Txt data search on Arduino SD card
hi everyone...
I tried to do a data search on the data.txt file on the Arduino SD card...
but it can only be read if the data is in the first row (top), the second data and so on cannot be found...
I wonder why?
here is the code that I use
Thank You
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SD.h>
const int chipSelect = 4;
File myFile;
char buf[8];
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
   //pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // re-open the file for reading:
  myFile = SD.open("data.txt");
  if (myFile) {
    Serial.println("data.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
        myFile.read(buf,8);
        if(strncmp(buf,"18429874",8)==0)
            Serial.println("Match!");
    // close the file:
    myFile.close();
  	// if the file didn't open, print an error:
    Serial.println("error opening test.txt");
	// nothing happens after setup
I moved your topic to an appropriate forum category @ranggajulizar .
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Sorry, this is my first time using this forum..
and thank you for fixing it
How the data in the file is organized? Is it a lines with exact 8 characters each? Does that lines terminated by CR or LF?
hi b707
thank you for responding..
yes, lines are written with 8 characters..
the following data is written in the file..
without CR and LF
18429874
18429875
18429876
18429877
18429878
18429879
18429880
18429881
18429882
18429883
18429884
18429885
18429886
18429887
Sorry because I'm a beginner when it comes to Arduino storage
Are you sure?
Without line terminated, your data should looks like this:
How the data did written in the file? Or could you show the file, listed in HEX view mode ?
with CR without LF ..
like this
or if you have a string search code in the txt file... that I can use, I would be very grateful
In that case your lines has 9 chars length rather than 8, so you need to read it accordingly.
Do not forget to increase a length of buf array.
then to be able to read the next line too, is there a way?
because if I look for the second or third data it can't be found
You just need to change two lines
and
may be a function like this would work. (typed here, totally untested)
assuming you have
#include <SdFat.h>
SdFat sd;
File file;
// in setup
    if (!sd.begin()) return false; // Initialization failed
then the function could be
bool findStringInFile(const char *filename, const char *searchString, size_t &pos) {
    file = sd.open(filename, FILE_READ);
    if (!file) return false; // File not found
    size_t searchLen = strlen(searchString);
    size_t index = 0;
    pos = 0;
    while (file.available()) {
        char ch = file.read();
        if (ch == searchString[index]) {
            index++;
            if (index == searchLen) { // Match found
                pos = file.position() - searchLen;
                file.close();
                return true;
            index = (ch == searchString[0]) ? 1 : 0; // Reset index or start new match (not foolproof)
    file.close();
    return false; // String not found
you would use it like this:
size_t position;
if (findStringInFile("data.txt", "18429874", position)) {
    Serial.print("String found at position: ");
    Serial.println(position);
    Serial.println("String not found");
Thanks Jackson, I'll try it
Thank you for helping, I will update the results after this
Hi Jackson, I have tried implementing the code,
is my writing correct?
following are the results
SdFat sd;
File file;
    size_t index = 0;
    pos = 0;
            index++;
                file.close();
                return true;
    file.close();
size_t position;
missing the includes for the library
try something like this, with the serial monitor at 115200 bauds
#include <SdFat.h>
SdFat sd;
  File file = sd.open(filename, FILE_READ);
  size_t index = 0;
  pos = 0;
      index++;
        file.close();
        return true;
  file.close();
  if (!sd.begin()) {
    if (sd.card()->errorCode()) {
      Serial.println("SD initialization failed.");
    } else if (sd.vol()->fatType() == 0) {
      Serial.println("Can't find a valid FAT16/FAT32 partition.");
      Serial.println("Can't determine error type");
    return;
  size_t position;
void loop() {}
sorry for my misunderstanding...
the result is
is there no need to declare "chipselect" on
const uint8_t SD_CHIP_SELECT = 4;
indeed - I typed that here β€” you need to pass the parameters as you did before
finally...I can find it...
Thank you very much Jackson for your help..
here is the final code
#include <SdFat.h>
SdFat sd;
SdFile file;
  File file = sd.open("data.txt", FILE_READ);
  size_t index = 0;
  pos = 0;
      index++;
        file.close();
        return true;
  file.close();
  if (!sd.begin(SD_CHIP_SELECT, SPI_HALF_SPEED)) {
    return;
  size_t position;
  if (findStringInFile("data.txt", "18429875", position)) {
void loop() {}
glad it helped
hi, anyone here?
I found a little problem..
When searching for data using the value sent from the Wiegand RFID, it seems like there are empty characters behind it...
so it doesn't match the values ​​in the list.
How do I remove the empty characters??
I used the trim() command but it couldn't and an error like this appeared
if (findStringInFile("data.txt",wg.getCode(), position)) {
Compilation error: conversion from 'long unsigned int' to 'String' is ambiguous
