Hello everybody, my name is Geovannys, nice to meet you.
I need to solve this problem for class, please.
Thank you for your information
I am using nano with expansion board
`int boton= 3;
int leds[]={9,10,11,12};
int numleds = sizeof(leds) / sizeof(leds[0]);
pinMode(A3,INPUT);//Asigna el pin 2 como entrada el pin 2 donde está la entrada del botón
for(int i=0; i< numleds; i++){
pinMode(leds[i],OUTPUT);
randomSeed(analogRead(0));
boton = digitalRead(A3);//digital read número de pin donde se encuentra el pulsador
//Asigno a la variable "ValorBot" el valor que viene del pulsador cuando lo presiono
Serial.println(boton);
if (digitalRead(boton) == HIGH){
int led =random(0,numleds);
digitalWrite(leds[led],HIGH);
digitalWrite(leds[led],LOW);
I want to press the button and turn on a LED randomly each time.
Consider using INPUT_PULLUP in pinMode() for the input pin to turn on the built in pullup resistor. Arrange the button wiring to take the pin LOW when pressed and detect LOW as a button press. No need for extra external components
Also, take note of post #3 above. You need to test the state of the button pin
Good mornig.
Good morning, nice to meet you.
What happens when you upload the sketch ?
switch (contador){
//encender los Leds de acuerdo al contador
case 0:
//Todos los leds encendido
digitalWrite(led_1, HIGH);
digitalWrite(led_2, LOW);
digitalWrite(led_3, LOW);
digitalWrite(led_4, LOW);
Have you got a pulldown resistor keeping pin A3 LOW when the button is not pressed ?
int led_1 = 9;
int led_2 = 10;
int led_3 = 11;
int led_4 = 12;
int pulsadoravanzar = 3;
int valorpul = 0; //variable usada para el antirrebote del controlador avanzar
int contador; //variable asociada a un contador
// Declaración de entradas y sálidas digitales:
pinMode(pulsadoravanzar,INPUT);//Asigna el pin 3 como entrada el pin 3 donde está la entrada del botón
pinMode(led_1,OUTPUT);
pinMode(led_2,OUTPUT);
pinMode(led_3,OUTPUT);
pinMode(led_4,OUTPUT);
pulsadoravanzar = digitalRead(A3);//digital read número de pin donde se encuentra el pulsador
Serial.println(pulsadoravanzar);
if (pulsadoravanzar == LOW){
valorpul = 1; //cambia de estado si se presiona el pulsador
if (pulsadoravanzar == HIGH && valorpul == 1){
valorpul = 0; //se reinicia la variable del antirrebote
contador++; //el contador aumenta en una unidad
if (contador > 4){
contador = 0; //se reinicia el contador regresando al LED 1
switch (contador){
case 0:
case 1:
//Enciende el led 1 y apaga los demás
digitalWrite(led_1, LOW);
digitalWrite(led_2, HIGH);
case 2:
//Enciende el led 2 y apaga los demás
digitalWrite(led_3, HIGH);
case 3:
//Enciende el led 3 y apaga los demás
digitalWrite(led_4, HIGH);
case 4:
//Enciende el led 4 y apaga los demás
