Ubuntu arduino IDE not showing any ports
output of dmesg,
Blockquote[140710.612647] ch341 1-2.1.2:1.0: device disconnected
[140711.379846] usb 1-2.3: USB disconnect, device number 72
[140711.380140] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
[140711.380178] ch341 1-2.3:1.0: device disconnected
[140770.217570] usb 1-2.1.2: new full-speed USB device number 73 using ehci-pci
[140770.326787] usb 1-2.1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[140770.326797] usb 1-2.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[140770.326802] usb 1-2.1.2: Product: USB Serial
[140770.328117] ch341 1-2.1.2:1.0: ch341-uart converter detected
[140770.331587] usb 1-2.1.2: ch341-uart converter now attached to ttyUSB0
[141229.965343] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[141229.965592] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[141229.966972] usb 1-2.1.2: USB disconnect, device number 73
[141229.969148] usb 1-2.1.2: failed to send control message: -19
[141229.969346] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[141229.969389] ch341 1-2.1.2:1.0: device disconnected
I'll try different cables but if it was a charge only cable, how would it know the CH chip was even there?
This result does indicate a problem with the cable.
The Leonardo board doesn't use a CH340 chip. I assume the references to "ch341" in the dmesg output is from you having connected an "Uno" derivative board to your computer with a CH340 chip on it.
Did you use the same cable to connect that working "Uno" board to your computer as the cable you are using to connect the Leonardo? If you are using different cables then that would explain why you are getting different results between the two boards.
Now tried three different cables, same result. Just connected a Wemos board with the same cable and that shows up. Re-connected Leonardo board and it's not showing up.
But now it's showing up in dmesg,
Blockquote[141689.681595] usb 1-2.2: USB disconnect, device number 76
[141689.683996] usb 1-2.2: failed to send control message: -19
[141689.684176] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[141689.684218] ch341 1-2.2:1.0: device disconnected
[141695.036678] usb 1-2.2: new full-speed USB device number 77 using ehci-pci
[141695.160687] usb 1-2.2: New USB device found, idVendor=2341, idProduct=8036, bcdDevice= 1.00
[141695.160697] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[141695.160702] usb 1-2.2: Product: Arduino Leonardo
[141695.160705] usb 1-2.2: Manufacturer: Arduino LLC
[141695.164717] cdc_acm 1-2.2:1.0: ttyACM0: USB ACM device
[141816.640649] usb 1-2.2: USB disconnect, device number 77
[141819.692839] usb 1-2.2: new full-speed USB device number 78 using ehci-pci
[141819.829075] usb 1-2.2: New USB device found, idVendor=2341, idProduct=8036, bcdDevice= 1.00
[141819.829086] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[141819.829090] usb 1-2.2: Product: Arduino Leonardo
[141819.829094] usb 1-2.2: Manufacturer: Arduino LLC
[141819.829805] cdc_acm 1-2.2:1.0: ttyACM0: USB ACM device
Note third line from bottom. Still not available in the Arduino IDE.
I was starting to thing the board was bricked.
And now, it's magically showed up. Thanks.
You are welcome. I'm glad it is working now.
Given the symptoms you described, it is possible this was caused by an intermittent fault in the USB connection. That could happen if the USB cable wasn't plugged into the board fully, or if the cable is damaged or defective. That can result in a situation where there is a connection to the power lines of the cable (and thus the LEDs lighting up), but not to the data lines (and thus no port on the computer).
I also have similar issue with my Arduino Leonardo board. At first it worked without any problems, but suddenly, after about 30 minutes, it stopped showing up in Arduino IDE.
[  238.242620] usb 1-3: new full-speed USB device number 5 using xhci_hcd
[  238.394276] usb 1-3: New USB device found, idVendor=2a03, idProduct=0036, bcdDevice= 0.01
[  238.394293] usb 1-3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[  238.394299] usb 1-3: Product: Arduino Leonardo
[  238.394304] usb 1-3: Manufacturer: Arduino srl
[  238.439778] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[  238.439870] usbcore: registered new interface driver cdc_acm
[  238.439877] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  246.006009] usb 1-3: USB disconnect, device number 5
[  270.458114] usb 1-3: new full-speed USB device number 6 using xhci_hcd
[  270.609754] usb 1-3: New USB device found, idVendor=2a03, idProduct=0036, bcdDevice= 0.01
[  270.609769] usb 1-3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[  270.609775] usb 1-3: Product: Arduino Leonardo
[  270.609780] usb 1-3: Manufacturer: Arduino srl
[  270.612579] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[  278.221326] usb 1-3: USB disconnect, device number 6
[  306.985413] kauditd_printk_skb: 7 callbacks suppressed
[  306.985416] audit: type=1107 audit(1702480736.511:197): pid=759 uid=101 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/timedate1" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.118" pid=1787 label="snap.firefox.firefox" peer_pid=3314 peer_label="unconfined"
                exe="/usr/bin/dbus-daemon" sauid=101 hostname=? addr=? terminal=?'
[  307.645626] audit: type=1107 audit(1702480737.170:198): pid=759 uid=101 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal"  bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.13" mask="receive" pid=1787 label="snap.firefox.firefox" peer_pid=791 peer_label="unconfined"
[  312.964039] audit: type=1107 audit(1702480742.488:199): pid=759 uid=101 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal"  bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.13" mask="receive" pid=1787 label="snap.firefox.firefox" peer_pid=791 peer_label="unconfined"
[  368.747797] traps: hardinfo[3840] general protection fault ip:7f3dcee69b2e sp:7ffef9fd2830 error:0 in libgtk-x11-2.0.so.0.2400.33[7f3dcec64000+292000]
[  927.391109] audit: type=1400 audit(1702481357.122:200): apparmor="DENIED" operation="capable" class="cap" profile="/usr/lib/snapd/snap-confine" pid=4983 comm="snap-confine" capability=12  capname="net_admin"
[  927.391130] audit: type=1400 audit(1702481357.122:201): apparmor="DENIED" operation="capable" class="cap" profile="/usr/lib/snapd/snap-confine" pid=4983 comm="snap-confine" capability=38  capname="perfmon"
[ 1234.680084] usb 1-3: new full-speed USB device number 7 using xhci_hcd
[ 1234.831706] usb 1-3: New USB device found, idVendor=2341, idProduct=0043, bcdDevice= 0.01
[ 1234.831721] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 1234.831727] usb 1-3: Manufacturer: Arduino (www.arduino.cc)
[ 1234.831731] usb 1-3: SerialNumber: 851333231363510151E0
[ 1234.834596] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[ 1308.430606] usb 1-3: USB disconnect, device number 7
[ 1314.635205] usb 1-3: new full-speed USB device number 8 using xhci_hcd
[ 1314.787622] usb 1-3: New USB device found, idVendor=2341, idProduct=0043, bcdDevice= 0.01
[ 1314.787636] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 1314.787643] usb 1-3: Manufacturer: Arduino (www.arduino.cc)
[ 1314.787647] usb 1-3: SerialNumber: 851333231363510151E0
[ 1314.790599] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[ 1330.679212] usb 1-3: USB disconnect, device number 8
[ 1406.863237] audit: type=1400 audit(1702481836.565:202): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:255" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.863552] audit: type=1400 audit(1702481836.565:203): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:0" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.863655] audit: type=1400 audit(1702481836.565:204): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:0" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.863843] audit: type=1400 audit(1702481836.565:205): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:0" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.864007] audit: type=1400 audit(1702481836.565:206): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:0" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.865715] audit: type=1400 audit(1702481836.569:207): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:255" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.865905] audit: type=1400 audit(1702481836.569:208): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:254" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.866050] audit: type=1400 audit(1702481836.569:209): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:0" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.866228] audit: type=1400 audit(1702481836.569:210): apparmor="DENIED" operation="unlink" class="file" profile="snap.firefox.firefox" name="/dev/char/195:0" pid=5881 comm="glxtest" requested_mask="d" denied_mask="d" fsuid=1000 ouid=0
[ 1406.869479] audit: type=1107 audit(1702481836.573:211): pid=759 uid=101 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="ListNames" mask="send" name="org.freedesktop.DBus" pid=5881 label="snap.firefox.firefox" peer_label="unconfined"
That's dmesg output. I have selected the part where ttyAMC0 port appears.
Hi @pl_olov3. I'm going to ask you to run the dmesg command from the command line and post the output.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
  1. Open a terminal.
  2. Connect the Arduino board to your computer with the USB cable.
  3. Press and release the reset button on the Arduino board.
    The LED marked "L" on the board should now start pulsing. If it doesn't pulse, please reply here to let us know.
  4. Wait for the LED marked "L" on the board to stop pulsing.
  5. Type this command:
    sudo dmesg | tail --lines=20
  6. Press Enter
  7. If prompted for it, enter your Linux account password and press the Enter key.
  8. Click and drag the mouse to select all the output in the terminal window.
  9. Press Ctrl+Shift+C.
    This will copy the selected text to the clipboard.
  10. Open a forum reply here by clicking the "Reply" button.
  11. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
    Code tags icon on toolbar
  12. Press Ctrl+V.
    This will paste the output into the code block.
  13. Move the cursor outside of the code block markup before you add any additional text to your reply.
  14. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
"L" led is on when reset button is pressed. Releasing the button turn "L" led off. After double press "L" led starts to pulse.
[   44.437131] audit: type=1107 audit(1702486823.423:119): pid=770 uid=101 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/" interface="org.freedesktop.DBus.ObjectManager" member="GetManagedObjects" mask="send" name="org.bluez" pid=1910 label="snap.slack.slack" peer_pid=768 peer_label="unconfined"
[   44.505831] audit: type=1400 audit(1702486823.491:120): apparmor="DENIED" operation="open" class="file" profile="snap.slack.slack" name="/etc/vulkan/implicit_layer.d/" pid=2045 comm="slack" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[   46.238364] kauditd_printk_skb: 23 callbacks suppressed
[   46.238368] audit: type=1107 audit(1702486825.223:144): pid=770 uid=101 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal"  bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.login1.Manager" member="UserRemoved" name=":1.11" mask="receive" pid=1910 label="snap.slack.slack" peer_pid=801 peer_label="unconfined"
[   46.238396] audit: type=1107 audit(1702486825.223:145): pid=770 uid=101 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal"  bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.login1.Manager" member="UserRemoved" name=":1.11" mask="receive" pid=1910 label="snap.slack.slack" peer_pid=801 peer_label="unconfined"
[   49.259126] audit: type=1326 audit(1702486828.243:146): auid=1000 uid=1000 gid=1000 ses=4 subj=snap.slack.slack pid=1910 comm="slack" exe="/snap/slack/126/usr/lib/slack/slack" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7f9910763539 code=0x50000
[   49.597342] audit: type=1326 audit(1702486828.583:147): auid=1000 uid=1000 gid=1000 ses=4 subj=snap.slack.slack pid=1910 comm="slack" exe="/snap/slack/126/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7f99107593b7 code=0x50000
[   56.431414] audit: type=1326 audit(1702486835.415:148): auid=1000 uid=1000 gid=1000 ses=4 subj=snap.slack.slack pid=1910 comm="slack" exe="/snap/slack/126/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7f99107593b7 code=0x50000
[  132.308651] usb 1-3: new full-speed USB device number 5 using xhci_hcd
[  132.458715] usb 1-3: New USB device found, idVendor=2a03, idProduct=0036, bcdDevice= 0.01
[  132.458730] usb 1-3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[  132.458736] usb 1-3: Product: Arduino Leonardo
[  132.458740] usb 1-3: Manufacturer: Arduino srl
[  132.553369] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[  132.553440] usbcore: registered new interface driver cdc_acm
[  132.553446] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  140.071181] usb 1-3: USB disconnect, device number 5
OK, that was useful.
