thx for the wonderful library, works great on my DS-LCD-TG12864E (ST7920 controller) in spi mode. (R/W = MOSI, E= CLK , PSB =LOW, RS=HIGH)
speed is quite ok in spi, gotta try the parallel mode soon. the liquid crystal itself may be limiter.
Hmm..is possible can u make point to point drawline (x1,y1,x2,y2) available?
There are some imporant differences between GLCD v3 and U8glib. While porting is for sure possible, there are some restrictions on U8glib, which are not present for GLCD lib. GLCD and U8glib have two completly different programming concepts. It might require much more than just replacing the drawing primitives.
Also, Bill's library is highly optimized and much faster than U8glib. On the other hand, U8glib should be more flexible regarding the graphics hardware.
One result of the different concepts is that there is no clear screen available in U8glib. The screen is cleared as soon as you enter the "picture loop".
if it doesnt work out well maybe i will as well try to use 2 LCD display with different library on a same arduino board. it is possible to be done or someone here had done it before?
is there some pitfall in get your lib running on an Arduino Mega 2560 with an EA DOGXL-160 ?
if tried it yesterday and it did not work. i looked at the signals of the pins (with an oscilloscope) and the clock pin was a little bit confusing.
in Hardware SPI Mode the signal was realy destroyed.
in Software SPI Mode the u8g.setContrast(127); worked. but the 'hello World' not.
It looked like something is setting the clock pin manually some times..
the signal of the clock was at ~3.3V level out of the arduino and the odd spikes were at 5V level...
i used the Hardware SPI Pins on the Arduino Mega - see constructor..
i used the example hello world sketch and added the contrast command in setup.
my constructors that i tried were the following:
//U8GLIB_DOGXL160_2X_BW u8g(52, 51, 53, 49); // Software SPI ARDUINO MEGA SPI Com: SCK = 52, MOSI = 51, CS = SS = 53, A0 = 49 //there is something wrong...
U8GLIB_DOGXL160_2X_BW u8g(53, 49); // Hardware SPI ARDUINO MEGA SPI Com: SCK = 52, MOSI = 51, CS = SS = 53, A0 = 49 // here is something wrong too
have you got an idea?
know i will try it with an arduino Duemilanove. we will see
I recently added the 2X driver. Can you please check the single buffer constructor (without 2X).
I also do not own a Mega Board, so i have to rely on whatever the Arduino.h file has defined for the Hardware Pins.
If these hardware pins require some special settings, than these settings are not known to me.
But in any case, the SW SPI should work.
Your observation might also be caused by the connected hardware. How do you do the level transition?
Is it a HC4050 level translator for the signals? Resistor networks might work, but you might observe
other voltage ranges.
I have been using the u8g Library to complete a university project. I have been playing around with it and must say that it is fantastic. The one problem I am having is that I want to display a line of ASCII print for a certain period of time, clear the entree screen and then write another set of ASCII text. I am using an ST7920 screen as it was the only one locally available as all shops have sold out of the KS0108. The screen i attached to a DFRobot mega clone...
Please if anyone can help me I have tried so many ways to get this to work but with no success
In order to display a screen, wait some time and than display another screen, you may use the code and ideas from "GraphicsText.pde" (attached to this post, but also part of the Arduino examples).
hii i used this library it very nice.
i am from india and it also supporting my regional language hindi.
but there is one issue that in that language i need to OVERSTRIKE two characters some time.
means if i send "K" and "a"
then result on lcd should be as shown in image
please help me for this
I also played around with overstrike on a modified glcd lib and the resulting characters are not
very legible for a 5x7 font.
The other tricky thing is that the font either needs to be a fixed width
or the variable width characters need to be rendered centered
within a fixed width.
