UDPSendReceiveString problem
Hi, I am having a problem with the UDPSendReceiveString example. I only modified the ip address in the code. I am using iBoard Ex, which comes with w5100 chip.
In the processing sketch I changed the ip to "255.255.255.255" to send a broadcast message, but arduino serial monitor does not display anything, so I assume it is not receiving any udp message.
When I change the ip in processing to my pc's ip, I get the error message "could not send message. no route to host: datagram send failed".
I have already disabled firewall. Another thing is that my pc has no internet connection. Would appreciate any help. Thanks.
Which once again you haven't provided a link to. Get with the program, here.
PaulS:
Which once again you haven’t provided a link to.
Link to iBoard: IBoard Ex - ITEAD Wiki
Code for iBoard:
#include <SPI.h>
#include <Ethernet.h>
#include < EthernetUdp.h >
byte mac[] = {__, __, __, __, __, __}; // MAC address of controller
IPAddress ip (192,168,1,21);               // ip of pc
unsigned int localPort = 43770; // local port to listen on
// buffers for receiving and sending data (need to change to send bytes instead of char)
char packetBuffer [UDP_TX_PACKET_MAX_SIZE]; // buffer to hold incoming packet
char replyBuffer[] = “acknowledged”; // a string to send back
EthernetUDP Udp; // an EthernetUDP instance to let us send and receive packets over UDP
void setup(){
 Ethernet.begin (mac, ip); // Start Ethernet connection
 Udp.begin (localPort); // Start UDP
void loop(){
 // if data available, read a packet
 int packetSize = Udp.parsePacket();
 if (packetSize){
  Serial.print (“Received packet of size “);
  Serial.println (packetSize);
  Serial.print (“From “);
  IPAddress remote = Udp.remoteIP();
  for (int i=0; i<4; i++){
   Serial.print (remote[i], DEC);
   if (i<3){
   Serial.print(“ “);
 Serial.print (“, port”);
 Serial.println (Udp.remotePort());
 // read the packet into packetBuffer
 Udp.read (packetBuffer, UDP_TX_PACKET_MAX_SIZE);
 Serial.println (“Contents “);
 Serial.println (packetBuffer);
 // send a reply to the IP address and port that sent us the packet we received
 Udp.beginPacket (Udp.remoteIP(), Udp.remotePort());
 Udp.write (replyBuffer);
 Udp.endPacket();
 delay(10);
Code for processing:
import hypermedia.net.*;	// import the UDP library
UDP udp;		// define the UDP object
void setup(){
	udp = new UDP (this, 43770);		// create a new datagram connection on port 43770
	udp.listen (true);			// and wait for incoming message
void draw(){
void keyPressed(){
	int destPort = 43770;
	String ip = “255.255.255.255”;			// broadcast message
	udp.send (“Hello World\n”, ip, destPort);		// the message to send
void receive (byte[] data){
	// print the incoming data bytes as ASCII characters
	for (int i=0; i<data.length; i++) {
		print (char (data[i]));
	println();
Well, I can certainly understand redacting that. NOT.
new returns a pointer. You MUST store that in a variable of type pointer to.
I haven't tried your code, but my w5100 will receive broadcasts on the localnet broadcast address. On your subnet, that would be 192.168.1.255.
I have found the problem. The code works perfectly.
There was no DNS server set on the connection, so the link keeps breaking. Thanks all for the help.
