Ubuntu arduino IDE not showing any ports
[   62.776803] ath: Regpair used: 0x3b
[   62.776805] ath: regdomain 0x82fc dynamically updated by country element
[   62.873078] wlp2s0: Limiting TX power to 20 (23 - 3) dBm as advertised by b4:fb:f9:7b:90:90
[   68.010269] wlp2s0: deauthenticating from b4:fb:f9:7b:90:90 by local choice (Reason: 3=DEAUTH_LEAVING)
[   72.921046] wlp2s0: authenticate with 00:2e:c7:90:98:10
[   72.954299] wlp2s0: send auth to 00:2e:c7:90:98:10 (try 1/3)
[   72.963813] wlp2s0: authenticated
[   72.966258] wlp2s0: associate with 00:2e:c7:90:98:10 (try 1/3)
[   72.978941] wlp2s0: RX AssocResp from 00:2e:c7:90:98:10 (capab=0x1511 status=0 aid=15)
[   72.981607] wlp2s0: associated
[   72.981737] ath: EEPROM regdomain: 0x82fc
[   72.981741] ath: EEPROM indicates we should expect a country code
[   72.981744] ath: doing EEPROM country->regdmn map search
[   72.981747] ath: country maps to regdmn code: 0x3b
[   72.981749] ath: Country alpha2 being used: TH
[   72.981751] ath: Regpair used: 0x3b
[   72.981754] ath: regdomain 0x82fc dynamically updated by country element
[   73.025307] wlp2s0: Limiting TX power to 27 (30 - 3) dBm as advertised by 00:2e:c7:90:98:10
[   78.145356] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[   78.145379] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[   78.145387] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[   78.145396] pcieport 0000:00:1c.5:    [12] Timeout
[   82.983381] wlp2s0: deauthenticating from 00:2e:c7:90:98:10 by local choice (Reason: 3=DEAUTH_LEAVING)
[   97.888974] wlp2s0: authenticate with 00:2e:c7:90:98:11
[   97.922247] wlp2s0: send auth to 00:2e:c7:90:98:11 (try 1/3)
[   97.926444] wlp2s0: authenticated
[   97.930188] wlp2s0: associate with 00:2e:c7:90:98:11 (try 1/3)
[   97.949575] wlp2s0: RX AssocResp from 00:2e:c7:90:98:11 (capab=0x1501 status=0 aid=8)
[   97.953395] wlp2s0: associated
[   97.953735] ath: EEPROM regdomain: 0x82fc
[   97.953745] ath: EEPROM indicates we should expect a country code
[   97.953754] ath: doing EEPROM country->regdmn map search
[   97.953760] ath: country maps to regdmn code: 0x3b
[   97.953766] ath: Country alpha2 being used: TH
[   97.953770] ath: Regpair used: 0x3b
[   97.953774] ath: regdomain 0x82fc dynamically updated by country element
[   98.036819] wlp2s0: Limiting TX power to 27 (30 - 3) dBm as advertised by 00:2e:c7:90:98:11
[  144.486833] wlp2s0: Connection to AP 00:00:00:00:00:00 lost
[  561.862295] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[  561.862328] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[  561.862336] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000001/00006000
[  561.862346] ath10k_pci 0000:02:00.0:    [ 0] RxErr                  (First)
[  755.427427] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[  755.427452] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[  755.427460] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[  755.427470] pcieport 0000:00:1c.5:    [12] Timeout
[  850.523295] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[  850.523322] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[  850.523330] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000001/00006000
[  850.523340] ath10k_pci 0000:02:00.0:    [ 0] RxErr                  (First)
[ 1159.638809] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 1159.638840] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1159.638849] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000001/00006000
[ 1159.638858] ath10k_pci 0000:02:00.0:    [ 0] RxErr                  (First)
[ 1239.521369] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[ 1239.521382] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 1239.521384] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000080/00006000
[ 1239.521387] ath10k_pci 0000:02:00.0:    [ 7] BadDLLP
[ 1271.377098] warning: `gnome-system-mo' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 1497.020933] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[ 1497.021046] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 1497.021048] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000080/00006000
[ 1497.021051] ath10k_pci 0000:02:00.0:    [ 7] BadDLLP
[ 1547.174293] usb 1-3: new full-speed USB device number 5 using xhci_hcd
[ 1547.322922] usb 1-3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[ 1547.322927] usb 1-3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1547.322929] usb 1-3: Product: USB2.0-Ser!
