Unable to update GC9A01A tft for GPS project
Hello! First time posting here, so I hope I go about this correctly.
I'm trying to use a GC9A01A tft display for a basic GPS project, I'm wanting it to display speed, lat, long, etc. on the screen. I am able to get it to display a basic GUI on the screen during the setup, however whenever I try to put parsed information on the screen in the main loop section, it doesn't print on the screen at all.
What confuses me to no end is that I'm able to display the parsed information on the serial monitor, but once I try to display it on the TFT display, it doesn't work. I'm honestly a complete novice, so feel free to treat me like a total idiot, lol. Hope someone can help with my predicament. Here's hoping I'm just missing something simple.
Controller: Elegoo uno r3
GPS module: Adafruit ultimate GPS breakout v3
display: GC9A01A TFT
Librarys in use:
  • Adafruit_GFX.h
  • Adafruit_GC9A01A.h
  • SPI.h
  • Adafruit_GPS.h
  • SoftwareSerial.h
#include <Adafruit_GFX.h>
#include <Adafruit_GC9A01A.h>
#include <SPI.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
// Example Pin Connections (Adjust for your board)
#define TFT_CS    2
#define TFT_DC    1
#define TFT_RST   5
#define TFT_BL    3
Adafruit_GC9A01A tft(TFT_CS, TFT_DC, TFT_RST);
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO  true
int obtainedFix = 0;
  tft.begin();
  tft.setRotation(1); // Adjust orientation
  tft.fillScreen(GC9A01A_BLACK);
  pinMode(TFT_BL, OUTPUT);
  digitalWrite(TFT_BL, HIGH);
  //Start up screen, Hello world!
  tft.setCursor(50, 110);
  tft.setTextColor(GC9A01A_WHITE);
  tft.setTextSize(2);
  tft.println("Hello World!");
  tft.setCursor(40, 140);
  tft.setTextSize(1);
  tft.println("Initializing.");
  tft.println("Initializing..");
  tft.println("Initializing...");
  delay(500); //Yes I know this is silly, but Let me have this.
  //UI stuff
  tft.setTextColor(GC9A01A_RED);
  tft.setTextSize(2);
  tft.setCursor(50, 25);
  tft.println("FIX");
  tft.setCursor(25, 50);
  tft.println("KTS:");
  tft.setCursor(25, 80);
  tft.println("Lat:");
  tft.setCursor(13, 110);
  tft.println("Long:");
  tft.setCursor(13, 140);
  tft.println("Sats:");
  //~~~~~~~~~~~~~~~~~~~~~~~~~~~~ GPS & SERIAL START-UP
  delay(2000);
  Serial.println("Hello, how are you? I'm stressed, and hope this will eventually work! Turning on GPS...");
  GPS.begin(9600);
    GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA); //INFO TYPE: RMC GGA
    GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); //Update rate
    GPS.sendCommand(PGCMD_ANTENNA); //ANTENNA UPDATES.
  // Ask for firmware version
  mySerial.println(PMTK_Q_RELEASE);
uint32_t timer = millis();
char c = GPS.read();
  if ((c) && (GPSECHO))
    Serial.write(c);
  // if a sentence is received, we can check the checksum, parse it...
  if (GPS.newNMEAreceived()) {
    if (!GPS.parse(GPS.lastNMEA()))
      return;
//Print parsed data onto screen
  if (millis() - timer > 1000) {
    timer = millis(); // reset the timer
    Serial.print("Fix: "); Serial.println((int)GPS.fix);
      if (GPS.fix == true){
      if (obtainedFix == 0){
      Serial.println("SEE? IT WORKS WITH SERIAL. WHY ISN'T IT UPDATING THE SCREEN");
      tft.setTextColor(GC9A01A_GREEN);
      tft.print("FIX");
      obtainedFix ++;
Pop quiz: which pin is used for Serial Tx on an Uno R3?
Okay, you got me there. Serial Tx is on digital pin 1.
Should I move my TFT_DC over to a different pin?
Or move the GPS Tx/Rx over to pins 1/0 instead of using the software serial defined pins?
Thanks for the reply by the way.
You're not the first to make that mistake, trust me. :slightly_smiling_face:
Either option will work, but using 0/1 for the GPS will mean you'll have to disconnect it each time you upload. And you wouldn't be able to use Serial.
Either way, move TFT_DC elsewhere.
Alright, I've shifted pins for CS, DC, BL for the TFT over 1 each. (TFT DC is now 2, CS 3, etc.)
Aaaaaand... It works????? Welp. I feel very stupid now. Thanks for the help! I suppose I'll post here again if I run into any other problems with my lacking intelligence, lol.
