Tvout coding problem
Deal all,
thanks for reading my topics.
i am newaduino users andi have an assignment that need to TV with arduino.
i got the code from library (TVoutBeta1)
when i tries to compile it , i got the error below:
DemoPAL.pde: In function 'void setup()':
DemoPAL.pde:29:6: error: 'class TVout' has no member named 'begin'
DemoPAL.pde:29:12: error: 'PAL' was not declared in this scope
DemoPAL.pde:30:6: error: 'class TVout' has no member named 'select_font'
DemoPAL.pde:32:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:33:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:34:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:35:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:36:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:37:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:38:6: error: 'class TVout' has no member named 'bitmap'
DemoPAL.pde:39:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:41:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:42:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:46:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:47:6: error: 'class TVout' has no member named 'select_font'
DemoPAL.pde:48:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:49:6: error: 'class TVout' has no member named 'select_font'
DemoPAL.pde:50:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:51:6: error: 'class TVout' has no member named 'select_font'
DemoPAL.pde:52:6: error: 'class TVout' has no member named 'println'
DemoPAL.pde:53:6: error: 'class TVout' has no member named 'select_font'
DemoPAL.pde:54:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:57:6: error: 'class TVout' has no member named 'print'
DemoPAL.pde:58:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:62:6: error: 'class TVout' has no member named 'draw_circle'
DemoPAL.pde:62:21: error: 'class TVout' has no member named 'hres'
DemoPAL.pde:62:33: error: 'class TVout' has no member named 'vres'
DemoPAL.pde:62:45: error: 'class TVout' has no member named 'vres'
DemoPAL.pde:62:54: error: 'WHITE' was not declared in this scope
DemoPAL.pde:63:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:64:6: error: 'class TVout' has no member named 'draw_circle'
DemoPAL.pde:64:21: error: 'class TVout' has no member named 'hres'
DemoPAL.pde:64:33: error: 'class TVout' has no member named 'vres'
DemoPAL.pde:64:45: error: 'class TVout' has no member named 'vres'
DemoPAL.pde:64:60: error: 'INVERT' was not declared in this scope
DemoPAL.pde:65:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:69:6: error: 'class TVout' has no member named 'draw_rect'
DemoPAL.pde:70:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:71:6: error: 'class TVout' has no member named 'draw_rect'
DemoPAL.pde:72:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:75:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:78:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:82:6: error: 'class TVout' has no member named 'print'
DemoPAL.pde:83:6: error: 'class TVout' has no member named 'print'
DemoPAL.pde:84:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde: In function 'void intro()':
DemoPAL.pde:142:8: error: 'class TVout' has no member named 'bitmap'
DemoPAL.pde:142:19: error: 'class TVout' has no member named 'hres'
DemoPAL.pde:144:8: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:146:37: error: 'class TVout' has no member named 'vres'
DemoPAL.pde:147:8: error: 'class TVout' has no member named 'bitmap'
DemoPAL.pde:147:19: error: 'class TVout' has no member named 'hres'
DemoPAL.pde:148:8: error: 'class TVout' has no member named 'delay'
DemoPAL.pde:150:6: error: 'class TVout' has no member named 'delay'
DemoPAL.pde: In function 'void printcube()':
DemoPAL.pde:157:85: error: 'class TVout' has no member named 'hres'
DemoPAL.pde:158:85: error: 'class TVout' has no member named 'vres'
DemoPAL.pde:160:6: error: 'class TVout' has no member named 'delay_frame'
DemoPAL.pde: In function 'void draw_cube()':
DemoPAL.pde:205:68: error: 'WHITE' was not declared in this scope
Error compiling.
hope i got your help and get it working
also the code is below:
#include <TVout.h>
#include <fontALL.h>
#include "schematic.h"
#include "TVOlogo.h"
TVout TV;
int zOff = 150;
int xOff = 0;
int yOff = 0;
int cSize = 50;
int view_plane = 64;
float angle = PI/60;
float cube3d[8][3] = {
{xOff - cSize,yOff + cSize,zOff - cSize},
{xOff + cSize,yOff + cSize,zOff - cSize},
{xOff - cSize,yOff - cSize,zOff - cSize},
{xOff + cSize,yOff - cSize,zOff - cSize},
{xOff - cSize,yOff + cSize,zOff + cSize},
{xOff + cSize,yOff + cSize,zOff + cSize},
{xOff - cSize,yOff - cSize,zOff + cSize},
{xOff + cSize,yOff - cSize,zOff + cSize}
unsigned char cube2d[8][2];
TV.begin(PAL,120,96);
TV.select_font(font6x8);
intro();
TV.println("I am the TVout\nlibrary running on a freeduino\n");
TV.delay(2500);
TV.println("I generate a PAL\nor NTSC composite video using\ninterrupts\n");
TV.delay(2500);
TV.println("My schematic:");
TV.delay(1500);
TV.bitmap(0,0,schematic);
TV.delay(10000);
TV.clear_screen();
TV.println("Lets see what\nwhat I can do");
TV.delay(2000);
//fonts
TV.clear_screen();
TV.println(0,0,"Multiple fonts:");
TV.select_font(font4x6);
TV.println("4x6 font FONT");
TV.println("6x8 font FONT");
TV.select_font(font8x8);
TV.println("8x8 font FONT");
TV.delay(2000);
TV.clear_screen();
TV.print(9,44,"Draw Basic Shapes");
TV.delay(2000);
//circles
TV.clear_screen();
TV.draw_circle(TV.hres()/2,TV.vres()/2,TV.vres()/3,WHITE);
TV.delay(500);
TV.draw_circle(TV.hres()/2,TV.vres()/2,TV.vres()/2,WHITE,INVERT);
TV.delay(2000);
//rectangles and lines
TV.clear_screen();
TV.draw_rect(20,20,80,56,WHITE);
TV.delay(500);
TV.draw_rect(10,10,100,76,WHITE,INVERT);
TV.delay(500);
TV.draw_line(60,20,60,76,INVERT);
TV.draw_line(20,48,100,48,INVERT);
TV.delay(500);
TV.draw_line(10,10,110,86,INVERT);
TV.draw_line(10,86,110,10,INVERT);
TV.delay(2000);
//random cube forever.
