I would like to stick a Nano sense on the side of a small crane arm and be able to track it's position (incline and rotation only, no extension) and report the values over BT back to another module that could output the values on a display.
I haven't found any projects online exactly like this, but does anyone know of any sketches or projects where I could get started? Preferably something similar where someone is tracking a robotic arm / crane arm / some articulated arm thing with the accelerometers and gyro sensors? I'm having a hard time finding anything!
Looks something like that. I don't know the exact specs on the jib crane but basically I am looking to see if is in inclined or rotated... so I was thinking of putting a sense on the side of the arm and use the IMU to track the incline and rotation if possible...
What's "Nano Sense"? If you mean a sensor, I'd think that rotary encoders are what you want to use. An IMU can be used for inclination but not for rotation.
DrDiettrich:
Paul_KD7HB:
I saw "angular rate" and thought perhaps it could be used to detect rotation
That does detect rotation and nothing else. No beginning position or ending position. Only how fast the angle is changing.
Paul
Hmm.. so assuming I knew the start position and tracked the rate of change over time, I could potentially do some math to figure out the position if my recollection of equations of motion isn't too rusty.. but there would probably be a large amount of error?
The IMU detects speed of rotation, that must be integrated to give relative rotation. Even a small offset of the speed channel will fake permanent rotation. Inclination instead can be calculated from the gravity impact on the various axes, resulting in a stable absolute inclination angle.
The same considerations apply to each IMU, angle measurement by gyroscope is unreliable. Magnetometers are very susceptible to iron and magnetic fields nearby. Better use a rotary encoder for rotation.