[ 1547.340282] usbcore: registered new interface driver usbserial_generic
[ 1547.340295] usbserial: USB Serial support registered for generic
[ 1547.342278] usbcore: registered new interface driver ch341
[ 1547.342526] usbserial: USB Serial support registered for ch341-uart
[ 1547.342547] ch341 1-3:1.0: ch341-uart converter detected
[ 1547.343217] ch341-uart ttyUSB0: break control not supported, using simulated break
[ 1547.343311] usb 1-3: ch341-uart converter now attached to ttyUSB0
[ 1547.405736] input: PC Speaker as /devices/platform/pcspkr/input/input22
[ 1547.917740] input: BRLTTY 6.4 Linux Screen Driver Keyboard as /devices/virtual/input/input23
[ 1548.039876] usb 1-3: usbfs: interface 0 claimed by ch341 while 'brltty' sets config #1
[ 1548.040225] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[ 1548.040255] ch341 1-3:1.0: device disconnected
[ 1636.420714] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1636.420741] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1636.420747] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[ 1636.420754] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[ 1636.420764] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1636.420780] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[ 1636.456161] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1636.456179] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1636.456182] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[ 1636.456185] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[ 1636.602114] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 1636.602133] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1636.602135] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1636.602137] pcieport 0000:00:1c.5:    [12] Timeout
[ 1636.602147] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1636.602149] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1636.602150] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1636.602152] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 1638.360251] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1638.360296] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1638.360310] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[ 1638.360323] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[ 1638.360352] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1638.360385] pcieport 0000:00:1c.5: AER: can't find device of ID00e5
[ 1638.396426] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1638.396461] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1638.396469] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00000001/00002000
[ 1638.396479] pcieport 0000:00:1c.5:    [ 0] RxErr                  (First)
[ 1638.573291] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 1638.573300] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1638.573302] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1638.573304] pcieport 0000:00:1c.5:    [12] Timeout
[ 1638.573311] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1638.573313] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1638.573314] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1638.573316] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 1638.576421] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[ 1638.576428] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1638.576430] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1638.576432] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1643.620057] wlp2s0: authenticate with 00:2e:c7:90:98:11
[ 1643.652503] wlp2s0: send auth to 00:2e:c7:90:98:11 (try 1/3)
[ 1643.656608] wlp2s0: authenticated
[ 1643.658290] wlp2s0: associate with 00:2e:c7:90:98:11 (try 1/3)
[ 1643.668757] wlp2s0: RX AssocResp from 00:2e:c7:90:98:11 (capab=0x1501 status=0 aid=6)
[ 1643.671183] wlp2s0: associated
[ 1643.671301] ath: EEPROM regdomain: 0x82fc
[ 1643.671303] ath: EEPROM indicates we should expect a country code
[ 1643.671306] ath: doing EEPROM country->regdmn map search
[ 1643.671307] ath: country maps to regdmn code: 0x3b
[ 1643.671309] ath: Country alpha2 being used: TH
[ 1643.671311] ath: Regpair used: 0x3b
[ 1643.671312] ath: regdomain 0x82fc dynamically updated by country element
[ 1643.675604] wlp2s0: Limiting TX power to 27 (30 - 3) dBm as advertised by 00:2e:c7:90:98:11
[ 1649.819830] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1649.819847] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1649.819849] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1649.819852] pcieport 0000:00:1c.5:    [12] Timeout
[ 1649.819855] pcieport 0000:00:1c.5: AER:   Error of this Agent is reported first
[ 1649.819863] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1649.819865] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1649.819867] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1661.435989] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 1661.436000] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1661.436002] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1661.436005] pcieport 0000:00:1c.5:    [12] Timeout
[ 1661.436013] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1661.436015] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1661.436018] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1661.436020] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 1679.137129] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 1679.137164] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1679.137176] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1679.137189] pcieport 0000:00:1c.5:    [12] Timeout
[ 1679.429539] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 1679.429548] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1679.429551] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1679.429553] pcieport 0000:00:1c.5:    [12] Timeout
