Multiple rfid reader
Hello
I would like to interface with two rfid readers at the same time (the model is Q5MOO5, http://www.netronix.pl/_userfiles/Image/plik/Q5M-005_eng.pdf ) with my arduino Duemilanove.
It works good when I use only one reader but not when I plug the second one. It seems to be a programmation problem, the readers read the tags but nothing returns on the serial monitor. I divided the code in two parts to avoid some conflicts between the two rfid readers.
But it doesn't work..
Can you help me!!?
The code is...
#include <NewSoftSerial.h>
NewSoftSerial mySerial1(2, 3); //first RFIDreader
NewSoftSerial mySerial2(4, 5); //second RFIDreader
int tagMem1[11]; //first list to stock data from rfidtag
int tagMem2[11]; //second list
boolean goPrint1 = false; //verification
boolean goPrint2 = false;
int OneByOne=1; //to read one by one
int numero[] = {67, 55, 68, 194, 205}; //number to identify RFIDtag
  Serial.begin(57600);
  mySerial1.begin(9600);
  mySerial2.begin(9600);
//first RFIDreader
 if(OneByOne==1){
 // put tag to memory
    int cnt1=0;
    while (mySerial1.available()) {
    int val1 = mySerial1.read();
    if (cnt1<11) tagMem1[cnt1] = val1;
    cnt1++;
    goPrint1 = true;
  if (goPrint1==true) { /// if there is some data from serial port
    if (isTagOK1()==true) { /// check if data is OK
            for(int i=0; i< 5; i++){
            if(tagMem1[10]==numero[i]){
            Serial.print("numero");
            Serial.println(i); // print the Tag number on the serial monitor
    goPrint1 = false;
delay(200);
 // Second RFIDreader
 if(OneByOne==-1){
        int cnt2=0;
  while (mySerial2.available()) {
    int val2 = mySerial2.read();
    if (cnt2<11) tagMem2[cnt2] = val2;
    cnt2++;
    goPrint2 = true;
    if (goPrint2==true) { /// if there is some data from serial port
    if (isTagOK2()==true) { /// check if data is OK
            for(int j=0; j< 5; j++){
            if(tagMem2[10]==numero[j]){
            Serial.println(j);  // print the Tag number on the serial monitor
    goPrint2 = false;
delay(200);
OneByOne=-OneByOne; //to alternate between the two procedures of the two readers
boolean isTagOK1() { /// check procedure for the first reader
  if ((tagMem1[0]==1) && (tagMem1[1]==11)  && (tagMem1[8]==255)) {
    return true;
  else {
    return false;
boolean isTagOK2() { /// check procedure for the second reader
  if ((tagMem2[0]==1) && (tagMem2[1]==11)  && (tagMem2[8]==255)) {
    return true;
  else {
    return false;
By doing this you create a new variable for each character you read, you will soon run out of memory if you do this.
If nothing is appearing in the monitor then this line:-
Should be changed so you print something out no matter what the token is.
The use some print statements to test the assumptions you have made in your code.
There is no need to use the OneByOne variable, I don't see what you think it does.
Hi Milou,
you could try to put one RFID on the hardware port and the other one with NewSoftSerial ?
some ideas how to refactor your code (not tested) without the use of delay and minimal number of flags...
	if (rfid1() == true) // 11 chars read
		Serial.print("RFID1: ");
		for (int i=0; i< 11; i++)
			Serial.print(tagMem1[i]);
		int person = checkCode(1);
		if (person() > 0)
			// open the door
	if (rfid2() == true)
		Serial.print("RFID2: ");
			Serial.print(tagMem2[i]);
		int person = checkCode(2);
		if (person() > 0)
			// open the door
// reader help function
// every call one char/byte is read,
// after 11 calls tagMem is filled and it will return true
// the next call it will reset itself.
boolean rfid1()
	static int i=0;
	if (i==11) i=0;
	if (mySerial1.Available() >0)
		tagMem1[i] = mySerial1.Read();
		i++;
	return (i==11);
// idem
boolean rfid2()
	static int i=0;
	if (i==11) i=0;  // reset for next RFID read
	if (mySerial2.Available() >0)
		tagMem2[i] = mySerial2.Read();
		i++;
	return (i==11);
// idem
int checkCode(int x)
	if (x == 1)
		int i=0;
		while (tagMem1[i] == numero[i] && i < 11) i++;
		if (i==11) return 1;
	if (x == 2)
		i=0;
		while (tagMem2[i] == numero[i] && i < 11) i++;
		if (i==11) return 2;
	return 0;
Thank you for the answers!!
Grumpy_Mike, I tried what you said but there is still nothing on the serial monitor.
Robtillart, i tried your code but still nothing. Even if there is just one rfidreader plugged on the arduino.
But your code works good when i modified it to react for only one rfidreader.
I really think there is a conflict when the arduino try to communicate with two readers.
Is it a problem about the code ? because of they communicate at the same baud (9600) ? ......
Do you have an idea?
Thanks!
Here is the simplier version of robtillart's code i used :
boolean rfid1()
	static int i=0;
	if (i==11) i=0;
	if (mySerial1.available() >0)
		tagMem1[i] = mySerial1.read();
		i++;
	return (i==11);
// idem
boolean rfid2()
	static int i=0;
	if (mySerial2.available() >0)
		tagMem2[i] = mySerial2.read();
		i++;
	return (i==11);
The baud-rate 9600 should not be the problem as far as I know.
So the base-code seems to work, so lets try to modify that code so that one RFID works with NewSoftSerial and the other on the hardware Serial.
You need to connect the RFID2 to the HW serial pin 0 AFTER downloading the sketch.
give it a try (code not tested, just modified, might need some fixing still)
// NewSoftSerial mySerial2(4, 5); //second RFIDreader
	// mySerial2.begin(9600);
boolean rfid1()
	static int i=0;
	if (i==11) i=0;
		i++;
	return (i==11);
// idem
boolean rfid2()
	static int i=0;
	if (Serial.available() >0)
		tagMem2[i] = Serial.read();
		i++;
	return (i==11);
It works!
Thank you robtillaart.
So it was a comunication problem between the two Serial created with NewSoftSerial().
For the next step of my project, I need to communicate with 5 rfidreaders.... hmm
So i want to know if there is an other way to create new Serials ?
I may have to use an arduinoMega to have many RXpin.
What do you think about this ?
Well there are only 4 on the Mega, but that is hardware so I suppose you could implement another one or two in software.
this might be a possible directions for a solution - Low-Cost RS232 Multiplexer -
just found it by googling "rs232 multiplexing"
