have a problem using AT commands via my Sketch.
I flashed the ESP-01 unit I have, and when connecting the unit directly to my RX and TX pins on the Arduino mega, I can use the AT commands via serial monitor. However as soon as I try to move the pins and use SoftwareSerial.h on any other pins, I can communicate with the module.
I have looked at examples, from really basic to full on web services, and none of them work, if I connect the RX and TX from the ESP to my Arduino in the correct locations as defined. The AT commands are not processed.
I have tried swapping the RX and TX connections, still with no results. I know the AT commands work, as I can manually enter them, just not using a sketch.
Below is one of the may examples I tried with no results at all.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3); //RX,TX
void setup(){
mySerial.begin(115200);
mySerial.write("AT\r\n");
long b=mySerial.read();
Serial.println(b);
mySerial.print("AT\r\n");
b=mySerial.read();
Serial.println(b);
mySerial.println("AT\r\n");
b=mySerial.read();
Serial.println(b);
void loop(){
if(Serial.available()>0){
byte b=Serial.read();
mySerial.println(b);
if(mySerial.available()>0){
byte b=mySerial.read();
Serial.println(b);
Looking at serial monitor I get these results.
09:32:47.346 -> -1
09:32:48.346 -> -1
09:32:49.331 -> -1
When I connect directly to my RX and TX pins I can run AT commands like below
09:54:32.148 -> AT
09:54:32.148 ->
09:54:32.148 -> OK
09:54:39.175 -> AT+GMR
09:54:39.175 -> AT version:1.1.0.0(May 11 2016 18:09:56)
09:54:39.175 -> SDK version:1.5.4(baaeaebb)
09:54:39.175 -> Ai-Thinker Technology Co. Ltd.
09:54:39.175 -> Jun 13 2016 11:29:20
09:54:39.175 -> OK
IIdon't know where I am going wrong here, for some reason it does not seem like my ESP-01 likes "Software Serial". I have 5 units all of them giving the same results. Showing me its something I am doing wrong. With all of this said, how do I get my AT commands to work from my sketch? do i have to reset the unit in setup, or is my code just completely wrong?
This is just testing, AT commands. If I get this to work I can add the rest of the code. Since there is no point in writing a entire sketch if I cant get the basic command to work.
