Welp, im new to arduino and without knowing anything i have been told to write some code in order to create an array out of a bunch of numbers separated with spaces. The user would write "9 16 7 4" (for example) and the array should be ["9","16","7","4"]. I have been searching info for a long time and still cannot find anything that helps me.
Where would the user write that?
The strtok() function does that. strtok() and strtok_r() functions in C with examples - GeeksforGeeks
In the serial line. I dont understand almost anything about arduino, and the programming tool i habe been told to use is the tinkercad arduino coding section, so i think the input comes from Serial
Thanks! After that ill need to make basic operations with those elements of the array, so ill se how it comes out
