Hi guys,
I work it out. But it still has some problem.
The two ID-12 readers works good. But the data come from the readers have some problem.
my code is :
#include <SoftwareSerial.h>
//SoftwareSerial SSerial(9,8);//rx = digital 1, tx == digital 2
SoftwareSerial SSerial(11,10);
int RFIDResetPin1 = 3; //digital3
int RFIDResetPin2 = 4; //digital4
//Register your RFID tags here
char tag1[13] = "0102ACB7B1A9";
char tag2[13] = "01023C072C14";
char tag3[13] = "01023C013A04";
char tag4[13] = "01023101093A";
char tag5[13] = "01023C0A4376";
void setup(){
SSerial.begin(9600);
pinMode(RFIDResetPin1, OUTPUT);
pinMode(RFIDResetPin2, OUTPUT);
digitalWrite(RFIDResetPin1, HIGH);
digitalWrite(RFIDResetPin2, HIGH);
void loop(){
checkRFIDReader1();// check serial
checkRFIDReader2();// check serial
void checkRFIDReader1(){
//RFID tags are 13+1 characters,
//so no need to check until we have that many bytes available
if(Serial.available() >= 6){
// char tagString[13]; //this will hold the tag string;
int readByte = Serial.read(); //read next available byte
//we MUST start proces at a 2 as it marks the tag begining
//if it is not a 2, get out of here.
// if(readByte != 2) return;
//buffer to hold our tag
char tagString[13];
// //read the serial until we gat a 3, the end of the tag
Serial.readBytesUntil(3, tagString, 13);
Serial.print("From 1 ");
checkTag(tagString); //Check if it is a match
clearTag(tagString); //Clear the char of all value
resetReader1(); //eset the RFID reader
// delay(1000);
void checkRFIDReader2(){
if(SSerial.available() >= 6){
//char tagString[13]; //this will hold the tag string;
int readByte = SSerial.read(); //read next available byte
char tagString[13];
SSerial.readBytesUntil(3, tagString, 13);
Serial.print("From 2 ");
resetReader2(); //eset the RFID reader
// delay(1000);
void checkTag(char tag[]){
//Check the read tag against known tags
if(strlen(tag) == 0) return; //empty, no need to contunue
// if(compareTag(tag, tag1)){ // if matched tag1, do this
// Serial.println("tag 1");
// }else if(compareTag(tag, tag2)){ //if matched tag2, do this
// Serial.println("tag 2");
// }else if(compareTag(tag, tag3)){
// Serial.println("tag 3");
// }else if(compareTag(tag, tag4)){
// Serial.println("tag 4");
// }else if(compareTag(tag, tag5)){
// Serial.println("tag 5");
else{
Serial.print("Tag: ");
Serial.println(tag); //read out any unknown tag
//void lightLED(int pin){
// //Turn on LED on pin "pin" for 250ms
// Serial.println(pin);
// digitalWrite(pin, HIGH);
// delay(250);
// digitalWrite(pin, LOW);
void resetReader1(){
//Reset the RFID reader to read again.
digitalWrite(RFIDResetPin1, LOW);
delay(150);
void resetReader2(){
digitalWrite(RFIDResetPin2, LOW);
delay(150);
void clearTag(char one[]){
//clear the char array by filling with null - ASCII 0
//otherwise, it will think same tag has been read
for(int i = 0; i < 12; i++){
one[i] = 0;
boolean compareTag(char one[], char two[]){
//compare two value to see if same,
//strcmp not working 100% so we do this
if(strlen(one) == 0) return false; //empty
if(one[i] != two[i]) return false;
return true; //no mismatches
The out come data from readers:
From 2 Tag: 280005DC8071$ ¼ Ä ^
From 1 Tag: 280005DC8071
$ ¼ Â ^
From 2 Tag:
From 1 From 1 Tag: 280005DC8071
$ ¼ Â ^
From 2 Tag:
8
From 2 Tag: ÿ 280005DC807$ ¼ Ä ^
$ ¼ Â ^
From 2 Tag:
0005DC8071
$ ¼ Ä ^
$ ¼ Â ^
Some time one reader read several time, and have Garbled!