[ 1679.429565] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1679.429567] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1679.429569] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1679.429571] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 1685.352727] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 1685.352736] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1685.352738] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1685.352741] pcieport 0000:00:1c.5:    [12] Timeout
[ 1685.352748] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1685.352750] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1685.352752] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1685.352754] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 1686.913002] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 1686.913022] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1686.913025] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1686.913028] pcieport 0000:00:1c.5:    [12] Timeout
[ 1686.913030] pcieport 0000:00:1c.5: AER:   Error of this Agent is reported first
[ 1686.913039] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1686.913041] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1686.913044] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1691.404792] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 1691.404802] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1691.404804] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1691.404807] pcieport 0000:00:1c.5:    [12] Timeout
[ 1692.827654] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[ 1692.827667] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1692.827669] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1692.827672] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1886.775895] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 1886.775920] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1886.775928] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1886.775938] pcieport 0000:00:1c.5:    [12] Timeout
[ 1950.879324] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 1950.879337] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1950.879340] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 1950.879343] pcieport 0000:00:1c.5:    [12] Timeout
[ 1950.879353] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1950.879356] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 1950.879359] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 1950.879361] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 2053.281062] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 2053.281095] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2053.281106] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2053.281119] pcieport 0000:00:1c.5:    [12] Timeout
[ 2169.602703] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 2169.602729] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2169.602737] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2169.602747] pcieport 0000:00:1c.5:    [12] Timeout
[ 2169.602762] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 2169.602769] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000040/00006000
[ 2169.602777] ath10k_pci 0000:02:00.0:    [ 6] BadTLP
[ 2169.602784] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 2186.810413] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 2186.810438] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2186.810446] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2186.810455] pcieport 0000:00:1c.5:    [12] Timeout
[ 2201.682144] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 2201.682168] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2201.682172] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2201.682177] pcieport 0000:00:1c.5:    [12] Timeout
[ 2201.682181] pcieport 0000:00:1c.5: AER:   Error of this Agent is reported first
[ 2201.682193] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2201.682196] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 2201.682200] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 2460.440768] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 2460.440794] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2460.440802] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2460.440812] pcieport 0000:00:1c.5:    [12] Timeout
[ 2479.369599] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[ 2479.369630] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2479.369639] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 2479.369649] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 2479.751478] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 2479.751509] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 2479.751517] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000001/00006000
[ 2479.751527] ath10k_pci 0000:02:00.0:    [ 0] RxErr                  (First)
[ 2519.428235] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 2519.428251] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2519.428253] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2519.428256] pcieport 0000:00:1c.5:    [12] Timeout
[ 2519.428257] pcieport 0000:00:1c.5: AER:   Error of this Agent is reported first
[ 2519.428266] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2519.428267] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001040/00006000
[ 2519.428269] ath10k_pci 0000:02:00.0:    [ 6] BadTLP
[ 2519.428271] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 2590.573184] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 2590.573193] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2590.573195] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2590.573197] pcieport 0000:00:1c.5:    [12] Timeout
[ 2590.573204] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2590.573206] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 2590.573208] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 2590.573209] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 2650.123283] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 2650.123294] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2650.123296] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2650.123299] pcieport 0000:00:1c.5:    [12] Timeout
