tinyGPS++ data on a TFT display
Hello forum,
working on a new project, I need to read on an SPI TFT display some GPS data received from a NEO-6M module.
I can get the GPS raw data on the serial monitor, but can't find a way to show the live data on the TFT.
I've been reading everywhere, and checking examples, I understand that I need to convert the NEMA data to some other type of variable in order to show them on the display, but I'm stuck.....and it's so frustrating......
Any help would be really appreciated.
Thanks
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <TFT.h>
#include <SPI.h>
#define cs   10
#define dc   9
#define rst  8
// create an instance of the library
TFT TFTscreen = TFT(cs, dc, rst);
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
  ss.begin(GPSBaud);
  //initialize the library
  TFTscreen.begin();
  // clear the screen with a black background
  TFTscreen.background(0, 0, 0);//TFTscreen.background(r, g, b);In which, r, g and b are the RGB values for a given color
  // set the font size
  TFTscreen.setTextSize(2);
  //TFTscreen.stroke(255,255,255); // COLORE TESTO BIANCO
  // set a random font color
  TFTscreen.stroke(255,255,0); // COLORE TESTO CELESTE
  // write the text in the middle of the screen
  TFTscreen.text("WWLOC", 3, 2);
  TFTscreen.text("UTC", 3, 20);
  TFTscreen.text("DATE", 3, 38);
  TFTscreen.text("ALT(m)", 3, 56);
  TFTscreen.text("SATs(#)", 3, 74);
  TFTscreen.text("PA(V)", 3, 92);
  TFTscreen.text("PA(degC)", 3, 110);
  // This sketch displays information every time a new sentence is correctly encoded.
  while (ss.available() > 0){
    gps.encode(ss.read());
    if (gps.location.isUpdated()){
      // Latitude in degrees (double)
      Serial.print("Latitude= ");
      Serial.print(gps.location.lat(), 6);
      // Longitude in degrees (double)
      Serial.print(" Longitude= ");
      Serial.println(gps.location.lng(), 6);
      // Raw latitude in whole degrees
      Serial.print("Raw latitude = ");
      Serial.print(gps.location.rawLat().negative ? "-" : "+");
      Serial.println(gps.location.rawLat().deg);
      // ... and billionths (u16/u32)
      Serial.println(gps.location.rawLat().billionths);
      // Raw longitude in whole degrees
      Serial.print("Raw longitude = ");
      Serial.print(gps.location.rawLng().negative ? "-" : "+");
      Serial.println(gps.location.rawLng().deg);
      Serial.println(gps.location.rawLng().billionths);
      // Raw date in DDMMYY format (u32)
      Serial.print("Raw date DDMMYY = ");
      Serial.println(gps.date.value());
      // Year (2000+) (u16)
      Serial.print("Year = ");
      Serial.println(gps.date.year());
      // Month (1-12) (u8)
      Serial.print("Month = ");
      Serial.println(gps.date.month());
      // Day (1-31) (u8)
      Serial.print("Day = ");
      Serial.println(gps.date.day());
      // Raw time in HHMMSSCC format (u32)
      Serial.print("Raw time in HHMMSSCC = ");
      Serial.println(gps.time.value());
      // Hour (0-23) (u8)
      Serial.print("Hour = ");
      Serial.println(gps.time.hour());
      // Minute (0-59) (u8)
      Serial.print("Minute = ");
      Serial.println(gps.time.minute());
      // Second (0-59) (u8)
      Serial.print("Second = ");
      Serial.println(gps.time.second());
      // 100ths of a second (0-99) (u8)
      Serial.print("Centisecond = ");
      Serial.println(gps.time.centisecond());
      // Raw speed in 100ths of a knot (i32)
      Serial.print("Raw speed in 100ths/knot = ");
      Serial.println(gps.speed.value());
      // Speed in knots (double)
      Serial.print("Speed in knots/h = ");
      Serial.println(gps.speed.knots());
      // Speed in miles per hour (double)
      Serial.print("Speed in miles/h = ");
      Serial.println(gps.speed.mph());
      // Speed in meters per second (double)
      Serial.print("Speed in m/s = ");
      Serial.println(gps.speed.mps());
      // Speed in kilometers per hour (double)
      Serial.print("Speed in km/h = ");
      Serial.println(gps.speed.kmph());
      // Raw course in 100ths of a degree (i32)
      Serial.print("Raw course in degrees = ");
      Serial.println(gps.course.value());
      // Course in degrees (double)
      Serial.print("Course in degrees = ");
      Serial.println(gps.course.deg());
      // Raw altitude in centimeters (i32)
      Serial.print("Raw altitude in centimeters = ");
      Serial.println(gps.altitude.value());
      // Altitude in meters (double)
      Serial.print("Altitude in meters = ");
      Serial.println(gps.altitude.meters());
      // Altitude in miles (double)
      Serial.print("Altitude in miles = ");
      Serial.println(gps.altitude.miles());
      // Altitude in kilometers (double)
      Serial.print("Altitude in kilometers = ");
      Serial.println(gps.altitude.kilometers());
      // Altitude in feet (double)
      Serial.print("Altitude in feet = ");
      Serial.println(gps.altitude.feet());
      // Number of satellites in use (u32)
      Serial.print("Number os satellites in use = ");
      Serial.println(gps.satellites.value());
      // Horizontal Dim. of Precision (100ths-i32)
      Serial.print("HDOP = ");
      Serial.println(gps.hdop.value());
The text() function expects string (null terminated character array) data. You can use the itoa() function to convert integer data to a string. Use the drostrf() function to convert float (double) data to a string. Consult the TinyGPS++ source to see the data types.
The TinyGPS++ library do it all for you.
Consult the TFT.h library how to display value on the screen.
Does your TFT library support the print() function?
The reference for the TFT library.
Consider using TFTscreen.setCursor() and TFTscreen.print().
Simple code such as;
TFTscreen.setCursor(0,0);
TFTscreen.print("Latitude = ");
TFTscreen.print(gps.location.lat(), 6);
might be worth a try ..............
