Hi, currently i want to try to build an ultrasonic data communication. I tried one sample project from this website, https://hackaday.com/2018/06/01/dead-simple-ultrasonic-data-communication/#comments but i cannot get data transmitted.
I used Arduino nano in this project.
On the transmitter side, i got PWM waveform with much noises but on the receiver side i got straight line waveforms throughout the circuit.
How do i reduce the noise in the transmitter? How to i make sure whether the data from transmitter is transit or not? Is it possible transmitter transmitted data, but receiver cannot receive it? Any solution? Thank you ![]()
These coding is given in the website.
Transmitter Coding:
pinMode(3,OUTPUT);
send("Ultrasonic communication by Zola Lab\n");
send("Hello World\n\n");
void send(String msg)
byte ch;
unsigned int pos = 0;
unsigned int sz = msg.length();
while(pos<sz)
ch = msg.charAt(pos);
Serial.print((char)ch);
tone(3,40000);
delay(10);
noTone(3);
for(int i=0;i<8;i++)
boolean b;
b = bitRead(ch,7-i);
// Serial.print (b);
if(b)
tone(3,40000);
delay(2);
tone(3,40000);
delay(4);
noTone(3);
delay(11);
pos++;
Receiver Coding :
int pos = 0;
unsigned char CH = 0;
unsigned int bits1 = 0;
boolean capture = false;
pinMode(5,INPUT_PULLUP);
if(digitalRead(5))
bits1 = 0;
unsigned long deltaT = millis();
while(millis()-deltaT <= 10) if(digitalRead(5)) bits1 ++;
Serial.println(bits1);
if(capture)
boolean b = 0;
if(bits1 > 290 && bits1 < 600) b = 0;
if(bits1 > 20 && bits1 < 290) b = 1;
if(b) bitSet(CH,7-pos); else bitClear(CH,7-pos);
Serial.print(b);
pos++;
if(pos == 8)
Serial.print((char)CH);
pos = 0;
capture = false;
if(bits1 > 600)
capture = true;
pos = 0;
