Two MPR121 capacity touch sensors
Hi everyone!
I'm trying to get two capacity sensors to work with an Arduino Uno. I'm using the Adafruit library, with the Sparkfun capacity sensors.
I can get a single sensor to work perfectly, however, I can't get my code to see the second one.
As soon as I connect the ADD(R) pin on my second capacity sensor to anything (like explained here), neither sensor works. When the ADD(R) pin on the second one is not connected, the first capacity sensor works fine, but the second one doesn't.
I've attached a Fritzing sketch of the setup I have, with the ADD pin connected to 3.3V, which should give the second sensor the 0x5B address. I've also tried connecting it pin to the SDA and SCL, for 0x5C and 0x5D respectively.
My code is here:
#include <Wire.h>
#include "Adafruit_MPR121.h"
Adafruit_MPR121 cap1 = Adafruit_MPR121();
Adafruit_MPR121 cap2 = Adafruit_MPR121();
  while (!Serial);        // needed to keep leonardo/micro from starting too fast!
  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
  // Default address is 0x5A, if tied to 3.3V its 0x5B
  // If tied to SDA its 0x5C and if SCL then 0x5D
  Serial.println( "looking for 0x5A" );
  if (!cap1.begin(0x5A)) {
      Serial.println("MPR121 0x5A not found, check wiring?");
      while (1);
  Serial.println("MPR121 0x5A found!");
  Serial.println( "looking for 0x5B" );
  if (!cap2.begin(0x5B)) {
      Serial.println("MPR121 0x5B not found, check wiring?");
      while (1);
  Serial.println("MPR121 0x5B found!");
  Serial.prinln("In loop");
Any help would be greatly appreciated :sweat_smile:
Have you broken the jumper link on one of them:-
An address jumper ties the ADD pin to ground, meaning the default I2C address of the chip will be 0x5A. If you need to change the address of the chip (by shorting ADD to a different pin), make sure you open the jumper first.
Also you need to disable the pull up resistors on one of the boards
Jumpers also connect SDA, SCL and the interrupt pin to 10k pull-up resistors. If you don’t require the pull-up resistors you can open the jumpers by cutting the trace connecting them.