This is somewhat unexpected for a Leonardo because that specific board usually only requires a single press of the reset button to go into the mode where the LED pulses. However, there is an alternative bootloader that requires a double press and it might well be that your board has that bootloader, so the single/double reset discrepancy is not really significant for this discussion so long as you are able to put the board to go into this mode via one procedure or another.
The tricky thing about the boards with native USB capability like your board is the USB code that creates the CDC serial port is running on the same microcontroller as your sketch. This means your sketch code can break the USB code, or stop it from running. When that happens, the board no longer produces a serial port.
This can be unexpected to those who previously mainly worked with the boards like Uno and Mega with a dedicated USB chip that can never be affected by the sketch code.
The missing port makes it so you can't upload normally any more. However, the situation is really not so bad because there is an independent program called the bootloader in a separate section of memory from your sketch, and that program has its own USB CDC code. So even if the sketch is completely broken, you only need to activate the bootloader to get a port back and be able to upload. My interpretation of your dmesg output is that the board did produce a port as expected when you activated the bootloader via the double reset, here:
Then when the bootloader timed out and the sketch application ran again, the port produced by the bootloader disappeared (which is expected), but then the sketch application did not produce a port (which it would under normal operating conditions):
So the solution should be to upload to the board while the bootloader is activated. You need to get the timing right when doing this. If you press the reset button too early, the bootloader will have already timed out by the time the upload starts. The tricky thing is that when you press the "Upload" button in Arduino IDE, it first compiles your sketch before starting the actual upload. So you need to wait until after the compilation finishes before pressing the reset button.
Try this:
  1. Select Sketch > Upload from the Arduino IDE menus.
  2. Watch the black "Output" panel at the bottom of the Arduino IDE window until you see something like this:
    Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
    Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables.
    Maximum is 2048 bytes.
  3. Immediately press and release the reset button on the Arduino board twice quickly.
The upload should now finish successfully.
If you find that the board still doesn't produce a port while the bootloader is not activated, the problem may be caused by your sketch code. You can verify this by uploading a simple sketch like the one from File > Examples > 01.Basics > BareMinimum in the Arduino IDE menus. If the uploads work normally after uploading that sketch, but not after uploading the previous sketch you were using, then you will know the issue is caused by that other sketch code.
It's not the first time that I have heard that a Leonardo requires a double tap reset; @Grumpy_Mike has mentioned it as well. My (official) Leonardo reacts on a single tap.
Do you have info about that alternative bootloader? Was there ever an official 'alternative' one? For a clone I can imagine that it's the case, it might be a (modified) Pro Micro bootloader.
My knowledge of it comes from this:
https://learn.sparkfun.com/tutorials/pro-micro--fio-v3-hookup-guide/troubleshooting-and-faq#ts-reset
We ship the Pro Micro with a modified version of the Arduino Leonardo bootloader, with one major enhancement. When a Leonardo (or any device using the "stock" bootloader) is externally reset, it goes back into the bootloader...and waits there eight seconds before it starts running the sketch. For some embedded projects, waiting eight seconds before a program runs isn't acceptable, so we modified the bootloader run time.
When a Pro Micro is externally reset (by pulling the RST pin low), it'll only briefly (<750ms) start the bootloader before continuing on to the sketch. If you need the bootloader to run longer, resetting twice quickly will get the Pro Micro to enter bootloader mode for eight seconds.
I believe the source code for the variant of the Caterina bootloader shipped on the SparkFun boards is here:
But I don't know whether SparkFun was the originator of this innovation or if they only used the enhanced bootloader created by someone else. Unfortunately there isn't any meaningful commit history for the files in that repo.
It would be interesting to understand whether this was the origin of the double reset that is now a common convention on all modern boards where giving the user the ability to put the board into a "boot mode" is useful. It would also be interesting to know the origin of the modern approach of making the mode persistent, without a timeout.
Just for the record I have two Leonardo boards, both official and depending on what code I have loaded a single click is not always sufficient. The sort of code to cause that requirement is not obvious. Sometimes it is a clear error I have made and other times it just needs one almost at random. I have not changed the boot loader since I got them, and these were early acquired, within about a year of the board's first release.
I do run the latest 1.x IDE and I use a Mac running MacOS Moajve which I do know is old, but is the latest OS that will allow me the use of about four vital pieces of software (for me) which have no satisfactory equivalent on later OS releases.
I have given this advice on a number of occasions on the forum and sometimes it appears to be a solution.
My official Leonardo purchased a year ago, official Arduino Micros from 2020, and several clone Pro Micros circa 2014 have the same behavior regardless of whether I do a single or a double reset.
The only ATmega32U4-based boards I have that require a double reset are official SparkFun 3.3V/8Mhz Pro Micros purchased in 2021.
Out of curiosity, how do they identify themselves to the operating system? As SparkFun Pro Micro or as Arduino Leonardo. This is after a reset of both an official Leonardo (single tap) and of an official Pro Micro (double tap).
I think that at run time you might see a difference; mine identifies itself as a SparkFun Pro Micro but that is, to my knowledge, because I have the SparkFun board package installed and compile for a Pro Micro (8MHz/3.3V).
FYI
I have an Arduino Micro from what's next (formerly arduino.org AFAIK) that behaves like my Pro Micro (needs double tap reset to invoke bootloader); it does identify itself as an Arduino Micro.
I bought several over the course of a few years and from different eBay sellers and every one identified as Leonardo.
Your solution worked! Thanks.
You are welcome. I'm glad it is working now. It is fairly common to experience this sort of state when developing sketches for "native USB" boards like the Leonardo. In some cases it can be the expected result of the code (e.g., putting the microcontroller to sleep). In other cases it can be the unexpected result of a bug (e.g., a divide by zero crashing the processor).
So knowing this technique for being able to accomplish an upload even when the sketch application does not produce a port is very helpful.
Although it can still sometimes be difficult to track down the cause in the case where the state is caused a bug, at least now you will always be able to easily recover the board to a functional state once more.
Regards,
Per
Saved me ... charge-only-cable ... how silly is that??
Christoph
help me, arduino ide not showing any ports
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 174f:2426 Syntek Integrated Camera
Bus 001 Device 003: ID 0cf3:e500 Qualcomm Atheros Communications
Bus 001 Device 005: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Bus 001 Device 002: ID 248a:8514 Maxxter Wireless Receiver
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and dmesg
[    0.000000] microcode: updated early: 0xb4 -> 0xf4, date = 2023-02-23
[    0.000000] Linux version 6.5.0-14-generic (buildd@lcy02-amd64-110) (x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #14~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Mon Nov 20 18:15:30 UTC 2 (Ubuntu 6.5.0-14.14~22.04.1-generic 6.5.3)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.5.0-14-generic root=UUID=49f117eb-48c0-4e1c-9637-5f174f964b2a ro quiet splash
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040400000-0x0000000073c4bfff] usable
[    0.000000] BIOS-e820: [mem 0x0000000073c4c000-0x0000000073c4cfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000073c4d000-0x0000000073c4dfff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000073c4e000-0x0000000075388fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000075389000-0x0000000075c88fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000075c89000-0x000000008be9efff] usable
[    0.000000] BIOS-e820: [mem 0x000000008be9f000-0x000000008c09efff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008c09f000-0x000000008c88efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008c88f000-0x000000008cf7efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008cf7f000-0x000000008cffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008cfff000-0x000000008cffffff] usable
[    0.000000] BIOS-e820: [mem 0x000000008d000000-0x000000008fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000fe7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffa00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000036effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.5 by INSYDE Corp.
[    0.000000] efi: ACPI 2.0=0x8cffe014 SMBIOS=0x8c113000 SMBIOS 3.0=0x8c111000 ESRT=0x8c10f758
[    0.000000] efi: Remove mem42: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[    0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[    0.000000] efi: Remove mem43: MMIO range=[0xfd000000-0xfe7fffff] (24MB) from e820 map
[    0.000000] e820: remove [mem 0xfd000000-0xfe7fffff] reserved
[    0.000000] efi: Not removing mem44: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem45: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem46: MMIO range=[0xfed10000-0xfed19fff] (40KB) from e820 map
[    0.000000] efi: Not removing mem47: MMIO range=[0xfed84000-0xfed84fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem48: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem49: MMIO range=[0xffa00000-0xffffffff] (6MB) from e820 map
[    0.000000] e820: remove [mem 0xffa00000-0xffffffff] reserved
[    0.000000] secureboot: Secure boot disabled
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: LENOVO 81GC/LNVNB161216, BIOS 8LCN23WW 06/10/2019
[    0.000000] tsc: Detected 2000.000 MHz processor
[    0.000000] tsc: Detected 1999.968 MHz TSC
[    0.000735] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000741] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000761] last_pfn = 0x36f000 max_arch_pfn = 0x400000000
[    0.000768] MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
[    0.000771] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001623] last_pfn = 0x8d000 max_arch_pfn = 0x400000000
[    0.014833] esrt: Reserving ESRT space from 0x000000008c10f758 to 0x000000008c10f7e0.
