Hello, I recently migrated to Ubuntu 11.04 and I installed Arduino via Synaptic, it seems to work fine but it wont upload.
I have a self-made breaduino with an Atmega168, under windowsOS it works perfectly, selecting the arduino board: "diecimila w/168", so I upload a serial test program to test my ubuntu drivers. Wen I open the Serial Monitor on ubuntu I can comunicate with it just fine at 9600 bd.
The problem is uploading in ubuntu OS, I selected the same board and the correct port, but it says "avrdude: stk500_getsync(): not in sync: resp=0x20" (I have tested all the "reset" options, while, before, after pressing upload)
verbose output:
Binary sketch size: 990 bytes (of a 14336 byte maximum)
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega168 -carduino -P/dev/ttyS4 -b19200 -D -Uflash:w:/tmp/build6136871358548744634.tmp/Blink.cpp.hex:i
avrdude: Version 5.10, compiled on Jun 29 2010 at 03:44:14
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
User configuration file is "/home/rawthil/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyS4
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: [20]
avrdude done. Thank you.
And I also tried via command line with
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega168 -carduino -P/dev/ttyS4 -b9600 -D -Uflash:w:/tmp/build6136871358548744634.tmp/Blink.cpp.hex:i
(note "-b9600" istead of "-b19200")
but it makes no diference.
Im using a PCI-Serial board based on a WCH352L
Thanks!
