Dear Perry,
Thanks for your quick reply. The above are the compilation results.
Anyways, here is the code:
// LIS203DL: MEMS digital output motion sensor:
// ultra-low-power high-performance three-axis "nano" accelerometer
// read accelaration sensor and print serial
// STM32F4 Discovery
// accelerometer: LIS203DL ( included in STM32F4, some boards may have the LIS3DSH )
// April 2017, ChrisMicro
#include <SPI.h>
#define SERIALINTERFACE SerialUSB
#define CS PE3
void accelerometer_SPI_select()
digitalWrite(CS, LOW); // 0=SPI communication mode, 1=SPI IDLE MODE
delayMicroseconds(50);
void accelerometer_SPI_release()
digitalWrite(CS, HIGH);
#define READREGISTERCOMMAND 0x80
uint8_t spiRead(uint8_t registerAddress)
uint8_t r;
accelerometer_SPI_select();
SPI.transfer( registerAddress | READREGISTERCOMMAND );
delayMicroseconds(500);
r = SPI.transfer(0); // dummy write, data read
accelerometer_SPI_release();
return r;
SERIALINTERFACE.begin(9600);
while(SERIALINTERFACE.available()==0)
SERIALINTERFACE.println("\npess any key to start");
SERIALINTERFACE.println("\n( on Arduino Serial Monitor press space the button 'send' on the right )");
SERIALINTERFACE.println("");
SERIALINTERFACE.println("\n accelerometer");
// configure SPI
pinMode(CS, OUTPUT);
SPI.begin();
SPI.setDataMode(SPI_MODE3);
SPI.setBitOrder(MSBFIRST);
// print sensor informatiion
SERIALINTERFACE.print("INFO1 register: "); SERIALINTERFACE.println( spiRead(0x0D), HEX);
SERIALINTERFACE.print("INFO2 register: "); SERIALINTERFACE.println( spiRead(0x0E), HEX);
uint8_t whoAmI=spiRead(0x0F);
SERIALINTERFACE.print("WHO AM I register: "); SERIALINTERFACE.print( whoAmI , HEX);
if(whoAmI==0x3B) SERIALINTERFACE.println(" LIS3DSL sensor,detected ");
if(whoAmI==0x3F) SERIALINTERFACE.println(" LIS3DSH sensor detected ");
// configure sensor
SPI.transfer(0x20); // CTRL4 ODR register
delay(10);
SPI.transfer(0x47); // 25 Hz update, enable x,y,z
int32_t x, y, xx, yy, z, zz;
int16_t xg, yg, zg;
x = spiRead(0x28);
xx = spiRead(0x29);
y = spiRead(0x2a);
yy = spiRead(0x2b);
z = spiRead(0x2c);
zz = spiRead(0x2d);
xg = (x + (xx << 8));
yg = (y + (yy << 8));
zg = (z + (zz << 8));
SERIALINTERFACE.print("X: ");
SERIALINTERFACE.print(xg);
SERIALINTERFACE.print(" Y: ");
SERIALINTERFACE.print( yg);
SERIALINTERFACE.print(" Z: ");
SERIALINTERFACE.println(zg);
