Two SoftwareSerial ports, one hardware sreial
I wrote a code for arduino uno, so that it collects data from the GPS sensor and sends it to the server via GET method via the GPRS shield. Here is the code:
#include <GPRS_Shield_Arduino.h>
#include <TroykaGPS.h>
#include <SoftwareSerial.h>
#define IMEI "861508038977104"
#define INTERVAL 60000
#define LEN 370
char time[16];
char date[16];
char tcpBuffer[370];
char buf[16];//time buffer
unsigned long previousMillis = 0;
SoftwareSerial gprsStream(10, 11);
SoftwareSerial gpsStream(4, 5);
GPS gps(gpsStream);
GPRS gprs(gprsStream);
void setup(){
	while(!Serial){}
	Serial.println("Serial opened on 9600");
	delay(100);
	gpsStream.begin(115200);
	Serial.println("gpsStream opened on 115200");
	gpsStream.write("$PMTK251,9600*17\r\n");
	Serial.println("gpsStream changed to 9600");
	gpsStream.end();
	Serial.println("gpsStream closed");
void loop(){
	gprsStream.begin(9600);
	Serial.println("gprsStream opened on 9600");
	gprs.powerOn();
	gprs.getDateTime(buf);
	Serial.print("time on gprs: ");
	Serial.println(buf);
	gprs.powerOff();
	gprsStream.end();
	Serial.println("gprsSerial closed");
	gpsStream.begin(9600);
	Serial.println("gpsStream opened on 9600");
	if(gps.available()){
		gps.readParsing();
		switch(gps.getState()){
		case GPS_OK:
			gps.getTime(time, 16);
			gps.getDate(date, 16);
			sprintf(tcpBuffer, "GET /recvdata.php?%s_%s.txt&data=%s_%s_%s_%f_%f HTTP/1.0\r\n\r\n", date, time, IMEI, date, time, gps.getLatitudeBase10(), gps.getLongitudeBase10());
			Serial.print("formed: ");
			Serial.print(tcpBuffer);
		case GPS_ERROR_DATA:
			sprintf(tcpBuffer, "GET /recvdata.php?filename=%s_err.txt&data=ERROR_DATA_%s_%s HTTP/1.0\r\n\r\n", buf, buf, IMEI);
			Serial.println(tcpBuffer);
		case GPS_ERROR_SAT:
			sprintf(tcpBuffer, "GET /recvdata.php?filename=%s_err.txt&data=ERROR_SAT_%s_%s HTTP/1.0\r\n\r\n", buf, buf, IMEI);
	else{
		Serial.println("GPS not available");
		return;
	gpsStream.end();
	gprs.powerOn();
	while(!gprs.init()){
		Serial.println("GPRS init error");
	Serial.println("GPRS init success");
	delay(3000);
	while(!gprs.join("internet.beeline.ru", "beeline", "beeline")){
		Serial.println("GPRS error joining network");
	Serial.println("GPRS connected to the network");
	Serial.print("IP address is ");
	Serial.println(gprs.getIPAddress());
	while(!gprs.connect(TCP, "188.44.53.81", 80)){
		Serial.println("GPRS could not connect to the internet");
	Serial.println("GPRS connected to the internet");
	gprs.send(tcpBuffer);
	clearTcpBuffer();
	gprs.close();
	gprs.disconnect();
	delay(100);
	Serial.println("Buffer sent");
	gprs.powerOff();
	gprsStream.end();
	Serial.println("gprsStream closed");
	Serial.println("waiting...");
	while(millis() - previousMillis < INTERVAL){
	previousMillis = millis();
void clearTcpBuffer(){
	for(int i = 0; i < 370; i++){
		tcpBuffer[i] = 0;
This code does not give any output on the hardware Serial port. The parts for GPS and GPRS shield work perfectly separately
softwareserial library does not support more that one is instance unless you use the listen()/ isListening()/ stopListening() routines to switch between instances... may not be the best route though for what you are doing.
There are other software serial libraries with I believe can support that OR get a leonardo (it had an addtional hardware serial port (Serial1) you can use) + software serial OR another board such as the MEGA that has 4 hardware serial ports