[    0.014846] Using GB pages for direct mapping
[    0.016159] secureboot: Secure boot disabled
[    0.016161] RAMDISK: [mem 0x2f9b5000-0x33cd1fff]
[    0.016182] ACPI: Early table checksum verification disabled
[    0.016186] ACPI: RSDP 0x000000008CFFE014 000024 (v02 LENOVO)
[    0.016193] ACPI: XSDT 0x000000008CFC4188 00011C (v01 LENOVO CB-01    00000001      01000013)
[    0.016202] ACPI: FACP 0x000000008CFEC000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016211] ACPI: DSDT 0x000000008CFCB000 01D6AA (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016217] ACPI: FACS 0x000000008CF59000 000040
[    0.016222] ACPI: UEFI 0x000000008CFFD000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016227] ACPI: UEFI 0x000000008CFFC000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016232] ACPI: MSDM 0x000000008CFFB000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016237] ACPI: SSDT 0x000000008CFF7000 00312B (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016242] ACPI: SSDT 0x000000008CFF3000 00398E (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016248] ACPI: SSDT 0x000000008CFF2000 000064 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016253] ACPI: SSDT 0x000000008CFF1000 000A2A (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016258] ACPI: ASF! 0x000000008CFF0000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016264] ACPI: ASPT 0x000000008CFEF000 000034 (v07 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016269] ACPI: BOOT 0x000000008CFEE000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016274] ACPI: DBGP 0x000000008CFED000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016279] ACPI: HPET 0x000000008CFEB000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016284] ACPI: APIC 0x000000008CFEA000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016289] ACPI: MCFG 0x000000008CFE9000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016294] ACPI: SSDT 0x000000008CFCA000 000517 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016300] ACPI: SSDT 0x000000008CFC8000 0011E1 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016305] ACPI: LPIT 0x000000008CFC7000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016310] ACPI: WSMT 0x000000008CFC6000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016315] ACPI: SSDT 0x000000008CFC5000 00029F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016320] ACPI: SSDT 0x000000008CFC3000 000346 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016325] ACPI: SSDT 0x000000008CFBF000 003002 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016330] ACPI: SSDT 0x000000008CFBE000 00051E (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016335] ACPI: DBGP 0x000000008CFBD000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016341] ACPI: DBG2 0x000000008CFBC000 000054 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016346] ACPI: SSDT 0x000000008CFBA000 0012E6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016351] ACPI: SSDT 0x000000008CFB8000 0017AE (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016356] ACPI: SSDT 0x000000008CFB4000 003B47 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016361] ACPI: DMAR 0x000000008CFB3000 0000A8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016366] ACPI: FPDT 0x000000008CFB2000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016371] ACPI: BGRT 0x000000008CFB1000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.016376] ACPI: Reserving FACP table memory at [mem 0x8cfec000-0x8cfec10b]
[    0.016378] ACPI: Reserving DSDT table memory at [mem 0x8cfcb000-0x8cfe86a9]
[    0.016380] ACPI: Reserving FACS table memory at [mem 0x8cf59000-0x8cf5903f]
[    0.016382] ACPI: Reserving UEFI table memory at [mem 0x8cffd000-0x8cffd235]
[    0.016383] ACPI: Reserving UEFI table memory at [mem 0x8cffc000-0x8cffc041]
[    0.016384] ACPI: Reserving MSDM table memory at [mem 0x8cffb000-0x8cffb054]
[    0.016386] ACPI: Reserving SSDT table memory at [mem 0x8cff7000-0x8cffa12a]
[    0.016387] ACPI: Reserving SSDT table memory at [mem 0x8cff3000-0x8cff698d]
[    0.016389] ACPI: Reserving SSDT table memory at [mem 0x8cff2000-0x8cff2063]
[    0.016390] ACPI: Reserving SSDT table memory at [mem 0x8cff1000-0x8cff1a29]
[    0.016392] ACPI: Reserving ASF! table memory at [mem 0x8cff0000-0x8cff00a4]
[    0.016393] ACPI: Reserving ASPT table memory at [mem 0x8cfef000-0x8cfef033]
[    0.016395] ACPI: Reserving BOOT table memory at [mem 0x8cfee000-0x8cfee027]
[    0.016396] ACPI: Reserving DBGP table memory at [mem 0x8cfed000-0x8cfed033]
[    0.016398] ACPI: Reserving HPET table memory at [mem 0x8cfeb000-0x8cfeb037]
[    0.016399] ACPI: Reserving APIC table memory at [mem 0x8cfea000-0x8cfea12b]
[    0.016401] ACPI: Reserving MCFG table memory at [mem 0x8cfe9000-0x8cfe903b]
[    0.016402] ACPI: Reserving SSDT table memory at [mem 0x8cfca000-0x8cfca516]
[    0.016404] ACPI: Reserving SSDT table memory at [mem 0x8cfc8000-0x8cfc91e0]
[    0.016405] ACPI: Reserving LPIT table memory at [mem 0x8cfc7000-0x8cfc7093]
[    0.016407] ACPI: Reserving WSMT table memory at [mem 0x8cfc6000-0x8cfc6027]
[    0.016408] ACPI: Reserving SSDT table memory at [mem 0x8cfc5000-0x8cfc529e]
[    0.016410] ACPI: Reserving SSDT table memory at [mem 0x8cfc3000-0x8cfc3345]
[    0.016411] ACPI: Reserving SSDT table memory at [mem 0x8cfbf000-0x8cfc2001]
[    0.016413] ACPI: Reserving SSDT table memory at [mem 0x8cfbe000-0x8cfbe51d]
[    0.016414] ACPI: Reserving DBGP table memory at [mem 0x8cfbd000-0x8cfbd033]
[    0.016416] ACPI: Reserving DBG2 table memory at [mem 0x8cfbc000-0x8cfbc053]
[    0.016417] ACPI: Reserving SSDT table memory at [mem 0x8cfba000-0x8cfbb2e5]
[    0.016419] ACPI: Reserving SSDT table memory at [mem 0x8cfb8000-0x8cfb97ad]
[    0.016420] ACPI: Reserving SSDT table memory at [mem 0x8cfb4000-0x8cfb7b46]
[    0.016422] ACPI: Reserving DMAR table memory at [mem 0x8cfb3000-0x8cfb30a7]
[    0.016423] ACPI: Reserving FPDT table memory at [mem 0x8cfb2000-0x8cfb2043]
[    0.016425] ACPI: Reserving BGRT table memory at [mem 0x8cfb1000-0x8cfb1037]
[    0.016785] No NUMA configuration found
[    0.016787] Faking a node at [mem 0x0000000000000000-0x000000036effffff]
[    0.016805] NODE_DATA(0) allocated [mem 0x36efd2000-0x36effcfff]
[    0.017082] Zone ranges:
[    0.017085]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.017090]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.017093]   Normal   [mem 0x0000000100000000-0x000000036effffff]
[    0.017096]   Device   empty
[    0.017098] Movable zone start for each node
[    0.017101] Early memory node ranges
[    0.017102]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.017105]   node   0: [mem 0x0000000000059000-0x000000000009dfff]
[    0.017107]   node   0: [mem 0x0000000000100000-0x000000003fffffff]
[    0.017109]   node   0: [mem 0x0000000040400000-0x0000000073c4bfff]
[    0.017110]   node   0: [mem 0x0000000073c4e000-0x0000000075388fff]
[    0.017112]   node   0: [mem 0x0000000075c89000-0x000000008be9efff]
[    0.017113]   node   0: [mem 0x000000008cfff000-0x000000008cffffff]
[    0.017115]   node   0: [mem 0x0000000100000000-0x000000036effffff]
[    0.017118] Initmem setup node 0 [mem 0x0000000000001000-0x000000036effffff]
[    0.017124] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.017127] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.017158] On node 0, zone DMA: 98 pages in unavailable ranges
[    0.020888] On node 0, zone DMA32: 1024 pages in unavailable ranges
[    0.020950] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.021705] On node 0, zone DMA32: 2304 pages in unavailable ranges
[    0.021771] On node 0, zone DMA32: 4448 pages in unavailable ranges
[    0.042609] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.042671] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.042683] Reserving Intel graphics memory at [mem 0x8e000000-0x8fffffff]
[    0.042929] ACPI: PM-Timer IO Port: 0x1808
[    0.042941] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.042944] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.042946] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.042947] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.042948] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.042950] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.042951] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.042953] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.042954] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.042955] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.042957] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.042958] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.042959] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.042961] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.042962] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.042964] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.042991] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.042997] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.043000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.043008] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.043010] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.043020] e820: update [mem 0x7c2ad000-0x7c3a0fff] usable ==> reserved
[    0.043043] TSC deadline timer available
[    0.043045] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.043081] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.043085] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.043088] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.043091] PM: hibernation: Registered nosave memory: [mem 0x40000000-0x403fffff]
[    0.043095] PM: hibernation: Registered nosave memory: [mem 0x73c4c000-0x73c4cfff]
[    0.043096] PM: hibernation: Registered nosave memory: [mem 0x73c4d000-0x73c4dfff]
[    0.043099] PM: hibernation: Registered nosave memory: [mem 0x75389000-0x75c88fff]
[    0.043102] PM: hibernation: Registered nosave memory: [mem 0x7c2ad000-0x7c3a0fff]
[    0.043105] PM: hibernation: Registered nosave memory: [mem 0x8be9f000-0x8c09efff]
[    0.043107] PM: hibernation: Registered nosave memory: [mem 0x8c09f000-0x8c88efff]
[    0.043108] PM: hibernation: Registered nosave memory: [mem 0x8c88f000-0x8cf7efff]
[    0.043109] PM: hibernation: Registered nosave memory: [mem 0x8cf7f000-0x8cffefff]
[    0.043113] PM: hibernation: Registered nosave memory: [mem 0x8d000000-0x8fffffff]
[    0.043114] PM: hibernation: Registered nosave memory: [mem 0x90000000-0xfebfffff]
[    0.043115] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.043116] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.043118] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.043119] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed0ffff]
[    0.043120] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.043122] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.043123] PM: hibernation: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.043124] PM: hibernation: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.043126] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.043127] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[    0.043130] [mem 0x90000000-0xfebfffff] available for PCI devices
[    0.043132] Booting paravirtualized kernel on bare hardware
[    0.043135] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.043146] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.043669] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[    0.043682] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[    0.043686] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.043749] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5.0-14-generic root=UUID=49f117eb-48c0-4e1c-9637-5f174f964b2a ro quiet splash
[    0.043851] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.5.0-14-generic", will be passed to user space.
[    0.043919] random: crng init done
[    0.045942] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.046978] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.047163] Fallback order for Node 0: 0
[    0.047168] Built 1 zonelists, mobility grouping on.  Total pages: 3072535
[    0.047170] Policy zone: Normal
[    0.047179] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.047195] software IO TLB: area num 8.
[    0.105330] Memory: 12002308K/12485864K available (20480K kernel code, 4265K rwdata, 13180K rodata, 4792K init, 17396K bss, 483296K reserved, 0K cma-reserved)
[    0.105727] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.105745] Kernel/User page tables isolation: enabled
[    0.105797] ftrace: allocating 55226 entries in 216 pages
[    0.121281] ftrace: allocated 216 pages with 4 groups
[    0.122464] Dynamic Preempt: voluntary
[    0.122527] rcu: Preemptible hierarchical RCU implementation.
[    0.122528] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[    0.122531] 	Trampoline variant of Tasks RCU enabled.
[    0.122532] 	Rude variant of Tasks RCU enabled.
[    0.122533] 	Tracing variant of Tasks RCU enabled.
[    0.122534] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.122535] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.127468] NR_IRQS: 524544, nr_irqs: 2048, preallocated irqs: 16
[    0.127727] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.127925] Console: colour dummy device 80x25
[    0.127929] printk: console [tty0] enabled
[    0.128019] ACPI: Core revision 20230331
[    0.128362] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.128364] APIC: Switch to symmetric I/O mode setup
[    0.128367] DMAR: Host address width 39
[    0.128369] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.128381] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.128386] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.128392] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.128395] DMAR: RMRR base: 0x0000008c766000 end: 0x0000008c785fff
[    0.128398] DMAR: RMRR base: 0x0000008d800000 end: 0x0000008fffffff
[    0.128402] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.128404] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.128406] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.130157] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.130161] x2apic enabled
[    0.130173] Switched APIC routing to cluster x2apic.
[    0.133963] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x39a8208cdd2, max_idle_ns: 881590748921 ns
[    0.133973] Calibrating delay loop (skipped), value calculated using timer frequency.. 3999.93 BogoMIPS (lpj=7999872)
[    0.134012] x86/cpu: SGX disabled by BIOS.
[    0.134026] CPU0: Thermal monitoring enabled (TM1)
[    0.134101] process: using mwait in idle threads
[    0.134106] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.134109] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.134116] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.134119] Spectre V2 : Mitigation: IBRS
[    0.134121] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.134122] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.134124] RETBleed: Mitigation: IBRS
[    0.134127] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.134129] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.134132] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.134145] MDS: Mitigation: Clear CPU buffers
[    0.134147] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.134155] SRBDS: Mitigation: Microcode
[    0.134167] GDS: Mitigation: Microcode
[    0.134177] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.134180] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.134182] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.134185] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.134187] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.134190] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.134193] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.134196] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.134199] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.137968] Freeing SMP alternatives memory: 44K
[    0.137968] pid_max: default: 32768 minimum: 301
[    0.137968] LSM: initializing lsm=lockdown,capability,landlock,yama,apparmor,integrity
[    0.137968] landlock: Up and running.
[    0.137968] Yama: becoming mindful.
[    0.137968] AppArmor: AppArmor initialized
[    0.137968] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.137968] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.137968] smpboot: CPU0: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz (family: 0x6, model: 0x8e, stepping: 0xa)
[    0.137968] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.137968] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.137968] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.137968] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.137968] ... version:                4
[    0.137968] ... bit width:              48
[    0.137968] ... generic registers:      4
[    0.137968] ... value mask:             0000ffffffffffff
[    0.137968] ... max period:             00007fffffffffff
[    0.137968] ... fixed-purpose events:   3
[    0.137968] ... event mask:             000000070000000f
[    0.137968] signal: max sigframe size: 2032
[    0.137968] Estimated ratio of average max frequency by base frequency (times 1024): 1894
[    0.137968] rcu: Hierarchical SRCU implementation.