[ 2650.123306] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 2650.123308] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000040/00006000
[ 2650.123311] ath10k_pci 0000:02:00.0:    [ 6] BadTLP
[ 2650.123313] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 2841.528269] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 2841.528294] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2841.528302] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2841.528312] pcieport 0000:00:1c.5:    [12] Timeout
[ 2873.651597] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 2873.651616] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2873.651623] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2873.651631] pcieport 0000:00:1c.5:    [12] Timeout
[ 2899.407941] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 2899.407967] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2899.407975] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 2899.407983] pcieport 0000:00:1c.5:    [12] Timeout
[ 3042.985435] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:02:00.0
[ 3042.985467] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3042.985478] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 3042.985489] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 3235.520125] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 3235.520137] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3235.520140] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 3235.520143] pcieport 0000:00:1c.5:    [12] Timeout
[ 3235.520152] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3235.520154] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 3235.520157] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 3235.520159] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 3241.411357] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 3241.411392] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 3241.411402] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000001/00006000
[ 3241.411413] ath10k_pci 0000:02:00.0:    [ 0] RxErr                  (First)
[ 3294.808950] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:02:00.0
[ 3294.808977] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3294.808985] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 3294.808995] pcieport 0000:00:1c.5:    [12] Timeout
[ 3294.809009] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
[ 3294.809016] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00000040/00006000
[ 3294.809024] ath10k_pci 0000:02:00.0:    [ 6] BadTLP
[ 3294.809031] ath10k_pci 0000:02:00.0: AER:   Error of this Agent is reported first
[ 3469.675725] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 3469.675751] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3469.675760] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 3469.675770] pcieport 0000:00:1c.5:    [12] Timeout
[ 3668.694112] pcieport 0000:00:1c.5: AER: Multiple Corrected error received: 0000:00:1c.5
[ 3668.694144] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3668.694148] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 3668.694152] pcieport 0000:00:1c.5:    [12] Timeout
[ 3668.694156] pcieport 0000:00:1c.5: AER:   Error of this Agent is reported first
[ 3668.694166] ath10k_pci 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3668.694170] ath10k_pci 0000:02:00.0:   device [168c:0042] error status/mask=00001000/00006000
[ 3668.694173] ath10k_pci 0000:02:00.0:    [12] Timeout
[ 3790.495413] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 3790.495427] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3790.495431] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 3790.495436] pcieport 0000:00:1c.5:    [12] Timeout
[ 3859.067942] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 3859.067971] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3859.067980] pcieport 0000:00:1c.5:   device [8086:9d15] error status/mask=00001000/00002000
[ 3859.067991] pcieport 0000:00:1c.5:    [12] Timeout
Uninstall BRLTTY or disable it using udev rules.
how to uinstall or disable?
A simple google search for arduino linux brltty - Google Search reveals e.g.
I try run this command "sudo apt-get remove brltty" but it still not work. when i restart, it work. thx sterretje.
Great. You can mark your topic as solved by clicking the little checkbox under the most useful post.
You can limit the dmesg output in future. Without the board connected, run dmesg -w. You will get the long output; the application will not close. Next observe the changes when you connect the board. <ctrl>C to close the application.
unfortunately i have to ask for help here as well. My newly purchased arduino leonardo is not recognized by the OS, not by Windows and not by Linux. I cant choose a port in the arduino IDE, newest version.
The "On" and "L" LEDs light up.
lsusb command:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:5415 IMC Networks Integrated Camera
Bus 001 Device 004: ID 0bda:c024 Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 002: ID 258a:1007 SINOWEALTH Game Mouse
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
brltty is not installed.
What to do next?
regards,
Alexej
@alra0351
First suspect would be the cable. You might be using a charge-only cable instead of a data/sync cable.
Make sure that you use a data/sync cable.
My setup() function starts off with:
  while(!Serial);
  Serial.println(__FILE__);
What about yours?
In a Linux terminal, type dmesg |grep usb [ENTER]:
Mine looks like:
[260504.190390] usb 3-4.1.4: new full-speed USB device number 30 using xhci_hcd
[260504.297680] usb 3-4.1.4: New USB device found, idVendor=2341, idProduct=8037, bcdDevice= 1.00
[260504.297683] usb 3-4.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[260504.297684] usb 3-4.1.4: Product: Arduino Micro
[260504.297686] usb 3-4.1.4: Manufacturer: Arduino LLC
I tried out 5 different cables. Unfortunately no changes.
