#include <AT24Cxx.h>
#define i2c_address 0x50
/** the current address in the EEPROM (i.e. which byte we're going to write to next) **/
int address = 0;
AT24Cxx eep(i2c_address, 32); // Initialize using AT24CXX(i2c_address, size of EEPROM in KB).
// initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// Check for incoming data
if (Serial.available() > 0) {
// Read binary data from the serial port and write to EEPROM
while (Serial.available()) {
int val = Serial.read();
Serial.println(val);
// Update the particular EEPROM cell
eep.update(address, val);
// Read the value back from EEPROM for verification
int readVal = eep.read(address);
// Check if the read value matches what was written
if (readVal == val) {
Serial.println("Write to EEPROM successful.");
Serial.println("Write to EEPROM failed.");
// You can add additional error handling here
// Advance to the next address, when at the end restart at the beginning
address = (address + 1) % eep.length();
delay(100); // Delay to prevent flooding the serial port
Serial.println("Write operation complete.");
The deviceAddress/SlaveAddress of my 24C32 is: 0x57 (1010111). I have tested the following sketch on 24C32 EEPROM located on the DS3231 RTC Module and it is working fine. (Arduino UNO)
The above is a possible device address for 24C32 EEPROM deendong on the logic values of the address selection bits (A2-A0). Change the address to 0x57 and rerun your sketch. It should work. (Arduino UNO)
I have uploaded your sketch and is working. This is the output.
49
50
51
52
Thanks for the answers, but I tried running an I2C scanner, but it's not picking up anything. I tried running your script, I tried running mine with 0x57 and it still fails .
I changed the pins to digital 2 and 3, then to upper SDA and SCL, still didn't work.
Are you using a stand-alone 24C32? If yes, consult data sheets and set an address for the device by the HIGH/LOW logic of the A2-A0 address lines (Fig-1).
No word about this in the datasheet, it is only mentioned that the input on those pins select the I2C address. I strongly suspect those lines must be tied to either Vcc or GND, and can not be left floating. If in doubt: never let an input float...
