Aj-sr04m 0cm problem
Hello, I have been using a JSN SR04T model ultrasonic as a parking sensor until now. But this card is broken, the new card I ordered is AJ-SR04M model but no matter what I do, I cannot get any value. I thought it was broken and ordered a new card but that is the case. It constantly throws 0 value and occasionally throws a measurement value, although rare. I am using UNO and I have tested it with different softwares with correct cables but I have the same problem in all of them. I am using it as mode 0 and I have not made any changes, I am sharing my code, please help. I connect the RX pin to TRIG and the TX pin to ECHO.
By the way, I also tried the code with the NewPing library and no solution was found.
#define TRIG 9 //Module pins
#define ECHO 10
#define motor 11
  Serial.begin(9600); // Serial monitoring
  pinMode(TRIG, OUTPUT); // Initializing Trigger Output and Echo Input
  pinMode(ECHO, INPUT_PULLUP);
  pinMode(motor, OUTPUT);
    digitalWrite(TRIG, LOW); // Set the trigger pin to low for 2uS
    delayMicroseconds(2);
    digitalWrite(TRIG, HIGH); // Send a 10uS high to trigger ranging
    delayMicroseconds(20);
    digitalWrite(TRIG, LOW); // Send pin low again
    int distance = pulseIn(ECHO, HIGH,26000); // Read in times pulse
    distance= distance/58; //Convert the pulse duration to distance
                           //You can add other math functions to calibrate it well
    Serial.print("Distance ");
    Serial.print(distance);
    Serial.println("cm");
   if (distance > 1 && distance < 80)
  digitalWrite(motor, HIGH);
  delay(100);
 else if (distance > 105)
   digitalWrite(motor, LOW);
   delay(100);
    delay(3000);
I don't see any significant differences between the 2 models.
That narrows it down to three completely different boards.
So which Uno do you have. R3, R4, R4 WiFi.
Leo..
I am using Uno, previously the jsn model card was working without any problems with this code. However, one day my card started to give 0 value, I was operating it in a well and it got corrosion and moisture, I cleaned it, it is receiving energy, the red light is solid, now it was sending 0, so I ordered a new card and the AJ model came, when I plug it in, it also gives 0, if you say the problem is with Arduino, I tried with 3 different Arduinos, the result is the same.
Uno R3 model
What "reading" do you get with NO sensor attached?
It shows the same 0, but I tried by attaching different sensors and my sensors are also intact. Finally, I tried a different code and solved it by connecting only the echo end and leaving the trigger idle.
How did that solve the problem?
So probably you had it configured in continuous serial mode.
In any case, post your solution to help next forum member dealing with same issue.
It started to create problems again, my connection is like this, I actually switched to a new code and I only connect the echo pin, if I connect echo and trigger it throws 0, but if only echo is connected it throws value.But sometimes it starts the motor and never disables it, sometimes it sets a fixed value and after a while it sets ridiculous values ​​like 880cm. Sometimes the motor goes in and out as these values ​​are entered. But it was never like this before, it used to set a fixed value without any problems and the trigger and echo were connected, but now for some reason no matter what I do, the value is set to 0 in every card, every sensor, every connection and every software.
const int sensorPin = 2; // AJ-SR04M'nin RX/TRIG ve TX/ECHO pinlerini Arduino'nun 2 numaralı dijital pinine bağlayın
const int motorPin = 9;  // Motor kontrol için Arduino'nun 9 numaralı dijital pinini kullanacağız (PWM pini olabilir)
long duration;
int distance;
  pinMode(sensorPin, OUTPUT);
  pinMode(motorPin, OUTPUT); // Motor pinini çıkış olarak ayarla
  // 1. Kısa bir LOW darbe gönder
  digitalWrite(sensorPin, LOW);
  // 2. 10 mikrosaniye sürecek bir HIGH tetikleme darbesi gönder
  digitalWrite(sensorPin, HIGH);
  delayMicroseconds(10);
  // 3. Pini giriş olarak ayarla
  pinMode(sensorPin, INPUT);
  // 4. Yüksek pulsun süresini ölç
  duration = pulseIn(sensorPin, HIGH);
  // 5. Mesafeyi hesapla
  distance = duration * 0.0343 / 2;
  // 6. Seri monitöre mesafeyi yazdır
  Serial.print("Mesafe: ");
  Serial.println(" cm");
  // 7. Mesafe kontrolüne göre motoru çalıştır veya durdur
  if (distance > 1 && distance < 125) {
    digitalWrite(motorPin, HIGH); // Mesafe 0 ile 120 cm arasındaysa motoru çalıştır
    Serial.println("Motor ÇALIŞIYOR");
    delay(100);
  } else if (distance > 140) {
    digitalWrite(motorPin, LOW);
    Serial.println("Motor DURDU");
    delay(100);
  delay(3000); // Okumalar arasında kısa bir gecikme
Remove all the motor related from your setup until you have fully working distance output.
What you have on pad labeled R19, nothing?
The R19 resistor is empty, if I connect the sensor correctly, it always gives distance 0 in the form of vcc - gnd - trigger - echo. My card is new and I tried other cards and got the same result. However, if I disable the trigger pin, I can get a value.
Worth nothing if the value is not correct. Also, the code you linked above leaves the pin as input after first shot.
Are you sure you don't have tx / rx wrong? Try to swap them and use the "original" code.
Show a wiring diagram.