Hi @alra0351. Please try this experiment and then report back with the results:
  1. Connect the Arduino board to your computer with the USB cable.
  2. Press and release the reset button on the Arduino board.
Now please reply here on the forum thread with the answer to the following question:
  • Do you see the LED marked "L" on the board pulse after performing the above instructions?
Hi @ptillisch
after pressing the reset button, I see the ā€žLā€œ-Led pulsing. It stops after some seconds and starts blinking (on/off).
OK, this is a good sign. The tricky thing about the boards with native USB capability like your board is the USB code that creates the CDC serial port is running on the same microcontroller as your sketch. This means your sketch code can break the USB code, or stop it from running. When that happens, the board no longer produces a serial port. I know you said it is a "newly purchased" board, but it is still possible you might have already uploaded a sketch after getting the board, or maybe even that you bought the board from an unscrupulous seller who shipped you a returned board to which the previous owner had already uploaded a problematic sketch.
This can be unexpected to those who previously mainly worked with the boards like Uno and Mega with a dedicated USB chip that can never be affected by the sketch code.
The missing port makes it so you can't upload normally any more. However, the situation is really not so bad because there is an independent program called the bootloader in a separate section of memory from your sketch, and that program has its own USB CDC code. So even if the sketch is completely broken, you only need to activate the bootloader to get a port back and be able to upload.
You need to get the timing right. If you press the reset button too early, the bootloader will have already timed out by the time the upload starts. The tricky thing is that when you press the "Upload" button in Arduino IDE, it first compiles your sketch before starting the actual upload. So you need to wait until after the compilation finishes before pressing the reset button.
Try this:
  1. Select Sketch > Upload from the Arduino IDE menus.
  2. Watch the black "Output" panel at the bottom of the Arduino IDE window until you see something like this:
    Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
    Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables.
    Maximum is 2048 bytes.
  3. Immediately press and release the reset button on the Arduino board.
The upload should now finish successfully.
If you find that the board still doesn't produce a port while the bootloader is not activated, the problem may be caused by your sketch code. You can verify this by uploading a simple sketch like the one from File > Examples > 01.Basics > BareMinimum in the Arduino IDE menus. If the uploads work normally after uploading that sketch, but not after uploading the previous sketch you were using, then you will know the issue is caused by that other sketch code.
@ptillisch
thank you for your response. I tried to upload the BareMinimum multiple times and pressed the reset button. I played around with the timing. Unfortunately the IDE always prints the same error: "Failed uploading: no upload port provided." I tried that with different cables aswell.
Its an original arduino board purchased in the arduino store.
So we know from the pulsating L-LED that you have a bootloader and from the flashing LED that the blink example is preloaded.
You haven't answered the question in post #72 about the dmesg output after connecting the board.
Anyway, if there is no reaction in windows device manager or in dmesg when you connect the board, it's a communication problem. Either bad contacts / soldering of the connector on the board or the cable.
You did mention that you tried different cables; does one of those cables work with a cell phone so your computer sees the cell phone? If yes, that's the one to use.
Where did those cables come from? I have two that came with a power bank and a BT speaker and they are charge-only.
@sterretje, @ptillisch
thank you for your help. Sadly, I didn't have a device to check whether the cables were transmitting data or not. I made sure I was using a proper cable by buying a new one. The Arduino was recognized directly.
I noticed one difference immediately when I plugged in the Arduino: The RX LED flashes briefly once. Perhaps this criterion could improve troubleshooting for other users in the future.
best regards,
Alexej
I'm glad it is working now. Thanks for taking the time to post an update with your findings!
Regards,
Per
Thank you for this. I always have to remind myself how hard linux is when I get tired of Windows.
Thanks a lot, I would've never figured this out on my own!
thanks this worked perfectly