[    0.137968] rcu: 	Max phase no-delay instances is 1000.
[    0.137968] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.137968] smp: Bringing up secondary CPUs ...
[    0.137968] smpboot: x86: Booting SMP configuration:
[    0.137968] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.143474] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.143474] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.143474] smp: Brought up 1 node, 8 CPUs
[    0.143474] smpboot: Max logical packages: 1
[    0.143474] smpboot: Total of 8 processors activated (31999.48 BogoMIPS)
[    0.146526] devtmpfs: initialized
[    0.146526] x86/mm: Memory block size: 128MB
[    0.148221] ACPI: PM: Registering ACPI NVS region [mem 0x73c4c000-0x73c4cfff] (4096 bytes)
[    0.148221] ACPI: PM: Registering ACPI NVS region [mem 0x8c88f000-0x8cf7efff] (7274496 bytes)
[    0.148221] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.148221] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.148221] pinctrl core: initialized pinctrl subsystem
[    0.148221] PM: RTC time: 02:41:43, date: 2024-02-20
[    0.150487] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.150973] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.151160] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.151354] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.151372] audit: initializing netlink subsys (disabled)
[    0.151406] audit: type=2000 audit(1708396903.016:1): state=initialized audit_enabled=0 res=1
[    0.151406] thermal_sys: Registered thermal governor 'fair_share'
[    0.151406] thermal_sys: Registered thermal governor 'bang_bang'
[    0.151406] thermal_sys: Registered thermal governor 'step_wise'
[    0.151406] thermal_sys: Registered thermal governor 'user_space'
[    0.151406] thermal_sys: Registered thermal governor 'power_allocator'
[    0.151406] EISA bus registered
[    0.151406] cpuidle: using governor ladder
[    0.151406] cpuidle: using governor menu
[    0.151406] Simple Boot Flag at 0x44 set to 0x1
[    0.151406] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.151406] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.151406] PCI: not using MMCONFIG
[    0.151406] PCI: Using configuration type 1 for base access
[    0.151406] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.151406] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.151406] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.151406] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.151406] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.151406] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.151406] fbcon: Taking over console
[    0.151406] ACPI: Added _OSI(Module Device)
[    0.151406] ACPI: Added _OSI(Processor Device)
[    0.151406] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.151406] ACPI: Added _OSI(Processor Aggregator Device)
[    0.230218] ACPI: 14 ACPI AML tables successfully acquired and loaded
[    0.235675] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.243233] ACPI: Dynamic OEM Table Load:
[    0.243255] ACPI: SSDT 0xFFFF9C33C1007800 0005CD (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    0.247676] ACPI: \_PR_.PR00: _OSC native thermal LVT Acked
[    0.251135] ACPI: Dynamic OEM Table Load:
[    0.251152] ACPI: SSDT 0xFFFF9C33C158E800 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    0.255053] ACPI: Dynamic OEM Table Load:
[    0.255071] ACPI: SSDT 0xFFFF9C33C0167000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    0.259895] ACPI: Dynamic OEM Table Load:
[    0.259909] ACPI: SSDT 0xFFFF9C33C1588C00 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
[    0.269937] ACPI: EC: EC started
[    0.269940] ACPI: EC: interrupt blocked
[    0.270190] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.270195] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC used to handle transactions
[    0.270199] ACPI: Interpreter enabled
[    0.270280] ACPI: PM: (supports S0 S3 S4 S5)
[    0.270282] ACPI: Using IOAPIC for interrupt routing
[    0.274196] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.280997] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved as ACPI motherboard resource
[    0.281020] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.281022] PCI: Using E820 reservations for host bridge windows
[    0.283491] ACPI: Enabled 9 GPEs in block 00 to 7F
[    0.504344] ACPI: \_SB_.PCI0.RP01.PC01: New power resource
[    0.534344] acpi ABCD0000:00: ACPI dock station (docks/bays count: 1)
[    0.539564] ACPI: \_TZ_.FN00: New power resource
[    0.539767] ACPI: \_TZ_.FN01: New power resource
[    0.539966] ACPI: \_TZ_.FN02: New power resource
[    0.540160] ACPI: \_TZ_.FN03: New power resource
[    0.540357] ACPI: \_TZ_.FN04: New power resource
[    0.543326] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.543340] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.545449] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    0.550545] PCI host bridge to bus 0000:00
[    0.550550] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.550555] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.550560] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[    0.550563] pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
[    0.550566] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.550570] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.550759] pci 0000:00:00.0: [8086:5914] type 00 class 0x060000
[    0.550897] pci 0000:00:02.0: [8086:5917] type 00 class 0x030000
[    0.550913] pci 0000:00:02.0: reg 0x10: [mem 0xb2000000-0xb2ffffff 64bit]
[    0.550924] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.550932] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
[    0.550961] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.550967] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.551382] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.551399] pci 0000:00:04.0: reg 0x10: [mem 0xb4520000-0xb4527fff 64bit]
[    0.552020] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[    0.552043] pci 0000:00:14.0: reg 0x10: [mem 0xb4510000-0xb451ffff 64bit]
[    0.552123] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.553457] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[    0.553481] pci 0000:00:14.2: reg 0x10: [mem 0xb4532000-0xb4532fff 64bit]
[    0.553789] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
[    0.553983] pci 0000:00:15.0: reg 0x10: [mem 0xb4533000-0xb4533fff 64bit]
[    0.555363] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[    0.555390] pci 0000:00:16.0: reg 0x10: [mem 0xb4534000-0xb4534fff 64bit]
[    0.555476] pci 0000:00:16.0: PME# supported from D3hot
[    0.556443] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
[    0.556462] pci 0000:00:17.0: reg 0x10: [mem 0xb4530000-0xb4531fff]
[    0.556473] pci 0000:00:17.0: reg 0x14: [mem 0xb4537000-0xb45370ff]
[    0.556483] pci 0000:00:17.0: reg 0x18: [io  0x4080-0x4087]
[    0.556494] pci 0000:00:17.0: reg 0x1c: [io  0x4088-0x408b]
[    0.556504] pci 0000:00:17.0: reg 0x20: [io  0x4060-0x407f]
[    0.556514] pci 0000:00:17.0: reg 0x24: [mem 0xb4535000-0xb45357ff]
[    0.556569] pci 0000:00:17.0: PME# supported from D3hot
[    0.557184] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[    0.557283] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.558561] pci 0000:00:1c.5: [8086:9d15] type 01 class 0x060400
[    0.558680] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.559919] pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400
[    0.560019] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.561259] pci 0000:00:1f.0: [8086:9d4e] type 00 class 0x060100
[    0.561916] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[    0.561936] pci 0000:00:1f.2: reg 0x10: [mem 0xb452c000-0xb452ffff]
[    0.562509] pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040300
[    0.562539] pci 0000:00:1f.3: reg 0x10: [mem 0xb4528000-0xb452bfff 64bit]
[    0.562577] pci 0000:00:1f.3: reg 0x20: [mem 0xb4500000-0xb450ffff 64bit]
[    0.562641] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.564306] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[    0.564365] pci 0000:00:1f.4: reg 0x10: [mem 0xb4536000-0xb45360ff 64bit]
[    0.564437] pci 0000:00:1f.4: reg 0x20: [io  0x4040-0x405f]
[    0.565077] pci 0000:01:00.0: [10de:1c8d] type 00 class 0x030000
[    0.565097] pci 0000:01:00.0: reg 0x10: [mem 0xb3000000-0xb3ffffff]
[    0.565113] pci 0000:01:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.565129] pci 0000:01:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
[    0.565140] pci 0000:01:00.0: reg 0x24: [io  0x3000-0x307f]
[    0.565152] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    0.565182] pci 0000:01:00.0: Enabling HDA controller
[    0.565322] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:1c.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.565937] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
[    0.565957] pci 0000:01:00.1: reg 0x10: [mem 0xb4000000-0xb4003fff]
[    0.566181] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.566187] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    0.566192] pci 0000:00:1c.0:   bridge window [mem 0xb3000000-0xb40fffff]
[    0.566198] pci 0000:00:1c.0:   bridge window [mem 0xa0000000-0xb1ffffff 64bit pref]
[    0.566460] pci 0000:02:00.0: [168c:0042] type 00 class 0x028000
[    0.566512] pci 0000:02:00.0: reg 0x10: [mem 0xb4200000-0xb43fffff 64bit]
[    0.566893] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.567568] pci 0000:00:1c.5: PCI bridge to [bus 02]
[    0.567575] pci 0000:00:1c.5:   bridge window [mem 0xb4200000-0xb43fffff]
[    0.567664] pci 0000:03:00.0: [2646:5017] type 00 class 0x010802
[    0.567689] pci 0000:03:00.0: reg 0x10: [mem 0xb4400000-0xb4403fff 64bit]
[    0.567905] pci 0000:03:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:1d.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[    0.568062] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    0.568068] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.597684] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[    0.597813] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    0.597937] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[    0.598071] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[    0.598196] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[    0.598319] ACPI: PCI: Interrupt link LNKF configured for IRQ 11
[    0.598444] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[    0.598569] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[    0.606004] ACPI Warning: GPE type mismatch (level/edge) (20230331/evxface-791)
[    0.606032] ACPI: EC: interrupt unblocked
[    0.606033] ACPI: EC: event unblocked
[    0.606039] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.606041] ACPI: EC: GPE=0x50
[    0.606044] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC initialization complete
[    0.606048] ACPI: \_SB_.PCI0.LPCB.H_EC: EC: Used to handle transactions and events
[    0.606187] iommu: Default domain type: Translated
[    0.606187] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.606282] SCSI subsystem initialized
[    0.606293] libata version 3.00 loaded.
