Ultrasonic sensor aj-sr04m
i have been trying to work with Waterproof ultrasonic sensor AJ-SR04m but i am not getting any genuine outputs from it .I have tried its mode 1 which requires open ckt. i.e no short ckt. at R19 .
I am currently using Arduino UNO as the microcontroller .
IF anyone has previously worked with it successfully .Kindly help.
The code I am using :-
#define TRIG_PIN 9  // Pin connected to Trig
#define ECHO_PIN 8  // Pin connected to Echo
  Serial.begin(9600);       // Initialize Serial Monitor
  pinMode(TRIG_PIN, OUTPUT); // Set Trig as output
  pinMode(ECHO_PIN, INPUT);  // Set Echo as input
  Serial.println("AJ-SR04M in HR-04 Trigger Mode Initialized");
  // Trigger the ultrasonic pulse
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  // Measure the duration of the pulse
  long duration = pulseIn(ECHO_PIN, HIGH);
  // Calculate the distance in cm
  float distance = (duration * 0.034) / 2;
  // Display the distance on the Serial Monitor
  Serial.print("Distance: ");
  Serial.print(distance);
  Serial.println(" cm");
  Serial.print("Pulse duration: ");
  Serial.println(duration);
  delay(1000); // Wait for half a second before the next measurement
what host microcontroller are you using?
how have you connected the AJ-SR04m to the host
post your code using code tags e.g. click < CODE > and paste you code where it says 'type or paste code here
Thanks .....i have edited my original question so it is better visible now.
here is code I used with the UNO trigger connected to pin 12 and echo to pin 11
// Arduino - simple sonar distance demonstrator using ultrasocic transducer
//  trigger connected to pin 12 and echo to pin 11
// the setup function runs once when you press reset or power the board
  pinMode(12, OUTPUT);  // trigger pulse
  pinMode(11, INPUT);   // echo pulse
// the loop function runs over and over again forever
    // trigger pulse high approx 10 microseconds
    digitalWrite(12, HIGH);   // HIGH is the voltage level
   // now trigger low
    digitalWrite(12, LOW);    // voltage LOW
    // wait for echo pulse to go high
    while(!digitalRead(11)) ;
    // start timer
    unsigned long StartTime = micros();
    // wait for end of echo pulse (goes low)
    while(digitalRead(11)) ;
    unsigned long CurrentTime = micros();
    // calculate length of echo pulse in microseconds
    unsigned long HighLevelTime = CurrentTime - StartTime;
    // calculate distance High level time * vecocity (340M/sec)/2
    float distance=HighLevelTime*340.0/20000;  // in cm
    Serial.print("ADRM1 Time ");
    Serial.print(HighLevelTime, DEC);
    Serial.print(" microseconds, distance ");
    Serial.print(distance, 2);
    delay(1000);              // short delay before next pulse
Do i need to use any particular mode for this one ?like there are 5 modes on this module .
if R19 is open circuit should be in mode 1 (the default) GP10 using trigger and echo
running the code of post 5 on a UNO as I vary the distance of sensor from a flat surface gives
ADRM1 Time 1412 microseconds, distance 24.00 cm
ADRM1 Time 1428 microseconds, distance 24.28 cm
ADRM1 Time 1464 microseconds, distance 24.89 cm
ADRM1 Time 1888 microseconds, distance 32.10 cm
ADRM1 Time 2356 microseconds, distance 40.05 cm
ADRM1 Time 2952 microseconds, distance 50.18 cm
ADRM1 Time 3516 microseconds, distance 59.77 cm
ADRM1 Time 4012 microseconds, distance 68.20 cm
ADRM1 Time 4528 microseconds, distance 76.98 cm
ADRM1 Time 5344 microseconds, distance 90.85 cm
ADRM1 Time 5864 microseconds, distance 99.69 cm
ADRM1 Time 4812 microseconds, distance 81.80 cm
ADRM1 Time 5940 microseconds, distance 100.98 cm
ADRM1 Time 4132 microseconds, distance 70.24 cm
ADRM1 Time 5640 microseconds, distance 95.88 cm
ADRM1 Time 8164 microseconds, distance 138.79 cm
ADRM1 Time 8084 microseconds, distance 137.43 cm
Hi, @a3ya
Can I ask why you are not using the NewPing Library that will do most of what you want?
https://docs.arduino.cc/libraries/newping/
It does all the pulse timing and distance measurements.
Tom... Thanks.. Tom... :grinning: :+1: :coffee: :australia:
haha ....thanks Tom for the suggestion.I really liked your tom....thanks...tom.
i came across the newping library but i did not want to use it cause firstly it is so so much easier to use this ultrasonic and i wanted to do it raw and not using library .cause the working and communication is so easy for this module .
and secondly i just wanted to check thesensor if it was working or not .Originally i want to integrate it with the rpi4b but there it was not working so tried it on arduino just to check its functionality .
thanks for the pic "horace".I will surely now try it after 3-4 days and will tell you but as much as i can see in this image i was doing the same and used the same code given by code but my readings were not changing idk why ...what you think might be possible reason .
i was giving 5v and trigger on 12 and echo on pin 11 of arduino UNO but still no result .
