Hi
I just tried it with the Display Test code from the examples folder.
I didn't implement g8ulib it in my code befor I know if its working properly.
So my main problem is how to set the pins right because the constructor is gifing
11 pins -> 8 Data and cs, da.
To get the Display working properly i need to manage:
CS -> Chip Select
DC -> di -> Data/Command Control
WR -> Read/Write Select or Write
RD -> Read/Write Enable or Read
Reset -> reset -> Reset / init
My updated example code looks like this:
#include "U8glib.h"
// setup u8g object, please remove comment from one of the following constructor calls
// IMPORTANT NOTE: The complete list of supported devices is here: http://code.google.com/p/u8glib/wiki/device
U8GLIB_NHD31OLED_GR u8g(22, 23, 24, 25, 26, 27, 28, 29, 33, 35, 36); // s8bit Com: D0..D7: 22,23,24,25,26,27,28,29 cs=33 dc=35 wr=36 rd=37 res=34
#define KEY_NONE 0 // Auto
#define KEY_PREV 1 // Left
#define KEY_NEXT 2 // Right
#define KEY_SELECT 3 // Select
#define KEY_BACK 4 // Menu
// DOGS102 shield configuration values
//uint8_t uiKeyPrev = 2;
//uint8_t uiKeyNext = 4;
//uint8_t uiKeySelect = 5;
//uint8_t uiKeyBack = 3;
// DOGM128-Shield configuration values
// DOGXL60-Shield configuration values
uint8_t uiKeyPrev = 47;
uint8_t uiKeyNext = 46;
uint8_t uiKeySelect = 45;
uint8_t uiKeyBack = 48;
uint8_t uiHolderGND = 30;
uint8_t uiKeyCodeFirst = KEY_NONE;
uint8_t uiKeyCodeSecond = KEY_NONE;
uint8_t uiKeyCode = KEY_NONE;
void uiSetup(void) {
// configure input keys
pinMode(uiKeyPrev, INPUT); // set pin to input
digitalWrite(uiKeyPrev, HIGH); // turn on pullup resistors
pinMode(uiKeyNext, INPUT); // set pin to input
digitalWrite(uiKeyNext, HIGH); // turn on pullup resistors
pinMode(uiKeySelect, INPUT); // set pin to input
digitalWrite(uiKeySelect, HIGH); // turn on pullup resistors
pinMode(uiKeyBack, INPUT); // set pin to input
digitalWrite(uiKeyBack, HIGH); // turn on pullup resistors
pinMode(uiHolderGND, OUTPUT); // set Holder Analog GND PIN
digitalWrite(uiHolderGND, LOW); // turn off Analog Holder GND
void uiStep(void) {
uiKeyCodeSecond = uiKeyCodeFirst;
if ( digitalRead(uiKeyPrev) == LOW )
uiKeyCodeFirst = KEY_PREV;
else if ( digitalRead(uiKeyNext) == LOW )
uiKeyCodeFirst = KEY_NEXT;
else if ( digitalRead(uiKeySelect) == LOW )
uiKeyCodeFirst = KEY_SELECT;
else if ( digitalRead(uiKeyBack) == LOW )
uiKeyCodeFirst = KEY_BACK;
if ( uiKeyCodeSecond == uiKeyCodeFirst )
uiKeyCode = uiKeyCodeFirst;
#define MENU_ITEMS 4
char *menu_strings[MENU_ITEMS] = { "First Line", "Second Item", "3333333", "abcdefg" };
uint8_t menu_current = 0;
uint8_t menu_redraw_required = 0;
uint8_t last_key_code = KEY_NONE;
void drawMenu(void) {
uint8_t i, h;
u8g_uint_t w, d;
u8g.setFont(u8g_font_6x13);
u8g.setFontRefHeightText();
u8g.setFontPosTop();
h = u8g.getFontAscent()-u8g.getFontDescent();
w = u8g.getWidth();
for( i = 0; i < MENU_ITEMS; i++ ) {
d = (w-u8g.getStrWidth(menu_strings[i]))/2;
u8g.setDefaultForegroundColor();
if ( i == menu_current ) {
u8g.drawBox(0, i*h+1, w, h);
u8g.setDefaultBackgroundColor();
u8g.drawStr(d, i*h, menu_strings[i]);
void updateMenu(void) {
if ( uiKeyCode != KEY_NONE && last_key_code == uiKeyCode ) {
return;
last_key_code = uiKeyCode;
switch ( uiKeyCode ) {
case KEY_NEXT:
menu_current++;
if ( menu_current >= MENU_ITEMS )
menu_current = 0;
menu_redraw_required = 1;
case KEY_PREV:
if ( menu_current == 0 )
menu_current = MENU_ITEMS;
menu_current--;
// rotate screen, if required
// u8g.setRot180();
//DDRC = B11111111;
//PORTC = B00000000;
DDRD = B11111111;
PORTD = B00000000;
DDRE = B11111111;
PORTE = B00000000;
uiSetup(); // setup key detection and debounce algorithm
menu_redraw_required = 1; // force initial redraw
uiStep(); // check for key press
if ( menu_redraw_required != 0 ) {
u8g.firstPage();
do {
drawMenu();
} while( u8g.nextPage() );
updateMenu(); // update menu bar
