Again I am trying to run a simple TV out code from the standard sketches provided with the TVout library. The code is this
#include <TVout.h>
#include <fontALL.h>
#include "schematic.h"
#include "TVOlogo.h"
TVout TV;
int zOff = 150;
int xOff = 0;
int yOff = 0;
int cSize = 50;
int view_plane = 64;
float angle = PI/60;
float cube3d[8][3] = {
{xOff - cSize,yOff + cSize,zOff - cSize},
{xOff + cSize,yOff + cSize,zOff - cSize},
{xOff - cSize,yOff - cSize,zOff - cSize},
{xOff + cSize,yOff - cSize,zOff - cSize},
{xOff - cSize,yOff + cSize,zOff + cSize},
{xOff + cSize,yOff + cSize,zOff + cSize},
{xOff - cSize,yOff - cSize,zOff + cSize},
{xOff + cSize,yOff - cSize,zOff + cSize}
unsigned char cube2d[8][2];
TV.begin(PAL,120,96);
TV.select_font(font6x8);
intro();
TV.println("I am the TVout\nlibrary running on a freeduino\n");
TV.delay(2500);
TV.println("I generate a PAL\nor NTSC composite video using\ninterrupts\n");
TV.delay(2500);
TV.println("My schematic:");
TV.delay(1500);
TV.bitmap(0,0,schematic);
TV.delay(10000);
TV.clear_screen();
TV.println("Lets see what\nwhat I can do");
TV.delay(2000);
//fonts
TV.clear_screen();
TV.println(0,0,"Multiple fonts:");
TV.select_font(font4x6);
TV.println("4x6 font FONT");
TV.println("6x8 font FONT");
TV.select_font(font8x8);
TV.println("8x8 font FONT");
TV.delay(2000);
TV.clear_screen();
TV.print(9,44,"Draw Basic Shapes");
TV.delay(2000);
//circles
TV.clear_screen();
TV.draw_circle(TV.hres()/2,TV.vres()/2,TV.vres()/3,WHITE);
TV.delay(500);
TV.draw_circle(TV.hres()/2,TV.vres()/2,TV.vres()/2,WHITE,INVERT);
TV.delay(2000);
//rectangles and lines
TV.clear_screen();
TV.draw_rect(20,20,80,56,WHITE);
TV.delay(500);
TV.draw_rect(10,10,100,76,WHITE,INVERT);
TV.delay(500);
TV.draw_line(60,20,60,76,INVERT);
TV.draw_line(20,48,100,48,INVERT);
TV.delay(500);
TV.draw_line(10,10,110,86,INVERT);
TV.draw_line(10,86,110,10,INVERT);
TV.delay(2000);
//random cube forever.
TV.clear_screen();
TV.print(16,40,"Random Cube");
TV.print(28,48,"Rotation");
TV.delay(2000);
randomSeed(analogRead(0));
int rsteps = random(10,60);
switch(random(6)) {
case 0:
for (int i = 0; i < rsteps; i++) {
zrotate(angle);
printcube();
case 1:
zrotate(2*PI - angle);
printcube();
case 2:
xrotate(angle);
printcube();
case 3:
xrotate(2*PI - angle);
printcube();
case 4:
yrotate(angle);
printcube();
case 5:
yrotate(2*PI - angle);
printcube();
void intro() {
unsigned char w,l,wb;
int index;
w = pgm_read_byte(TVOlogo);
l = pgm_read_byte(TVOlogo+1);
if (w&7)
wb = w/8 + 1;
wb = w/8;
index = wb*(l-1) + 2;
for ( unsigned char i = 1; i < l; i++ ) {
TV.bitmap((TV.hres() - w)/2,0,TVOlogo,index,w,i);
index-= wb;
TV.delay(50);
for (unsigned char i = 0; i < (TV.vres() - l)/2; i++) {
TV.bitmap((TV.hres() - w)/2,i,TVOlogo);
TV.delay(50);
TV.delay(3000);
TV.clear_screen();
void printcube() {
//calculate 2d points
for(byte i = 0; i < 8; i++) {
cube2d[i][0] = (unsigned char)((cube3d[i][0] * view_plane / cube3d[i][2]) + (TV.hres()/2));
cube2d[i][1] = (unsigned char)((cube3d[i][1] * view_plane / cube3d[i][2]) + (TV.vres()/2));
TV.delay_frame(1);
TV.clear_screen();
draw_cube();
void zrotate(float q) {
float tx,ty,temp;
tx = cube3d[i][0] - xOff;
ty = cube3d[i][1] - yOff;
temp = tx * cos(q) - ty * sin(q);
ty = tx * sin(q) + ty * cos(q);
tx = temp;
cube3d[i][0] = tx + xOff;
cube3d[i][1] = ty + yOff;
void yrotate(float q) {
float tx,tz,temp;
tz = cube3d[i][2] - zOff;
temp = tz * cos(q) - tx * sin(q);
tx = tz * sin(q) + tx * cos(q);
tz = temp;
