Hi !
I'm working on a project that involve the monitoring of a PV installation using a GSM module. I choose for simplicity to use ThingSpeak as a solution of IOT to see all of my data. Also, I wanted throught a SMS of the user to receive several informations in respond of this one.
I'm also using a protothread library because i find that it simplify my code.
I'm quite new to arduino less than a years for informations same as AT command that i'm using in the code.
**How i want to my code to work ? **
I want that it check permanently if he received a new SMS of any cell phone number. If it received one, and the text is "STATUS" then it respond to it with information (the code above below just send a text). Then every 20 sec, the code will send a data to thingspeak (here the number 400 is sent). And then it go back to sleep waiting for the 20 sec or for a new SMS from users.
I'm aware of a problem that can occure, that if a user send a SMS while data are sending to Thingspeak then nothing will be sent to the users. But for now using a timer big enought to reduce the chance of that scenario is the easier way.
How it work for now :
The GSM module is starting good, i can send a first SMS to receive my information before the 20 sec and the sending of data. Then I can't ask for information throught SMS and it keep sending dat every 20 sec as it should. But I feel like it can't get trought m "if(gsm.available()>0 but i dont know why.
So I as hoping with my post ton find an awnser or maybe a track of a solution.
Parts that I'm using :
-Arduino MEGA 2560,
-GSM Module SIM900.
#include <pt.h>
#include <SoftwareSerial.h>
SoftwareSerial gsm(10,11);
static struct pt pt1, pt2;
String textMessage;
String CellNumtemp;
String CellNum;
PT_INIT(&pt1);
PT_INIT(&pt2);
gsm.begin(9600);
delay(5000);
Serial.println("GPRS ready...\r\n");
gsm.println("AT+CMGF=1\r"); // use full functionality (calls, sms, gprs) - see app note
ShowSerialData();
delay(100);
gsm.println("AT+CLIP=1\r"); // enable presentation number
ShowSerialData();
delay(100);
gsm.println("AT+CSCS=\"GSM\"\r"); // configure sms as standard text messages
ShowSerialData();
delay(100);
gsm.println("AT+CNMI=1,2,0,0,0\r"); // alert our GSM shield and now whenever it will receive message
ShowSerialData();
delay(100);
void send_data()
gsm.println("AT");
gsm.println("AT+CPIN?");
gsm.println("AT+CREG?");
gsm.println("AT+CGATT?");
gsm.println("AT+CIPSHUT");
gsm.println("AT+CIPSTATUS");
delay(2000);
gsm.println("AT+CIPMUX=0");
delay(2000);
gsm.println("AT+CSTT=\"free\"");//start task and setting the APN,
gsm.println("AT+CIICR");//bring up wireless connection
delay(3000);
gsm.println("AT+CIFSR");//get local IP adress
delay(2000);
gsm.println("AT+CIPSPRT=0");
delay(3000);
gsm.println("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"");//start up the connection
delay(6000);
gsm.println("AT+CIPSEND");//begin send data to remote server
delay(4000);
String str="GET https://api.thingspeak.com/update?api_key=KBXJB73STRDHZJVL&field1=400"; //+ String(U) +"&field2="+String(I);
gsm.println(str);//begin send data to remote server
delay(4000);
gsm.println((char)26);//sending
delay(5000);//waitting for reply, important! the time is base on the condition of internet
gsm.println("AT+CIPSHUT");//close the connection
delay(100);
ShowSerialData();
ShowSerialData();
ShowSerialData();
gsm.println("AT+CNMI=2,2,0,0,0\r"); // alert our GSM shield and now whenever it will receive message
ShowSerialData();
delay(5000);
static int protothread1(struct pt *pt)
PT_BEGIN(pt);
if(gsm.available()>0)
textMessage = gsm.readString();
Serial.println(textMessage);
CellNumtemp = textMessage.substring(textMessage.indexOf("+33")); //locate the cell number
CellNum = CellNumtemp.substring(0,12); //stock upcoming cell number in CellNum
if (textMessage.indexOf("STATUS")>=0)
gsm.print("AT+CMGS=\"");
gsm.print(CellNum);
gsm.print("\"\r");
ShowSerialData();
gsm.println("Test Protothread SMS+ThingSpeak");
gsm.print((char)26);
ShowSerialData();
gsm.println("AT+CMGD=1,4"); //delete all sms read/undread in SIM
ShowSerialData();
delay(100);
PT_END(pt);
void ShowSerialData()
while(gsm.available()!=0)
Serial.write(gsm.read());
static int protothread2(struct pt *pt, int interval)
static unsigned long timestamp = 0;
PT_BEGIN(pt);
while(1)
PT_WAIT_UNTIL(pt, millis() - timestamp > interval );
timestamp = millis();
send_data();
PT_END(pt);
protothread1(&pt1);
protothread2(&pt2,20000);
All the part are working fine were not put together, but trying to receive an SMS while sending data to a website make my life a nightmare ahah.
Thanks for the reading, if I forgot to mention something feel free to ask.
Thanks you in advance,
NawaeK.
