your electricity supplier may provide API’s to get the data you want direct from the web ( eg look at Octopus Energy site )
Your electricity meter may have a led on it that flasher ( eg once per 0.01 KWh) , that could be used .
You could use a clamp in ammeter to measure load
These all give you simpler alternatives that do not intrude into the meter ( your supplier may object to you using the coms for fear of hacking - you need to ask if it’s not your meter)
