i've been experimenting with sending variables over multiple frames and receiving said frames on another Arduino
The hardware setup consists of 2 ESP32s and MCP2515s wired up over SPI
here are the sender and receiver code respectively. The problem here is that the sender properly sends 5 frames but the reciever recieves only the 1st one
the library used is GitHub - autowp/arduino-mcp2515: Arduino MCP2515 CAN interface library
Sender
#include <SPI.h>
#include <mcp2515.h>
int cyc1;
int cyc2;
int cyc3;
int cyc4;
int cyc5;
int cyc6;
int cyc7;
int cyc8;
int volt1;
int volt2;
int volt3;
int volt4;
int curr1;
int curr2;
int curr3;
int curr4;
struct can_frame canMsg1;
struct can_frame canMsg2;
struct can_frame canMsg3;
struct can_frame canMsg4;
struct can_frame canMsg5;
MCP2515 mcp2515(5);
int chunkSize = 255;
canMsg3.can_id = 0xCC;
canMsg3.can_dlc = 8;
canMsg4.can_id = 0xDD;
canMsg4.can_dlc = 8;
canMsg5.can_id = 0xEE;
canMsg5.can_dlc = 1;
SPI.begin();
mcp2515.reset();
mcp2515.setBitrate(CAN_1000KBPS, MCP_8MHZ);
mcp2515.setNormalMode();
Serial.println("Example: Write to CAN");
canMsg1.can_id = 0xAA;
canMsg1.can_dlc = 8;
canMsg1.data[0] = 'S';
canMsg1.data[1] = 'E';
canMsg1.data[2] = 'R';
canMsg1.data[3] = 'I';
canMsg1.data[4] = 'A';
canMsg1.data[5] = 'L';
canMsg1.data[6] = 'N';
canMsg1.data[7] = '0';
canMsg2.can_id = 0xBB;
canMsg2.can_dlc = 8;
canMsg2.data[0] = 'Y';
canMsg2.data[1] = 'Y';
canMsg2.data[2] = 'Y';
canMsg2.data[3] = 'Y';
canMsg2.data[4] = 'M';
canMsg2.data[5] = 'M';
canMsg2.data[6] = 'D';
canMsg2.data[7] = 'D';
mcp2515.sendMessage(&canMsg1);
int bms_voltage_can=693;
int bms_current_can=121;
int bms_soc_can=50;
int cycles_can=256;
int numSplits_volt = bms_voltage_can / 255;
int remainder_volt = bms_voltage_can % 255;
// Create an array to store the split variables
int splitVars_volt[numSplits_volt + 1];
// Initialize all the split variables to 255
for (int i = 0; i < numSplits_volt; i++) {
splitVars_volt[i] = 255;
// Set the last split variable to the remainder
splitVars_volt[numSplits_volt] = remainder_volt;
Serial.println("Voltage");
// Print the split variables
for (int i = 0; i <= numSplits_volt; i++) {
Serial.println(splitVars_volt[i]);
int numSplits_curr = bms_current_can / 255;
int remainder_curr = bms_current_can % 255;
int splitVars_curr[numSplits_curr + 1];
for (int i = 0; i < numSplits_curr; i++) {
splitVars_curr[i] = 255;
splitVars_curr[numSplits_curr] = remainder_curr;
Serial.println("Current");
for (int i = 0; i <= numSplits_curr; i++) {
Serial.println(splitVars_curr[i]);
int numSplits_cycles = cycles_can / 255;
int remainder_cycles = cycles_can % 255;
int splitVars_cycles[numSplits_cycles + 1];
for (int i = 0; i < numSplits_cycles; i++) {
splitVars_cycles[i] = 255;
splitVars_cycles[numSplits_cycles] = remainder_cycles;
Serial.println("Cycles");
for (int i = 0; i <= numSplits_cycles; i++) {
Serial.println(splitVars_cycles[i]);
canMsg3.data[0] = splitVars_volt[0];
canMsg3.data[1] = splitVars_volt[1];
canMsg3.data[2] = splitVars_volt[2];
canMsg3.data[3] = splitVars_volt[3];
canMsg3.data[4] = splitVars_curr[0];
canMsg3.data[5] = splitVars_curr[1];
canMsg3.data[6] = splitVars_curr[2];
canMsg3.data[7] = splitVars_curr[3];