[    0.606293] ACPI: bus type USB registered
[    0.606293] usbcore: registered new interface driver usbfs
[    0.606293] usbcore: registered new interface driver hub
[    0.606293] usbcore: registered new device driver usb
[    0.606293] pps_core: LinuxPPS API ver. 1 registered
[    0.606293] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.606293] PTP clock support registered
[    0.606293] EDAC MC: Ver: 3.0.0
[    0.606585] efivars: Registered efivars operations
[    0.606585] NetLabel: Initializing
[    0.606585] NetLabel:  domain hash size = 128
[    0.606585] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.606585] NetLabel:  unlabeled traffic allowed by default
[    0.606585] mctp: management component transport protocol core
[    0.606585] NET: Registered PF_MCTP protocol family
[    0.606585] PCI: Using ACPI for IRQ routing
[    0.636439] PCI: pci_cache_line_size set to 64 bytes
[    0.636821] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.636824] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.636827] e820: reserve RAM buffer [mem 0x73c4c000-0x73ffffff]
[    0.636830] e820: reserve RAM buffer [mem 0x75389000-0x77ffffff]
[    0.636832] e820: reserve RAM buffer [mem 0x7c2ad000-0x7fffffff]
[    0.636834] e820: reserve RAM buffer [mem 0x8be9f000-0x8bffffff]
[    0.636836] e820: reserve RAM buffer [mem 0x8d000000-0x8fffffff]
[    0.636838] e820: reserve RAM buffer [mem 0x36f000000-0x36fffffff]
[    0.636920] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.636920] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.636920] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.636920] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.636920] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.636920] vgaarb: loaded
[    0.639516] clocksource: Switched to clocksource tsc-early
[    0.659243] VFS: Disk quotas dquot_6.6.0
[    0.659267] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.659490] AppArmor: AppArmor Filesystem Enabled
[    0.659583] pnp: PnP ACPI init
[    0.659752] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[    0.660031] system 00:01: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.660037] system 00:01: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.660041] system 00:01: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.660044] system 00:01: [mem 0xfe000000-0xfe01ffff] has been reserved
[    0.660047] system 00:01: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.660050] system 00:01: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.660053] system 00:01: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.660676] system 00:02: [io  0x2000-0x20fe] has been reserved
[    0.686864] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.686870] system 00:03: [io  0xffff] has been reserved
[    0.686874] system 00:03: [io  0xffff] has been reserved
[    0.686877] system 00:03: [io  0xffff] has been reserved
[    0.686880] system 00:03: [io  0x1800-0x18fe] has been reserved
[    0.686883] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.687168] system 00:05: [io  0x1854-0x1857] has been reserved
[    0.690164] system 00:07: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.690169] system 00:07: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.690173] system 00:07: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.691515] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.691520] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.691523] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.691526] system 00:08: [mem 0xe0000000-0xefffffff] has been reserved
[    0.691530] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.691533] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.691537] system 00:08: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.691540] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[    0.691543] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.691547] system 00:08: [mem 0x90000000-0x9001ffff] has been reserved
[    0.692792] pnp: PnP ACPI: found 9 devices
[    0.699702] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.699812] NET: Registered PF_INET protocol family
[    0.700042] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.704968] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.705022] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.705147] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.705488] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.705877] TCP: Hash tables configured (established 131072 bind 65536)
[    0.706028] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.706101] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.706172] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.706265] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.706283] NET: Registered PF_XDP protocol family
[    0.706289] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.706310] pci 0000:01:00.0: BAR 6: assigned [mem 0xb4080000-0xb40fffff pref]
[    0.706315] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.706319] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    0.706325] pci 0000:00:1c.0:   bridge window [mem 0xb3000000-0xb40fffff]
[    0.706330] pci 0000:00:1c.0:   bridge window [mem 0xa0000000-0xb1ffffff 64bit pref]
[    0.706337] pci 0000:00:1c.5: PCI bridge to [bus 02]
[    0.706344] pci 0000:00:1c.5:   bridge window [mem 0xb4200000-0xb43fffff]
[    0.706353] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    0.706358] pci 0000:00:1d.0:   bridge window [mem 0xb4400000-0xb44fffff]
[    0.706366] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.706370] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.706373] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000dffff window]
[    0.706376] pci_bus 0000:00: resource 7 [mem 0x90000000-0xdfffffff window]
[    0.706379] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[    0.706382] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.706385] pci_bus 0000:01: resource 1 [mem 0xb3000000-0xb40fffff]
[    0.706388] pci_bus 0000:01: resource 2 [mem 0xa0000000-0xb1ffffff 64bit pref]
[    0.706391] pci_bus 0000:02: resource 1 [mem 0xb4200000-0xb43fffff]
[    0.706394] pci_bus 0000:03: resource 1 [mem 0xb4400000-0xb44fffff]
[    0.708592] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    0.708634] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.708797] PCI: CLS 64 bytes, default 64
[    0.708869] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.708871] software IO TLB: mapped [mem 0x00000000878e8000-0x000000008b8e8000] (64MB)
[    0.708923] Trying to unpack rootfs image as initramfs...
[    0.709962] Initialise system trusted keyrings
[    0.709975] Key type blacklist registered
[    0.710043] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[    0.710075] zbud: loaded
[    0.710498] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.710638] fuse: init (API version 7.38)
[    0.710837] integrity: Platform Keyring initialized
[    0.710841] integrity: Machine keyring initialized
[    0.726329] Key type asymmetric registered
[    0.726334] Asymmetric key parser 'x509' registered
[    0.726362] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.726423] io scheduler mq-deadline registered
[    0.727212] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[    0.727335] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[    0.727743] pcieport 0000:00:1c.5: PME: Signaling with IRQ 123
[    0.727837] pcieport 0000:00:1c.5: AER: enabled with IRQ 123
[    0.728204] pcieport 0000:00:1d.0: PME: Signaling with IRQ 124
[    0.728299] pcieport 0000:00:1d.0: AER: enabled with IRQ 124
[    0.728428] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.728543] efifb: probing for efifb
[    0.728576] efifb: showing boot graphics
[    0.731356] efifb: framebuffer at 0xc0000000, using 8128k, total 8128k
[    0.731360] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    0.731363] efifb: scrolling: redraw
[    0.731364] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.731512] Console: switching to colour frame buffer device 240x67
[    0.734216] fb0: EFI VGA frame buffer device
[    0.736012] ACPI: AC: AC Adapter [ADP1] (on-line)
[    0.736131] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/PNP0C09:00/PNP0C0D:00/input/input0
[    0.736197] ACPI: button: Lid Switch [LID0]
[    0.736285] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.736337] ACPI: button: Power Button [PWRF]
[    0.739781] thermal LNXTHERM:00: registered as thermal_zone0
[    0.739786] ACPI: thermal: Thermal Zone [TZ00] (0 C)
[    0.740564] thermal LNXTHERM:01: registered as thermal_zone1
[    0.740568] ACPI: thermal: Thermal Zone [TZ01] (0 C)
[    0.740726] thermal LNXTHERM:02: registered as thermal_zone2
[    0.740729] ACPI: thermal: Thermal Zone [TZ02] (10 C)
[    0.741123] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.745249] hpet_acpi_add: no address or irqs in _CRS
[    0.745289] Linux agpgart interface v0.103
[    0.748881] loop: module loaded
[    0.749388] tun: Universal TUN/TAP device driver, 1.6
[    0.749489] PPP generic driver version 2.4.2
[    0.749737] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    0.749742] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    0.750358] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.750566] mousedev: PS/2 mouse device common for all mice
[    0.750835] rtc_cmos 00:04: RTC can wake from S4
[    0.751676] rtc_cmos 00:04: registered as rtc0
[    0.751854] rtc_cmos 00:04: setting system clock to 2024-02-20T02:41:43 UTC (1708396903)
[    0.751898] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram
[    0.751913] i2c_dev: i2c /dev entries driver
[    0.752578] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    0.752591] device-mapper: uevent: version 1.0.3
[    0.752772] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    0.752817] platform eisa.0: Probing EISA bus 0
[    0.752826] platform eisa.0: EISA: Cannot allocate resource for mainboard
[    0.752829] platform eisa.0: Cannot allocate resource for EISA slot 1
[    0.752832] platform eisa.0: Cannot allocate resource for EISA slot 2
[    0.752835] platform eisa.0: Cannot allocate resource for EISA slot 3
[    0.752837] platform eisa.0: Cannot allocate resource for EISA slot 4
[    0.752840] platform eisa.0: Cannot allocate resource for EISA slot 5
[    0.752842] platform eisa.0: Cannot allocate resource for EISA slot 6
[    0.752845] platform eisa.0: Cannot allocate resource for EISA slot 7
[    0.752847] platform eisa.0: Cannot allocate resource for EISA slot 8
[    0.752849] platform eisa.0: EISA: Detected 0 cards
[    0.752855] intel_pstate: Intel P-state driver initializing
[    0.753394] intel_pstate: HWP enabled
[    0.753775] ledtrig-cpu: registered to indicate activity on CPUs
[    0.753943] intel_pmc_core intel_pmc_core.0:  initialized
[    0.754004] drop_monitor: Initializing network drop monitor service
[    0.761622] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[    0.768583] NET: Registered PF_INET6 protocol family
[    0.888347] ACPI: battery: Slot [BAT0] (battery present)
[    1.060127] Freeing initrd memory: 68724K
[    1.066462] Segment Routing with IPv6
[    1.066475] In-situ OAM (IOAM) with IPv6
[    1.066506] NET: Registered PF_PACKET protocol family
[    1.066658] Key type dns_resolver registered
[    1.067699] microcode: Microcode Update Driver: v2.2.
[    1.067705] IPI shorthand broadcast: enabled
[    1.069076] sched_clock: Marking stable (1061563412, 6115571)->(1144575545, -76896562)
[    1.069261] registered taskstats version 1
[    1.070089] Loading compiled-in X.509 certificates
[    1.070540] Loaded X.509 cert 'Build time autogenerated kernel key: 605c7c135229ebe23ab6a6fa2965fd12055e3c58'
[    1.070935] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[    1.071322] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[    1.071323] blacklist: Loading compiled-in revocation X.509 certificates
[    1.071338] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[    1.071351] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
[    1.071363] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
[    1.071376] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
[    1.071388] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
[    1.071402] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
[    1.071414] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
[    1.071425] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
[    1.073058] Key type .fscrypt registered
[    1.073059] Key type fscrypt-provisioning registered
[    1.075934] Key type encrypted registered
[    1.075938] AppArmor: AppArmor sha1 policy hashing enabled
[    1.078043] integrity: Loading X.509 certificate: UEFI:db
[    1.078086] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    1.078087] integrity: Loading X.509 certificate: UEFI:db
[    1.078106] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    1.078107] integrity: Loading X.509 certificate: UEFI:db
[    1.078127] integrity: Loaded X.509 cert '8L330S-15IKB: 098549669f60e39546bc5ecbff8977e2'
[    1.082461] ima: No TPM chip found, activating TPM-bypass!
[    1.082466] Loading compiled-in module X.509 certificates
[    1.082867] Loaded X.509 cert 'Build time autogenerated kernel key: 605c7c135229ebe23ab6a6fa2965fd12055e3c58'
[    1.082869] ima: Allocated hash algorithm: sha1
[    1.082875] ima: No architecture policies found
[    1.082889] evm: Initialising EVM extended attributes:
[    1.082889] evm: security.selinux
[    1.082891] evm: security.SMACK64
[    1.082891] evm: security.SMACK64EXEC
[    1.082892] evm: security.SMACK64TRANSMUTE
[    1.082893] evm: security.SMACK64MMAP
[    1.082893] evm: security.apparmor
[    1.082894] evm: security.ima
[    1.082895] evm: security.capability
[    1.082895] evm: HMAC attrs: 0x1
[    1.083310] PM:   Magic number: 12:818:662
[    1.083378] acpi PNP0C0A:01: hash matches
[    1.088391] RAS: Correctable Errors collector initialized.
