I finaly bought some material for my arduino projects and I have questions - again.
I have four 7 segment LED displays with common anode that I want to control (each segment needs 2V to work). And ULN2003A (here is a link to the datasheet: ULN2003AN Datasheet pdf - High-Voltage, High-Current Darlington Transistor Arrays - Texas Instruments ). Now I am having trouble connecting this thing. For some reasons it allways works like it should : .
I only tested it with one segment because it is realy late here and I need to go to bed. Here is my wiring:
pin 1 on ULN to arduino pin 2
pin 8 -> GND
pin 16 -> segment on LED display
+5V from arduino to common anode pin on the display (with 100ohm resistor).
Is this correct? I get 2V on the segment and I can control the segment like a normal LED. The main question - will this stop working if there are more segments active at one time?
