TTL UART CP2102 Converter [SOLVED]
I know there are a bizilion USB to TTL converters out there. I bought some of these to program some Pro Mini's (328 5v 16 MHz).
I haven't had any luck programming with these on any type of Arduino (tried an Uno). I keep getting "avrdude: stk500_recv(): programmer is not responding" error. I made sure to select the right board type and the programmer is showing up as a serial port.
I've been searching the forums for anyone that has used the type of converter I've bought but I haven't found any topics.
I'm using Ubuntu 12.04. I get blinking lights on the programmer. I know the Arduinos I have are good because I can program them with a FTDI programmer I got from Sparkfun.
Current Setup (I've tried switching tx/rx pins) SERIAL Arduino RST DTR TXD RXI RXD TXO GND GND 5V VCC
Anyone used these before? Anything special you had to do to get these programming?
Thanks for any help!
I dont think RST on these is Arduino RST, it's a reset for the ttl converter, I read that on the forum somewhere, to program my arduino i press compile and as soon as the sketch size apears in the IDE i press reset on arduino and the sketch loads
I have tried manual reset as P18F4550 describe. Another possibility is to connect a 0.1uf cap from DTR to reset on the Arduino
Ok I see what you mean, if I hold down the reset on the Arduino and click upload and then release the reset button it programs fine. Adding a capacitor between DTR and RST seems to do the trick!
Thanks for the help!
Pin 9, the RST pin on the cp2102 is the reset input to the chip. This is more than likely what is is hooked to the header pin labeled RST. To be sure you could verify it against the datasheet. https://www.silabs.com/Support%20Documents/TechnicalDocs/cp2102.pdf See if the RST header pin is wired to pin 9 (RST) of the chip. See page 7 of the chip spec to see the pinouts for the chip.
It is unfortunate that the designers of so many of these cp2102 boards have done this as there is no real need to put this input signal on the header. Perhaps they were dyslexic and thought they were hooking up the RTS signal which would have been much better or perhaps they simply don't understand what this signal is used for.
Other cp2102 boards like this: http://www.ebay.com/itm/USB-2-0-to-UART-TTL-6PIN-Module-Serial-Converter-CP2102-NEW-/180925940394?pt=US_Floppy_Zip_Jaz_Drives&hash=item2a2006c2aa provide breakout for the control lines and you can re-wire things to use RTS or DTR. I have several of these cp2102 boards and they will work with auto-reset if you re-wire it to use DTR or RTS. (I recommend using RTS as it offers some benefits over DTR).
For your board, if the header pin is the cp2102 RST input signal (which it probably is) I'd recommend not wiring it up to anything as auto-reset to the AVR will never work and there is no need to reset the cp2102, including when the arduino is reset.
--- bill
Just one followup. If you are really ambitious, you could get auto-rest to work with this board. You have cut the trace from the cp2102 to the RST header pin and then solder a tiny wire from the RST header pin to pin 24 (RTS) or pin 28 (DTR) on the cp2102. Then if you have a cap between this "RST" header pin and the RESET pin on the AVR auto reset will work. The pro mini should already have the cap between the pin it labels as "DTR" pin and the arduino RESET pin.
--- bill
Just got caught on that one myself, after buying a module along with a “Dupont” cable with not one, but two faulty crimps, so having to follow an extensive process to get it working properly. Fortunately, I had a working system and was just swapping a five pin (actually, PL2303) adapter to a six pin one with the intent to make the download process “automatic”.
And that modification works beautifully - cut the trace from “RST” to pin 9, solder the “RST” pin to the RTS “thru”. I used a piece of self-fluxing enamelled wire, almost invisible on the board.
This is clearly a gross design blunder in these “knock-off” boards which appear to follow about two or three designs but are marketed by a myriad of vendors, as are the Arduino Pro Mini boards themselves. The original designs such as the Sainsmart (FTDI chipset) appear to be problem-free and the sixth pin is labelled not “RST” but “RTS” - as it should be.
Just to add to this thread, I posted the other day on the “general electronics” part of the forum that there are some Chinese sellers on ebay now selling working CP2102 usb serial converters (no DTR mod required). They look like this:
You just have to trawl through ebay until you find one, and because they are new, they’re not as cheap as the modable converters (I’ve seen them for between 4 and 8). Be careful when looking for them as there a similar converters which looks almost the same but still requires the DTR mod. Here are pics of the two converters side by side:
What these "newer" converters actually provide is a genuine implementation of the pinout of the FTDI FT232 leads which directly match the interface connections of the Mini Pro and similar devices.