[    1.088446] clk: Disabling unused clocks
[    1.089382] Freeing unused decrypted memory: 2036K
[    1.090031] Freeing unused kernel image (initmem) memory: 4792K
[    1.130598] Write protecting the kernel read-only data: 34816k
[    1.131478] Freeing unused kernel image (rodata/data gap) memory: 1156K
[    1.204414] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.204416] x86/mm: Checking user space page tables
[    1.242425] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.242430] Run /init as init process
[    1.242431]   with arguments:
[    1.242433]     /init
[    1.242434]     splash
[    1.242434]   with environment:
[    1.242435]     HOME=/
[    1.242436]     TERM=linux
[    1.242437]     BOOT_IMAGE=/boot/vmlinuz-6.5.0-14-generic
[    1.341684] hid: raw HID events driver (C) Jiri Kosina
[    1.341954] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.341965] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.341979] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.341987] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1.370558] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.370566] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.372478] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    1.372841] ahci 0000:00:17.0: version 3.0
[    1.373745] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.373973] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    1.373979] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    1.374760] scsi host0: ahci
[    1.374878] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.374884] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.374889] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    1.374934] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
[    1.374938] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.374940] usb usb1: Product: xHCI Host Controller
[    1.374941] usb usb1: Manufacturer: Linux 6.5.0-14-generic xhci-hcd
[    1.374942] usb usb1: SerialNumber: 0000:00:14.0
[    1.374951] ata1: SATA max UDMA/133 abar m2048@0xb4535000 port 0xb4535100 irq 126
[    1.375071] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.375165] hub 1-0:1.0: USB hub found
[    1.375190] hub 1-0:1.0: 12 ports detected
[    1.382334] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.05
[    1.382339] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.382341] usb usb2: Product: xHCI Host Controller
[    1.382343] usb usb2: Manufacturer: Linux 6.5.0-14-generic xhci-hcd
[    1.382345] usb usb2: SerialNumber: 0000:00:14.0
[    1.382478] hub 2-0:1.0: USB hub found
[    1.382493] hub 2-0:1.0: 6 ports detected
[    1.383950] usb: port power management may be unreliable
[    1.642172] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[    1.689732] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.719158] ata1.00: ATA-10: ST1000LM035-1RK172, LCM2, max UDMA/100
[    1.730178] tsc: Refined TSC clocksource calibration: 1992.002 MHz
[    1.730199] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x396d566cf43, max_idle_ns: 881590760263 ns
[    1.730284] clocksource: Switched to clocksource tsc
[    1.799806] usb 1-1: New USB device found, idVendor=248a, idProduct=8514, bcdDevice= 1.00
[    1.799835] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.799842] usb 1-1: Product: Wireless Receiver
[    1.799848] usb 1-1: Manufacturer: Telink
[    1.811520] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.861624] ata1.00: configured for UDMA/100
[    1.881527] scsi 0:0:0:0: Direct-Access     ATA      ST1000LM035-1RK1 LCM2 PQ: 0 ANSI: 5
[    1.883836] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.884052] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    1.884066] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    1.884113] sd 0:0:0:0: [sda] Write Protect is off
[    1.884130] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.884218] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.884344] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    1.930197] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[    1.944620]  sda: sda1 sda2 sda3
[    1.945561] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.951427] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.951453] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.951519] pci 0000:00:1f.1: [8086:9d20] type 00 class 0x058000
[    1.951579] pci 0000:00:1f.1: reg 0x10: [mem 0xfd000000-0xfdffffff 64bit]
[    1.952401] nvme nvme0: pci function 0000:03:00.0
[    1.954600] i2c i2c-1: 2/2 memory slots populated (from DMI)
[    1.955929] input: SYNA3255:00 06CB:7F27 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3255:00/0018:06CB:7F27.0001/input/input3
[    1.956065] input: SYNA3255:00 06CB:7F27 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3255:00/0018:06CB:7F27.0001/input/input4
[    1.956198] hid-generic 0018:06CB:7F27.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA3255:00 06CB:7F27] on i2c-SYNA3255:00
[    1.970234] nvme nvme0: allocated 64 MiB host memory buffer.
[    1.990650] nvme nvme0: 8/0/0 default/read/poll queues
[    2.001947]  nvme0n1: p1 p2
[    2.080036] usb 1-4: New USB device found, idVendor=0cf3, idProduct=e500, bcdDevice= 0.01
[    2.080052] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.210236] usb 1-7: new high-speed USB device number 4 using xhci_hcd
[    2.395048] usb 1-7: New USB device found, idVendor=174f, idProduct=2426, bcdDevice= 1.08
[    2.395067] usb 1-7: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    2.395075] usb 1-7: Product: Integrated Camera
[    2.395081] usb 1-7: Manufacturer: 201406250001
[    2.395086] usb 1-7: SerialNumber: 200901010001
[    2.428279] input: Telink Wireless Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:248A:8514.0002/input/input6
[    2.428673] input: Telink Wireless Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:248A:8514.0002/input/input7
[    2.486763] input: Telink Wireless Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:248A:8514.0002/input/input8
[    2.487309] hid-generic 0003:248A:8514.0002: input,hidraw1: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:00:14.0-1/input0
[    2.490477] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:248A:8514.0003/input/input9
[    2.550944] hid-generic 0003:248A:8514.0003: input,hidraw2: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:00:14.0-1/input1
[    2.551101] usbcore: registered new interface driver usbhid
[    2.551107] usbhid: USB HID core driver
[    3.880454] EXT4-fs (nvme0n1p2): mounted filesystem 49f117eb-48c0-4e1c-9637-5f174f964b2a ro with ordered data mode. Quota mode: none.
[    4.026534] systemd[1]: Inserted module 'autofs4'
[    4.130622] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    4.130747] systemd[1]: Detected architecture x86-64.
[    4.131063] systemd[1]: Hostname set to <lenovo-ideapad-330s-15ikb-gtx1050>.
[    4.163106] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[    4.208711] block nvme0n1: the capability attribute has been deprecated.
[    4.318070] systemd[1]: Queued start job for default target Graphical Interface.
[    4.343420] systemd[1]: Created slice Slice /system/modprobe.
[    4.343898] systemd[1]: Created slice Slice /system/systemd-fsck.
[    4.344147] systemd[1]: Created slice User and Session Slice.
[    4.344260] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.344486] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.344567] systemd[1]: Reached target User and Group Name Lookups.
[    4.344587] systemd[1]: Reached target Remote File Systems.
[    4.344602] systemd[1]: Reached target Slice Units.
[    4.344623] systemd[1]: Reached target Mounting snaps.
[    4.344656] systemd[1]: Reached target Local Verity Protected Volumes.
[    4.345226] systemd[1]: Listening on Syslog Socket.
[    4.345359] systemd[1]: Listening on fsck to fsckd communication Socket.
[    4.345431] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    4.345697] systemd[1]: Listening on Journal Audit Socket.
[    4.345818] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.345968] systemd[1]: Listening on Journal Socket.
[    4.346272] systemd[1]: Listening on udev Control Socket.
[    4.346399] systemd[1]: Listening on udev Kernel Socket.
[    4.347394] systemd[1]: Mounting Huge Pages File System...
[    4.348378] systemd[1]: Mounting POSIX Message Queue File System...
[    4.349466] systemd[1]: Mounting Kernel Debug File System...
[    4.350461] systemd[1]: Mounting Kernel Trace File System...
[    4.352447] systemd[1]: Starting Journal Service...
[    4.353701] systemd[1]: Starting Set the console keyboard layout...
[    4.354810] systemd[1]: Starting Create List of Static Device Nodes...
[    4.355968] systemd[1]: Starting Load Kernel Module configfs...
[    4.357642] systemd[1]: Starting Load Kernel Module drm...
[    4.359419] systemd[1]: Starting Load Kernel Module efi_pstore...
[    4.360855] systemd[1]: Starting Load Kernel Module fuse...
[    4.361216] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    4.364138] systemd[1]: Starting Load Kernel Modules...
[    4.365088] pstore: Using crash dump compression: deflate
[    4.365731] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.367965] systemd[1]: Starting Coldplug All udev Devices...
[    4.371360] systemd[1]: Mounted Huge Pages File System.
[    4.371543] systemd[1]: Mounted POSIX Message Queue File System.
[    4.371884] systemd[1]: Mounted Kernel Debug File System.
[    4.372080] systemd[1]: Mounted Kernel Trace File System.
[    4.372897] systemd[1]: Finished Create List of Static Device Nodes.
[    4.373536] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    4.374107] systemd[1]: Finished Load Kernel Module configfs.
[    4.374770] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    4.375244] systemd[1]: Finished Load Kernel Module fuse.
[    4.377446] systemd[1]: Mounting FUSE Control File System...
[    4.378315] EXT4-fs (nvme0n1p2): re-mounted 49f117eb-48c0-4e1c-9637-5f174f964b2a r/w. Quota mode: none.
[    4.379916] systemd[1]: Mounting Kernel Configuration File System...
[    4.383887] systemd[1]: Finished Remount Root and Kernel File Systems.
[    4.385215] systemd[1]: Mounted FUSE Control File System.
[    4.387359] systemd[1]: Activating swap /swapfile...
[    4.389744] systemd[1]: Starting Load/Save Random Seed...
[    4.393180] systemd[1]: Starting Create System Users...
[    4.395136] systemd[1]: Mounted Kernel Configuration File System.
[    4.401569] Adding 2097148k swap on /swapfile.  Priority:-2 extents:16 across:845283328k SSFS
[    4.401659] systemd[1]: Activated swap /swapfile.
[    4.401749] systemd[1]: Reached target Swaps.
[    4.403918] systemd[1]: Finished Load/Save Random Seed.
[    4.404154] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    4.412084] ACPI: bus type drm_connector registered
[    4.414076] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    4.417186] systemd[1]: Finished Load Kernel Module drm.
[    4.417345] lp: driver loaded but no devices found
[    4.419042] pstore: Registered efi_pstore as persistent store backend
[    4.420115] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    4.420548] systemd[1]: Finished Load Kernel Module efi_pstore.
[    4.420719] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    4.421983] ppdev: user-space parallel port driver
[    4.427458] systemd[1]: Finished Create System Users.
[    4.428532] systemd[1]: Starting Create Static Device Nodes in /dev...
[    4.438526] systemd[1]: Started Journal Service.
[    4.443933] systemd-journald[275]: Received client request to flush runtime journal.
[    4.447675] systemd-journald[275]: File /var/log/journal/12d6dbef65f14514918ac4ed758f746e/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    4.471542] loop0: detected capacity change from 0 to 8
[    4.472734] loop1: detected capacity change from 0 to 173896
[    4.474511] loop2: detected capacity change from 0 to 177880
[    4.476272] loop3: detected capacity change from 0 to 113992
[    4.477938] loop4: detected capacity change from 0 to 130888
[    4.480086] loop5: detected capacity change from 0 to 130880
[    4.482616] loop6: detected capacity change from 0 to 151784
[    4.484842] loop7: detected capacity change from 0 to 151992
[    4.486786] loop8: detected capacity change from 0 to 536760
[    4.488712] loop9: detected capacity change from 0 to 537600
[    4.489757] loop10: detected capacity change from 0 to 305640
[    4.492453] loop11: detected capacity change from 0 to 324720
[    4.492769] loop12: detected capacity change from 0 to 337560
[    4.495437] loop13: detected capacity change from 0 to 709280
[    4.496599] loop14: detected capacity change from 0 to 716176
[    4.498304] loop15: detected capacity change from 0 to 1017816
[    4.500073] loop16: detected capacity change from 0 to 187776
[    4.501666] loop17: detected capacity change from 0 to 94064
[    4.503214] loop18: detected capacity change from 0 to 25240
[    4.504678] loop19: detected capacity change from 0 to 83672
[    4.506681] loop20: detected capacity change from 0 to 82800
[    4.508306] loop21: detected capacity change from 0 to 608
[    4.509082] loop22: detected capacity change from 0 to 904
[    4.510967] loop23: detected capacity change from 0 to 175112
[    4.513106] loop24: detected capacity change from 0 to 175112
[    4.687876] Consider using thermal netlink events interface
[    4.736474] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input10
[    4.769184] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[    4.816087] ideapad_acpi VPC2004:00: DYTC interface is not available
[    4.833901] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.833951] mc: Linux media interface: v0.10
[    4.834312] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.865730] videodev: Linux video capture interface: v2.00
[    4.909174] intel_rapl_common: Found RAPL domain package
[    4.923900] Bluetooth: Core ver 2.22
[    4.923927] NET: Registered PF_BLUETOOTH protocol family
[    4.923931] Bluetooth: HCI device and connection manager initialized
[    4.923936] Bluetooth: HCI socket layer initialized
[    4.923940] Bluetooth: L2CAP socket layer initialized
[    4.923945] Bluetooth: SCO socket layer initialized
[    5.146418] nvidia: loading out-of-tree module taints kernel.
[    5.146428] nvidia: module license 'NVIDIA' taints kernel.
[    5.146429] Disabling lock debugging due to kernel taint
[    5.146432] nvidia: module license taints kernel.