mcp2515.sendMessage(&canMsg2);
mcp2515.sendMessage(&canMsg3);
canMsg4.data[0] = splitVars_cycles[0];
canMsg4.data[1] = splitVars_cycles[1];
canMsg4.data[2] = splitVars_cycles[2];
canMsg4.data[3] = splitVars_cycles[3];
canMsg4.data[4] = splitVars_cycles[4];
canMsg4.data[5] = splitVars_cycles[5];
canMsg4.data[6] = splitVars_cycles[6];
canMsg4.data[7] = splitVars_cycles[7];
mcp2515.sendMessage(&canMsg4);
canMsg5.data[0]= bms_soc_can;
mcp2515.sendMessage(&canMsg5);
Serial.println("Messages sent");
delay(250);
here is the receiver code
#include <SPI.h>
float bms_voltage;
float bms_current;
int bms_cycles;
int bms_soc;
MCP2515 mcp2515(5);
char s1;
char s2;
char s3;
char s4;
char s5;
char s6;
char s7;
char s8;
char s9;
char s10;
char s11;
char s12;
char s13;
char s14;
char s15;
char s16;
int msgcheck1;
int msgcheck2;
int msgcheck3;
int msgcheck4;
int msgcheck5;
int receivedData_check;
SPI.begin();
mcp2515.reset();
Serial.println("------- CAN Read ----------");
Serial.println("ID DLC DATA");
if (mcp2515.readMessage(&canMsg1) == MCP2515::ERROR_OK) {
if (canMsg1.can_id == 0xAA) { //printout only message frame 0x18A
Serial.println("Data 1 Recieved");
s1 = canMsg1.data[0];
s2 = canMsg1.data[1];
s3 = canMsg1.data[2];
s4 = canMsg1.data[3];
s5 = canMsg1.data[4];
s6 = canMsg1.data[5];
s7 = canMsg1.data[6];
s8 = canMsg1.data[7];
delay(200);
Serial.print(" ");
if (mcp2515.readMessage(&canMsg2) == MCP2515::ERROR_OK) {
if (canMsg2.can_id == 0xBB) { //printout only message frame 0x18A
Serial.println("Data 2 Recieved");
s9 = canMsg2.data[0];
s10 = canMsg2.data[1];
s11 = canMsg2.data[2];
s12 = canMsg2.data[3];
s13 = canMsg2.data[4];
s14 = canMsg2.data[5];
s15 = canMsg2.data[6];
s16 = canMsg2.data[7];
Serial.print(" ");
delay(200);
if (mcp2515.readMessage(&canMsg3) == MCP2515::ERROR_OK) {
if (canMsg3.can_id == 0xCC) { //printout only message frame 0x18A
Serial.println("Data 3 Recieved");
int vol1 = canMsg3.data[0];
int vol2 = canMsg3.data[1];
int vol3 = canMsg3.data[2];
int vol4 = canMsg3.data[3];
int curr1 = canMsg3.data[4];
int curr2 = canMsg3.data[5];
int curr3 = canMsg3.data[6];
int curr4 = canMsg3.data[7];
Serial.print(" ");
delay(200);
bms_voltage = (vol1 + vol2 + vol3 + vol4) / 10;
bms_current = (curr1 + curr2 + curr3 + curr4) / 10;
Serial.println(bms_voltage);
Serial.println(bms_current);
if (mcp2515.readMessage(&canMsg4) == MCP2515::ERROR_OK) {
if (canMsg4.can_id == 0xDD) { //printout only message frame 0x18A
Serial.println("Data 4 Recieved");
int cyc1 = canMsg4.data[0];
int cyc2 = canMsg4.data[1];
int cyc3 = canMsg4.data[2];
int cyc4 = canMsg4.data[3];
int cyc5 = canMsg4.data[4];
int cyc6 = canMsg4.data[5];
int cyc7 = canMsg4.data[6];
int cyc8 = canMsg4.data[7];
delay(200);
bms_cycles = cyc1 + cyc2 + cyc3 + cyc4 + cyc5 + cyc6 + cyc7 + cyc8;
Serial.println(bms_cycles);
if (mcp2515.readMessage(&canMsg5) == MCP2515::ERROR_OK) {
if (canMsg5.can_id == 0xEE) { //printout only message frame 0x18A
Serial.println("Data 5 Recieved");
canMsg5.data[0] = bms_soc;
delay(200);
Serial.println(bms_soc);
Serial.print(" ");
delay(250);
char SerialNo[] = { s1, s2, s3, s4, s5, s6, s7, s8, s9, s10, s11, s12, s13, s14, s15, s16, '\0' };
Serial.println(SerialNo);
Serial.println(" ");