TV.clear_screen();
TV.print(16,40,"Random Cube");
TV.print(28,48,"Rotation");
TV.delay(2000);
randomSeed(analogRead(0));
int rsteps = random(10,60);
switch(random(6)) {
case 0:
for (int i = 0; i < rsteps; i++) {
zrotate(angle);
printcube();
case 1:
zrotate(2PI - angle);
printcube();
case 2:
xrotate(angle);
printcube();
case 3:
xrotate(2
PI - angle);
printcube();
case 4:
yrotate(angle);
printcube();
case 5:
yrotate(2*PI - angle);
printcube();
void intro() {
unsigned char w,l,wb;
int index;
w = pgm_read_byte(TVOlogo);
l = pgm_read_byte(TVOlogo+1);
if (w&7)
wb = w/8 + 1;
wb = w/8;
index = wb*(l-1) + 2;
for ( unsigned char i = 1; i < l; i++ ) {
TV.bitmap((TV.hres() - w)/2,0,TVOlogo,index,w,i);
index-= wb;
TV.delay(50);
for (unsigned char i = 0; i < (TV.vres() - l)/2; i++) {
TV.bitmap((TV.hres() - w)/2,i,TVOlogo);
TV.delay(50);
TV.delay(3000);
TV.clear_screen();
void printcube() {
//calculate 2d points
for(byte i = 0; i < 8; i++) {
cube2d[0] = (unsigned char)((cube3d[0] * view_plane / cube3d*[2]) + (TV.hres()/2));
cube2d[1] = (unsigned char)((cube3d[1] * view_plane / cube3d[2]) + (TV.vres()/2));
_ }_
TV.delay_frame(1);
TV.clear_screen();
draw_cube();
_}
void zrotate(float q) {
float tx,ty,temp;
tx = cube3d[0] - xOff;
ty = cube3d[1] - yOff;
temp = tx * cos(q) - ty * sin(q);
ty = tx * sin(q) + ty * cos(q);
tx = temp;
cube3d[0] = tx + xOff;
cube3d[1] = ty + yOff;
void yrotate(float q) {
float tx,tz,temp;
tz = cube3d[2] - zOff;
temp = tz * cos(q) - tx * sin(q);
tx = tz * sin(q) + tx * cos(q);
tz = temp;
cube3d[2] = tz + zOff;
void xrotate(float q) {
float ty,tz,temp;
temp = ty * cos(q) - tz * sin(q);
tz = ty * sin(q) + tz * cos(q);
ty = temp;
}_
void draw_cube() {
TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[1][0],cube2d[1][1],WHITE);
TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[2][0],cube2d[2][1],WHITE);
TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[4][0],cube2d[4][1],WHITE);
TV.draw_line(cube2d[1][0],cube2d[1][1],cube2d[5][0],cube2d[5][1],WHITE);
TV.draw_line(cube2d[1][0],cube2d[1][1],cube2d[3][0],cube2d[3][1],WHITE);
TV.draw_line(cube2d[2][0],cube2d[2][1],cube2d[6][0],cube2d[6][1],WHITE);
TV.draw_line(cube2d[2][0],cube2d[2][1],cube2d[3][0],cube2d[3][1],WHITE);
TV.draw_line(cube2d[4][0],cube2d[4][1],cube2d[6][0],cube2d[6][1],WHITE);
TV.draw_line(cube2d[4][0],cube2d[4][1],cube2d[5][0],cube2d[5][1],WHITE);
TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[6][0],cube2d[6][1],WHITE);
TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[3][0],cube2d[3][1],WHITE);
TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[5][0],cube2d[5][1],WHITE);
_}*_
put the TV library in the 'libraries' folder..
thanks my friend for the respond
TV library was already been in the libraries folder before compiling the code
any advise