[    5.380170] intel_rapl_common: Found RAPL domain package
[    5.380175] intel_rapl_common: Found RAPL domain core
[    5.380177] intel_rapl_common: Found RAPL domain uncore
[    5.380180] intel_rapl_common: Found RAPL domain psys
[    5.487222] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    5.487229] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    5.487232] RAPL PMU: hw unit of domain package 2^-14 Joules
[    5.487233] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    5.487235] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    5.487693] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[    5.487727] Console: switching to colour dummy device 80x25
[    5.489455] i915 0000:00:02.0: vgaarb: deactivate vga console
[    5.491196] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[    5.491338] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[    5.497436] cryptd: max_cpu_qlen set to 1000
[    5.499667] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    5.502139] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    5.509984] input: SYNA3255:00 06CB:7F27 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3255:00/0018:06CB:7F27.0001/input/input11
[    5.512560] input: SYNA3255:00 06CB:7F27 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3255:00/0018:06CB:7F27.0001/input/input12
[    5.513350] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[    5.514720] hid-multitouch 0018:06CB:7F27.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA3255:00 06CB:7F27] on i2c-SYNA3255:00
[    5.519883] usb 1-7: Found UVC 1.00 device Integrated Camera (174f:2426)
[    5.521196] AVX2 version of gcm_enc/dec engaged.
[    5.521253] AES CTR mode by8 optimization enabled
[    5.524781] usbcore: registered new interface driver btusb
[    5.528792] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[    5.528796] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[    5.532819] usbcore: registered new interface driver uvcvideo
[    5.543183] audit: type=1400 audit(1708396908.286:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="torbrowser_tor" pid=576 comm="apparmor_parser"
[    5.544357] audit: type=1400 audit(1708396908.286:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=572 comm="apparmor_parser"
[    5.544364] audit: type=1400 audit(1708396908.286:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=572 comm="apparmor_parser"
[    5.548523] audit: type=1400 audit(1708396908.290:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=584 comm="apparmor_parser"
[    5.549945] audit: type=1400 audit(1708396908.290:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=583 comm="apparmor_parser"
[    5.551163] audit: type=1400 audit(1708396908.294:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=571 comm="apparmor_parser"
[    5.552634] audit: type=1400 audit(1708396908.294:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=578 comm="apparmor_parser"
[    5.552640] audit: type=1400 audit(1708396908.294:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=578 comm="apparmor_parser"
[    5.552643] audit: type=1400 audit(1708396908.294:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=578 comm="apparmor_parser"
[    5.552996] audit: type=1400 audit(1708396908.294:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=573 comm="apparmor_parser"
[    5.566796] i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
[    5.602040] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[    5.608854] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  535.154.05  Thu Dec 28 15:37:48 UTC 2023
[    5.609298] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    5.614104] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    5.614473] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14
[    5.614589] ACPI: video: [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
[    5.614624] ACPI: video: Video Device [PXSX] (multi-head: yes  rom: yes  post: no)
[    5.614668] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:36/LNXVIDEO:01/input/input15
[    5.658366] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  535.154.05  Thu Dec 28 15:51:29 UTC 2023
[    5.717487] fbcon: i915drmfb (fb0) is primary device
[    5.719770] Console: switching to colour frame buffer device 240x67
[    5.739514] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    5.752823] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.752840] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[    5.752843] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[    5.752846] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[    5.752852] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.752864] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.752866] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.752878] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.752880] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.752892] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.752893] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.752905] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.779086] snd_hda_intel 0000:01:00.1: Disabling MSI
[    5.779096] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    5.786480] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.786498] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[    5.786501] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[    5.786505] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[    5.786511] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.786524] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.786526] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.786539] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.786540] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.786553] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.786555] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    5.786567] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[    5.808381] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    5.849643] ACPI Warning: \_SB.PCI0.RP01.PXSX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230331/nsarguments-61)
[    5.874180] intel_tcc_cooling: Programmable TCC Offset detected
[    5.894993] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[    5.897269] ath10k_pci 0000:02:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 17aa:0901
[    5.897273] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[    5.897300] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    5.897725] ath10k_pci 0000:02:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[    5.901744] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1c.0/0000:01:00.1/sound/card1/input16
[    5.901803] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[    5.901818] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[    5.901820] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[    5.901823] pcieport 0000:00:1c.5:    [12] Timeout
[    5.901834] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[    5.901836] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[    5.901838] ath10k_pci 0000:02:00.0:    [12] Timeout
[    5.901840] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[    5.901881] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1c.0/0000:01:00.1/sound/card1/input17
[    5.901971] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1c.0/0000:01:00.1/sound/card1/input18
[    5.902086] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1c.0/0000:01:00.1/sound/card1/input19
[    5.923661] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[    5.923684] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[    5.923687] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[    5.923690] pcieport 0000:00:1c.5:    [12] Timeout
[    5.923701] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[    5.923702] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[    5.923704] ath10k_pci 0000:02:00.0:    [12] Timeout
[    5.923706] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[    5.923841] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[    5.933088] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[    5.933110] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[    5.933113] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[    5.933116] pcieport 0000:00:1c.5:    [12] Timeout
[    5.933124] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[    5.933127] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[    5.933129] ath10k_pci 0000:02:00.0:    [12] Timeout
[    5.933131] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[    5.936223] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC236: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    5.936230] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.936234] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    5.936238] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.936241] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.936243] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[    5.936246] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    5.964629] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[    5.991055] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    5.991187] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    6.124110] ath10k_pci 0000:02:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[    6.211956] ath: EEPROM regdomain: 0x6c
[    6.211958] ath: EEPROM indicates we should expect a direct regpair map
[    6.211959] ath: Country alpha2 being used: 00
[    6.211960] ath: Regpair used: 0x6c
[    6.215901] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[    6.564932] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[    6.611088] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    6.611094] Bluetooth: BNEP filters: protocol multicast
[    6.611099] Bluetooth: BNEP socket layer initialized
[    6.613189] Bluetooth: MGMT ver 1.22
[    6.639835] NET: Registered PF_ALG protocol family
[    6.872143] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    6.872158] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[    6.872174] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[    6.872176] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[    6.873037] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    6.890348] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[    6.890357] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[    6.890359] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000080/00006000
[    6.890361] ath10k_pci 0000:02:00.0:    [ 7] BadDLLP
[    6.896394] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[    6.896402] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[    6.896404] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000080/00006000
[    6.896406] ath10k_pci 0000:02:00.0:    [ 7] BadDLLP
[    6.908044] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[    6.908058] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[    6.908060] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00002041/00002000
[    6.908062] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[    6.908064] pcieport 0000:00:1c.5:    [ 6] BadTLP
[    6.927786] nvidia-uvm: Loaded the UVM driver, major device number 507.
[    7.283887] systemd-journald[275]: File /var/log/journal/12d6dbef65f14514918ac4ed758f746e/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   12.130340] ath10k_pci 0000:02:00.0: wmi service ready event not received
[   12.211172] ath10k_pci 0000:02:00.0: Could not init core: -110
[   12.228030] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228049] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.228052] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[   12.228057] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[   12.228063] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228076] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.228078] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228091] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.228093] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228105] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.228108] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228120] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.228122] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228134] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.228136] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228148] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.228150] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.228162] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.263953] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.263977] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[   12.263981] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00002041/00002000
