Unable to upload code:: Failed chip erase: uploading error
I am trying to upload my code to ATMEGA2560 using Ardino UNO "Arduino as ISP" programmer. When I upload the ISP code to the Arduino UNO, the code is uploaded to the Arduino UNO but when I try to reset the ATMEGA2560 in order to burn the bootloader, the reset button LED doesn't blink. I get the following error when I burn the bootloader:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Failed chip erase: uploading error: exit status 1
Welcome and thanks for using code tags for the output :+1:
Are you burning the bootloader to an Arduino Mega or a board that you designed using the ATmega2560 processor? If the former, is there a reason?
Please enable verbose output during upload and disable verbose output during compilation under file/preferences in the IDE, burn the bootloader and post the complete output here.
The settings that you should use:
Target board: Arduino Mega.
Programmer: Arduino as ISP.
Port: Arduino Uno's port.
See also https://docs.arduino.cc/built-in-examples/arduino-isp/ArduinoISP/
That should be automatic; no need to manually reset the Mega's processor.
Thank you for the response! I am burning the bootloader to the ATMEGA2560 of the Firebird V as it is a criteria for a competition. I have posted the complete output here:
"C:\Users\stach\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\stach\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega2560 -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\stach\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude done.  Thank you.
We were finally able to solve the problem by restoring the bootloader in the Firebird V by following the tutorial which I have linked here. Thank you for your time.