cube3d[i][2] = tz + zOff;
void xrotate(float q) {
float ty,tz,temp;
temp = ty * cos(q) - tz * sin(q);
tz = ty * sin(q) + tz * cos(q);
ty = temp;
void draw_cube() {
TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[1][0],cube2d[1][1],WHITE);
TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[2][0],cube2d[2][1],WHITE);
TV.draw_line(cube2d[0][0],cube2d[0][1],cube2d[4][0],cube2d[4][1],WHITE);
TV.draw_line(cube2d[1][0],cube2d[1][1],cube2d[5][0],cube2d[5][1],WHITE);
TV.draw_line(cube2d[1][0],cube2d[1][1],cube2d[3][0],cube2d[3][1],WHITE);
TV.draw_line(cube2d[2][0],cube2d[2][1],cube2d[6][0],cube2d[6][1],WHITE);
TV.draw_line(cube2d[2][0],cube2d[2][1],cube2d[3][0],cube2d[3][1],WHITE);
TV.draw_line(cube2d[4][0],cube2d[4][1],cube2d[6][0],cube2d[6][1],WHITE);
TV.draw_line(cube2d[4][0],cube2d[4][1],cube2d[5][0],cube2d[5][1],WHITE);
TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[6][0],cube2d[6][1],WHITE);
TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[3][0],cube2d[3][1],WHITE);
TV.draw_line(cube2d[7][0],cube2d[7][1],cube2d[5][0],cube2d[5][1],WHITE);
The error message is
Error compiling for board Arduino Nano.
here is the error:
Arduino: 1.8.19 (Windows 7), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Greazlog.Greazlog-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Greazlog.Greazlog-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10819 -build-path C:\Users\GREAZL~1.GRE\AppData\Local\Temp\arduino_build_716139 -warnings=none -build-cache C:\Users\GREAZL~1.GRE\AppData\Local\Temp\arduino_cache_294776 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries\TVout\examples\DemoPAL\DemoPAL.pde
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Greazlog.Greazlog-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Greazlog.Greazlog-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10819 -build-path C:\Users\GREAZL~1.GRE\AppData\Local\Temp\arduino_build_716139 -warnings=none -build-cache C:\Users\GREAZL~1.GRE\AppData\Local\Temp\arduino_cache_294776 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries\TVout\examples\DemoPAL\DemoPAL.pde
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\GREAZL~1.GRE\AppData\Local\Temp\arduino_build_716139\sketch\DemoPAL.pde.cpp" -o nul
Alternatives for TVout.h: [TVout@1.0.2]
ResolveLibrary(TVout.h)
-> candidates: [TVout@1.0.2]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries\TVout" "C:\Users\GREAZL~1.GRE\AppData\Local\Temp\arduino_build_716139\sketch\DemoPAL.pde.cpp" -o nul
Alternatives for font4x6.h: []
ResolveLibrary(font4x6.h)
-> candidates: []
In file included from C:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries\TVout\examples\DemoPAL\DemoPAL.pde:2:0:
C:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries\TVout/fontALL.h:4:10: fatal error: font4x6.h: No such file or directory
#include "font4x6.h"
compilation terminated.
Using library TVout at version 1.0.2 in folder: C:\Users\Greazlog.Greazlog-PC\Documents\Arduino\libraries\TVout
exit status 1
What I did so far, all did not work:
1-making sure I chose the right board and right port.
2-uninstall and reinstall IDE to newer version
3-removed and reinstalled the TVout library twice, once from library manager, and once from zip file
4- copied the fontALL.h file and pasted it in the library.
5- changed from arduino nano, it several siblings of uno...all refused to compile. I read the discussion on this topic earlier, but still couldnt ...
Please help this is driving me mental..