[   12.263984] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[   12.263986] pcieport 0000:00:1c.5:    [ 6] BadTLP
[   12.263992] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.264004] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.264005] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[   12.264016] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.264018] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[   12.264029] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[   12.376152] loop25: detected capacity change from 0 to 8
[   12.641664] Bluetooth: RFCOMM TTY layer initialized
[   12.641673] Bluetooth: RFCOMM socket layer initialized
[   12.641677] Bluetooth: RFCOMM ver 1.11
[   13.838150] rfkill: input handler disabled
[   14.161092] kauditd_printk_skb: 49 callbacks suppressed
[   14.161096] audit: type=1400 audit(1708396916.902:61): apparmor="DENIED" operation="capable" class="cap" profile="/snap/snapd/20671/usr/lib/snapd/snap-confine" pid=1825 comm="snap-confine" capability=12  capname="net_admin"
[   14.161255] audit: type=1400 audit(1708396916.902:62): apparmor="DENIED" operation="capable" class="cap" profile="/snap/snapd/20671/usr/lib/snapd/snap-confine" pid=1825 comm="snap-confine" capability=38  capname="perfmon"
[   15.328157] audit: type=1400 audit(1708396918.070:63): apparmor="DENIED" operation="capable" class="cap" profile="/snap/snapd/20671/usr/lib/snapd/snap-confine" pid=2046 comm="snap-confine" capability=12  capname="net_admin"
[   15.328181] audit: type=1400 audit(1708396918.070:64): apparmor="DENIED" operation="capable" class="cap" profile="/snap/snapd/20671/usr/lib/snapd/snap-confine" pid=2046 comm="snap-confine" capability=38  capname="perfmon"
[   16.768615] audit: type=1107 audit(1708396919.510:65): pid=801 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.10" pid=1825 label="snap.snap-store.ubuntu-software" peer_pid=815 peer_label="unconfined"
                exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
[   16.768983] audit: type=1107 audit(1708396919.510:66): pid=801 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.PolicyKit1.Authority" member="CheckAuthorization" mask="send" name=":1.10" pid=1825 label="snap.snap-store.ubuntu-software" peer_pid=815 peer_label="unconfined"
[   16.771165] audit: type=1107 audit(1708396919.514:67): pid=801 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.10" pid=1825 label="snap.snap-store.ubuntu-software" peer_pid=815 peer_label="unconfined"
[   16.771512] audit: type=1107 audit(1708396919.514:68): pid=801 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.PolicyKit1.Authority" member="CheckAuthorization" mask="send" name=":1.10" pid=1825 label="snap.snap-store.ubuntu-software" peer_pid=815 peer_label="unconfined"
[   17.123858] audit: type=1400 audit(1708396919.866:69): apparmor="DENIED" operation="open" class="file" profile="snap.snap-store.ubuntu-software" name="/etc/appstream.conf" pid=1825 comm="snap-store" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[   17.454183] wlp2s0: authenticate with 00:2e:c7:90:98:10
[   17.489063] wlp2s0: send auth to 00:2e:c7:90:98:10 (try 1/3)
[   17.497964] wlp2s0: authenticated
[   17.502148] wlp2s0: associate with 00:2e:c7:90:98:10 (try 1/3)
[   17.574818] wlp2s0: RX AssocResp from 00:2e:c7:90:98:10 (capab=0x1511 status=0 aid=15)
[   17.577270] wlp2s0: associated
[   17.577412] ath: EEPROM regdomain: 0x82fc
[   17.577416] ath: EEPROM indicates we should expect a country code
[   17.577418] ath: doing EEPROM country->regdmn map search
[   17.577420] ath: country maps to regdmn code: 0x3b
[   17.577421] ath: Country alpha2 being used: TH
[   17.577423] ath: Regpair used: 0x3b
[   17.577424] ath: regdomain 0x82fc dynamically updated by country element
[   17.594555] ------------[ cut here ]------------
[   17.594558] WARNING: CPU: 7 PID: 0 at drivers/net/wireless/ath/ath10k/htt_rx.c:38 ath10k_htt_rx_pop_paddr+0x43/0xe0 [ath10k_core]
[   17.594595] Modules linked in: rfcomm nvidia_uvm(PO) cmac algif_hash algif_skcipher af_alg bnep snd_sof_pci_intel_skl snd_hda_codec_realtek snd_sof_intel_hda_common snd_hda_codec_generic soundwire_intel snd_sof_intel_hda_mlink ledtrig_audio soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils soundwire_generic_allocation soundwire_bus snd_soc_avs snd_soc_hda_codec intel_tcc_cooling snd_soc_skl snd_soc_hdac_hda snd_hda_ext_core x86_pkg_temp_thermal intel_powerclamp snd_soc_sst_ipc snd_soc_sst_dsp snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core coretemp snd_compress ac97_bus snd_pcm_dmaengine snd_hda_codec_hdmi nvidia_drm(PO) snd_hda_intel kvm_intel snd_intel_dspcfg snd_intel_sdw_acpi nvidia_modeset(PO) snd_hda_codec ath10k_pci kvm snd_hda_core snd_hwdep irqbypass crct10dif_pclmul polyval_clmulni snd_pcm binfmt_misc polyval_generic snd_seq_midi ghash_clmulni_intel btusb aesni_intel snd_seq_midi_event uvcvideo ath10k_core crypto_simd snd_rawmidi btrtl cryptd videobuf2_vmalloc btbcm
[   17.594671]  uvc ath rapl btintel videobuf2_memops nls_iso8859_1 nvidia(PO) mei_hdcp mei_pxp intel_rapl_msr btmtk i915 snd_seq videobuf2_v4l2 intel_cstate snd_seq_device mac80211 bluetooth drm_buddy videodev ttm processor_thermal_device_pci_legacy processor_thermal_device snd_timer drm_display_helper videobuf2_common ecdh_generic joydev input_leds mc serio_raw intel_wmi_thunderbolt wmi_bmof ecc cec processor_thermal_rfim cfg80211 snd processor_thermal_mbox hid_multitouch rc_core mei_me processor_thermal_rapl libarc4 soundcore mei drm_kms_helper intel_rapl_common intel_xhci_usb_role_switch int340x_thermal_zone i2c_algo_bit intel_soc_dts_iosf intel_pch_thermal ideapad_laptop sparse_keymap platform_profile int3400_thermal acpi_thermal_rel mac_hid acpi_pad sch_fq_codel cuse msr parport_pc ppdev lp parport drm efi_pstore ip_tables x_tables autofs4 dm_mirror dm_region_hash dm_log usbhid hid_generic nvme i2c_i801 crc32_pclmul nvme_core i2c_smbus nvme_common intel_lpss_pci ahci intel_lpss libahci xhci_pci idma64
[   17.594739]  xhci_pci_renesas i2c_hid_acpi video i2c_hid wmi hid
[   17.594745] CPU: 7 PID: 0 Comm: swapper/7 Tainted: P           O       6.5.0-14-generic #14~22.04.1-Ubuntu
[   17.594748] Hardware name: LENOVO 81GC/LNVNB161216, BIOS 8LCN23WW 06/10/2019
[   17.594750] RIP: 0010:ath10k_htt_rx_pop_paddr+0x43/0xe0 [ath10k_core]
[   17.594775] Code: 8b 0f 48 c1 e8 3c 48 8b 84 c1 f0 0c 00 00 48 85 c0 74 17 48 83 e8 08 48 85 c0 74 0e 48 3b 30 74 25 48 8b 40 08 48 85 c0 75 e9 <0f> 0b 31 db 48 89 d8 48 8b 5d f8 c9 31 d2 31 c9 31 f6 31 ff 45 31
[   17.594778] RSP: 0018:ffffb7a3002bccd8 EFLAGS: 00010246
[   17.594780] RAX: 0000000000000000 RBX: ffff9c33cb5ae3d0 RCX: ffff9c33e30a20a0
[   17.594782] RDX: ffffb7a3002bcd60 RSI: 000000008b226000 RDI: ffff9c33e30a2d18
[   17.594783] RBP: ffffb7a3002bcce0 R08: 0000000000000000 R09: 0000000000000000
[   17.594785] R10: ffffb7a3002bcdf0 R11: 0000000000000000 R12: 00000000ffffffff
[   17.594786] R13: ffff9c33e30a20a0 R14: ffffb7a3002bcd60 R15: 0000000000000000
[   17.594788] FS:  0000000000000000(0000) GS:ffff9c3622dc0000(0000) knlGS:0000000000000000
[   17.594789] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   17.594791] CR2: 00007f3cd0010ab8 CR3: 000000007903a005 CR4: 00000000003706e0
[   17.594793] Call Trace:
[   17.594794]  <IRQ>
[   17.594797]  ? show_regs+0x6d/0x80
[   17.594803]  ? __warn+0x89/0x160
[   17.594806]  ? ath10k_htt_rx_pop_paddr+0x43/0xe0 [ath10k_core]
[   17.594831]  ? report_bug+0x17e/0x1b0
[   17.594836]  ? handle_bug+0x46/0x90
[   17.594840]  ? exc_invalid_op+0x18/0x80
[   17.594843]  ? asm_exc_invalid_op+0x1b/0x20
[   17.594849]  ? ath10k_htt_rx_pop_paddr+0x43/0xe0 [ath10k_core]
[   17.594871]  ath10k_htt_rx_pop_paddr32_list+0x91/0x300 [ath10k_core]
[   17.594894]  ? __ath10k_pci_rx_post_buf+0x183/0x250 [ath10k_pci]
[   17.594901]  ath10k_htt_rx_in_ord_ind+0x139/0x350 [ath10k_core]
[   17.594925]  ath10k_htt_txrx_compl_task+0xa0/0x2d0 [ath10k_core]
[   17.594946]  ? ath10k_htt_txrx_compl_task+0xa0/0x2d0 [ath10k_core]
[   17.594969]  ath10k_pci_napi_poll+0x5c/0x160 [ath10k_pci]
[   17.594975]  __napi_poll+0x30/0x1f0
[   17.594979]  net_rx_action+0x181/0x2e0
[   17.594982]  __do_softirq+0xd9/0x349
[   17.594985]  ? handle_irq_event+0x52/0x80
[   17.594988]  ? handle_edge_irq+0xda/0x250
[   17.594991]  __irq_exit_rcu+0x75/0xa0
[   17.594994]  irq_exit_rcu+0xe/0x20
[   17.594997]  common_interrupt+0xa4/0xb0
[   17.594999]  </IRQ>
[   17.595000]  <TASK>
[   17.595002]  asm_common_interrupt+0x27/0x40
[   17.595005] RIP: 0010:cpuidle_enter_state+0xda/0x720
[   17.595008] Code: 55 06 ff e8 a8 f5 ff ff 8b 53 04 49 89 c7 0f 1f 44 00 00 31 ff e8 46 01 05 ff 80 7d d0 00 0f 85 61 02 00 00 fb 0f 1f 44 00 00 <45> 85 f6 0f 88 f7 01 00 00 4d 63 ee 49 83 fd 09 0f 87 19 05 00 00
[   17.595010] RSP: 0018:ffffb7a300147e18 EFLAGS: 00000246
[   17.595012] RAX: 0000000000000000 RBX: ffffd7a2ffdc0000 RCX: 0000000000000000
[   17.595013] RDX: 0000000000000007 RSI: 0000000000000000 RDI: 0000000000000000
[   17.595014] RBP: ffffb7a300147e68 R08: 0000000000000000 R09: 0000000000000000
[   17.595016] R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffad8d1b80
[   17.595017] R13: 0000000000000006 R14: 0000000000000006 R15: 0000000418b6ce06
[   17.595020]  ? cpuidle_enter_state+0xca/0x720
[   17.595023]  ? finish_task_switch.isra.0+0x85/0x2a0
[   17.595026]  cpuidle_enter+0x2e/0x50
[   17.595030]  call_cpuidle+0x23/0x60
[   17.595034]  cpuidle_idle_call+0x11d/0x190
[   17.595036]  do_idle+0x82/0xf0
[   17.595038]  cpu_startup_entry+0x1d/0x20
[   17.595040]  start_secondary+0x129/0x160
[   17.595045]  secondary_startup_64_no_verify+0x17e/0x18b
[   17.595050]  </TASK>
[   17.595051] ---[ end trace 0000000000000000 ]---
[   17.595054] ath10k_pci 0000:02:00.0: failed to pop paddr list: -2
[   17.625822] wlp2s0: Limiting TX power to 27 (30 - 3) dBm as advertised by 00:2e:c7:90:98:10
[   27.579774] wlp2s0: deauthenticating from 00:2e:c7:90:98:10 by local choice (Reason: 3=DEAUTH_LEAVING)
[   32.603214] wlp2s0: authenticate with b4:fb:f9:7b:90:90
[   32.632424] wlp2s0: send auth to b4:fb:f9:7b:90:90 (try 1/3)
[   32.639398] wlp2s0: authenticated
[   32.646131] wlp2s0: associate with b4:fb:f9:7b:90:90 (try 1/3)
[   32.650812] wlp2s0: RX AssocResp from b4:fb:f9:7b:90:90 (capab=0x1511 status=0 aid=9)
[   32.653281] wlp2s0: associated
[   32.653394] ath: EEPROM regdomain: 0x82fc
[   32.653396] ath: EEPROM indicates we should expect a country code
[   32.653398] ath: doing EEPROM country->regdmn map search
[   32.653400] ath: country maps to regdmn code: 0x3b
[   32.653401] ath: Country alpha2 being used: TH
[   32.653403] ath: Regpair used: 0x3b
[   32.653404] ath: regdomain 0x82fc dynamically updated by country element
[   32.664226] wlp2s0: Limiting TX power to 20 (23 - 3) dBm as advertised by b4:fb:f9:7b:90:90
[   42.655766] wlp2s0: deauthenticating from b4:fb:f9:7b:90:90 by local choice (Reason: 3=DEAUTH_LEAVING)
[   47.655625] wlp2s0: authenticate with 00:2e:c7:90:98:10
[   47.688867] wlp2s0: send auth to 00:2e:c7:90:98:10 (try 1/3)
[   47.702486] wlp2s0: authenticated
[   47.706234] wlp2s0: associate with 00:2e:c7:90:98:10 (try 1/3)
[   47.728037] wlp2s0: RX AssocResp from 00:2e:c7:90:98:10 (capab=0x1511 status=0 aid=15)
[   47.731357] wlp2s0: associated
[   47.731575] ath: EEPROM regdomain: 0x82fc
[   47.731581] ath: EEPROM indicates we should expect a country code
[   47.731587] ath: doing EEPROM country->regdmn map search
[   47.731591] ath: country maps to regdmn code: 0x3b
[   47.731595] ath: Country alpha2 being used: TH
[   47.731646] ath: Regpair used: 0x3b
[   47.731650] ath: regdomain 0x82fc dynamically updated by country element
[   47.731948] wlp2s0: Limiting TX power to 27 (30 - 3) dBm as advertised by 00:2e:c7:90:98:10
[   57.733945] wlp2s0: deauthenticating from 00:2e:c7:90:98:10 by local choice (Reason: 3=DEAUTH_LEAVING)
[   62.733139] wlp2s0: authenticate with b4:fb:f9:7b:90:90
[   62.763531] wlp2s0: send auth to b4:fb:f9:7b:90:90 (try 1/3)
[   62.764599] wlp2s0: authenticated
[   62.769985] wlp2s0: associate with b4:fb:f9:7b:90:90 (try 1/3)
[   62.774182] wlp2s0: RX AssocResp from b4:fb:f9:7b:90:90 (capab=0x1511 status=0 aid=9)
[   62.776645] wlp2s0: associated
[   62.776795] ath: EEPROM regdomain: 0x82fc
[   62.776797] ath: EEPROM indicates we should expect a country code
[   62.776799] ath: doing EEPROM country->regdmn map search
[   62.776800] ath: country maps to regdmn code: 0x3b
[   62.776802] ath: Country alpha2 being used: TH