This in effect "sacrifices" the 3.3V pin for the CTS signal which is in fact an input to the USB adaptor and connects to a second ground line on the Arduino device as it is not otherwise useful in this application (CTS is simply ignored by the software).
Personally, as the "faulty" versions are readily modified and cost less than US$1.50 (for the PL2303 version which is admittedly more difficult to modify; or US$2.11 for the CP2102), I tend to "run" with that. :D
RTS is a much better pin to use for Auto-reset than DTR. The days of needing to use DTR for auto reset have long passed. I wish everyone would stop using it and switch their designs over to RTS. Using RTS allows the option of opening the serial connection without resetting the target while DTR does not.
--- bill
i use this one from ebay, just soldered a pin header onto the DTR pad, no tracks to cut or anything, currently under $3
@Paul__B
Personally, as the “faulty” versions are readily modified and cost less than US$1.50 (for the PL2303 version which is admittedly more difficult to modify; or US$2.11 for the CP2102), I tend to “run” with that.
Hello to a fellow New South Welshperson. Unfortunately, I’m living in the middle of nowhere in NL at the moment, and buying ebay stuff that comes from China to the EU seems to be hit and miss - dependent on the price of the item. What I’ve noticed is that Chinese ebay sellers with the lowest prices tend to have massive amounts of negatives and neutrals for non-delivery. I’ve risked it a couple of times and indeed the items never arrived or took 6 weeks to get here. I got refunds for the non-deliveries, but the issue is the amount of time you lose waiting for something that is never going to arrive. My father back in AU has better luck with ebay buys/deliveries from China (timewise), and of course AU is closer to China geographically so that’s to be expected. But for me over here, parsimony has a time dimension. =(
The other thing is that the modules that I posted above came into my possession as a result of an ebay bait and switch. The modules that I ordered from the Chinese ebay seller were the “faulty” ones (the usual CP2102 “Baite” modules that a lot of posters here seem to be modding because of the ease of soldering from the DTR pad that is provided) BUT what I got was the the modules pictured above (and I didn’t have to pay $4-$8 to get 'em :wink: ). It was a pleasant surprise that I only had to mod one module.
I have also found that you release the button on the arduino when the led flashes on the CP210x I am using an older version of the CP210x and this took several tries to figure out, but it is now working correctly.
I was having the same problem with CP2101 + ESP8266 (ESP12) + Arduino IDE
Connection:
CP2101 ESP-12
DTR — GPIO0 (pull up)
RST — RTS (pull up)
TXD — RXD
RXD — TXD
GPIO15 (pull down)
GPIO2 (pull up)
CH_PD (pull_up)
Problem:
Message “error: espcomm_open failed” or directly ESP8266 blocked.
Solution:
I was thinking what the problem was bad pin conection in the CP2101 as bperrybap described or another one.
Solution:
Connect both GND pins beween CP2101 and ESP8266 :confused:
Probably it’s a tipical error of novice but I want to share. :slight_smile:
Regards and excuse for my english.
As of today, "Alice" has sold 2,412 of the proper adapter. I have found her to be amongst the most reliable suppliers, albeit not the cheapest. Of course, you still have the slow boat from china and her description on that page is in fact, incorrect, describing the "bodgie" version!
|500x500 This design drops the 3.3 V output - which is just as well since it is essentially thoroughly useless. It is really only a reference voltage, not suitable for powering anything other than perhaps two indicator LEDs, certainly not an ESP8266.
Paul__B: I have found {Alice} to be amongst the most reliable suppliers,...
Me too. Arduino clones, related electronics and so on, many transactions - "Alice" does good business.
Paul__B: This design drops the 3.3 V output - which is just as well since it is essentially thoroughly useless. It is really only a reference voltage, not suitable for powering anything other than perhaps two indicator LEDs, certainly not an ESP8266.
i would also agree alice is reliable but charges more and thanks to ebay protection little benefit over cheaper ones like this for a dollar and change:
http://www.ebay.com/itm/6Pin-CP2102-Module-USB-2-0-To-TTL-On-STC-To-Arduino-Board-Promini-Download-/271582898514?pt=LH_DefaultDomain_0&hash=item3f3b9a2952
believe it or not i have purchased literally hundreds of that exact model for clients and academic use. it is not "new" and i would definitely disagree about the 3.3v. not a "reference voltage" such as on avr but 50ma spec, 70ma or more real. unmodified proven useful for 99% of projects, personal and many others over several semesters. true that it fails as-is with esp and relays but a cheepee ldo tacked on between those two pins fixes that. in my experience makes a fine arduino programmer and general project power supply for MOST circuits.
btw the even cheaper ones with switch are the real new kid on the block and terrible adapters for several reasons.
