hello, I've found a code where you can write some value from the code in Arduino IDE, even it has their own library it's called "modbus_slave_HMI_Samkoon_V1.0.h"
#ifndef BUFFER_SIZE
#define BUFFER_SIZE 64
#endif
#ifndef ID_slave
#define ID_slave 01
#endif
byte RxData[BUFFER_SIZE];
uint8_t RxLength = 0;
byte Address_0x[BUFFER_SIZE];
byte Address_1x[BUFFER_SIZE];
uint16_t Address_3x[BUFFER_SIZE];
uint16_t Address_4x[BUFFER_SIZE];
byte TxData[BUFFER_SIZE];
bool bitRead_0x(uint16_t add_0x);
void bitWrite_0x(uint16_t add_0x, uint8_t value);
void bitSet_0x(uint16_t add_0x);
void bitClear_0x(uint16_t add_0x);
uint16_t Read_4x(uint16_t add_4x);
void Write_4x(uint16_t add_4x, uint16_t value);
void modbus_RTU_slave_HMI_samkoon(uint8_t *, uint8_t);
uint16_t CRC16(uint8_t *, uint8_t);
void ResPonse_0x01(uint8_t *, uint8_t);
void ResPonse_0x05(uint8_t *, uint8_t);
void ResPonse_0x03(uint8_t *, uint8_t);
void ResPonse_0x06(uint8_t *, uint8_t);
void sendData(uint8_t *, uint8_t);
bool bitRead_0x(uint16_t add_0x) {
return(bitRead(Address_0x[add_0x/8],add_0x%8));
void bitWrite_0x(uint16_t add_0x, uint8_t value) {
if (value ==0) bitClear(Address_0x[add_0x/8],add_0x%8);
else bitSet(Address_0x[add_0x/8],add_0x%8);
void bitSet_0x(uint16_t add_0x) {
void bitClear_0x(uint16_t add_0x) {
uint16_t Read_4x(uint16_t add_4x){
return(Address_4x[add_4x]);
void Write_4x(uint16_t add_4x, uint16_t value){
Address_4x[add_4x]=value;
void serialEvent() {
RxLength = Serial.readBytes(RxData, BUFFER_SIZE);
if (RxLength > 0) {
modbus_RTU_slave_HMI_samkoon(RxData, RxLength);
void modbus_RTU_slave_HMI_samkoon(uint8_t *Data_Modbus, uint8_t DataLen) {
uint16_t crc = CRC16(Data_Modbus, DataLen - 2); // crc check
uint16_t crc_Receive = Data_Modbus[DataLen - 2] << 8 | Data_Modbus[DataLen - 1];
if ((Data_Modbus[0] == ID_slave) && (crc == crc_Receive)) {
switch (Data_Modbus[1]) {
case 0x01:
ResPonse_0x01(Data_Modbus, DataLen);
case 0x03:
ResPonse_0x03(Data_Modbus, DataLen);
case 0x05:
ResPonse_0x05(Data_Modbus, DataLen);
case 0x06:
ResPonse_0x06(Data_Modbus, DataLen);
void ResPonse_0x01(uint8_t *Data_Modbus, uint8_t DataLen) {
uint16_t add_register = Data_Modbus[2] << 8 | Data_Modbus[3];
uint16_t num_coils = Data_Modbus[4] << 8 | Data_Modbus[5];
uint8_t Byte_Count = (num_coils - 1) / 8 + 1;
TxData[0] = ID_slave;
TxData[1] = 0X01; //phan hoi 0x01
TxData[2] = Byte_Count; //SO BYTE TRUYEN
int i = 0;
for (i = 0; i < Byte_Count; i++) {
TxData[i + 3] = Address_0x[add_register + i];
uint16_t crc = CRC16(TxData, Byte_Count + 3);
TxData[i + 3] = highByte(crc); // >> 8) & 0xFF; // CRC HIGH
TxData[i + 4] = lowByte(crc); // & 0xFF; // CRC LOW
sendData(TxData, Byte_Count + 5);
void ResPonse_0x05(uint8_t *Data_Modbus, uint8_t DataLen) {
uint16_t add_coil = Data_Modbus[2] << 8 | Data_Modbus[3];
uint16_t add_register_0x = add_coil / 8;
uint16_t add_register_0x_bit = add_coil % 8;
if (Data_Modbus[4] == 0xFF) bitSet(Address_0x[add_register_0x], add_register_0x_bit);
else bitClear(Address_0x[add_register_0x], add_register_0x_bit);
TxData[1] = 0X05; //phan hoi 0x05
TxData[2] = Data_Modbus[2]; //add high
TxData[3] = Data_Modbus[3]; //add low
TxData[4] = Data_Modbus[4]; //Byte high data = 0xFF or 0x00
TxData[5] = Data_Modbus[5]; //Byte low data = 0x00
uint16_t crc = CRC16(TxData, 6);
TxData[6] = highByte(crc); // >> 8) & 0xFF; // CRC HIGH
TxData[7] = lowByte(crc); // & 0xFF; // CRC LOW
sendData(TxData, 8);
void ResPonse_0x03(uint8_t *Data_Modbus, uint8_t DataLen) {
uint16_t num_registers = Data_Modbus[4] << 8 | Data_Modbus[5];
uint8_t Byte_Count = num_registers * 2;
TxData[1] = 0X03; //phan hoi 0x03
TxData[2] = Byte_Count; //num byte
int i = 0;
for (i = 0; i < num_registers; i++) {
TxData[2 * i + 3] = highByte(Address_4x[add_register + i]);
TxData[2 * i + 4] = lowByte(Address_4x[add_register + i]);
TxData[2 * i + 3] = highByte(crc); // >> 8) & 0xFF; // CRC HIGH
TxData[2 * i + 4] = lowByte(crc); // & 0xFF; // CRC LOW
void ResPonse_0x06(uint8_t *Data_Modbus, uint8_t DataLen) {
uint16_t add_4x = Data_Modbus[2] << 8 | Data_Modbus[3];
Address_4x[add_4x] = Data_Modbus[4] << 8 | Data_Modbus[5];
TxData[1] = 0X06; //phan hoi 0x04
TxData[4] = highByte(Address_4x[add_4x]); //data high
TxData[5] = lowByte(Address_4x[add_4x]); //data low
TxData[6] = highByte(crc); //>> 8) & 0xFF; // CRC HIGH
void sendData(uint8_t *DataSend, uint8_t DataLen) {
for (int i = 0; i < DataLen; i++) {
Serial.write(DataSend[i]);
/* Table of CRC values for high–order byte */
static unsigned char auchCRCHi[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81,
0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01,
0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81,
0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01,
0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81,
0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x40
//unsigned uIndex ; /* will index into CRC lookup table */
static char auchCRCLo[] = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7, 0x05, 0xC5, 0xC4,
0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD,
0x1D, 0x1C, 0xDC, 0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32, 0x36, 0xF6, 0xF7,
0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE,
0x2E, 0x2F, 0xEF, 0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1, 0x63, 0xA3, 0xA2,
0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB,
0x7B, 0x7A, 0xBA, 0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0, 0x50, 0x90, 0x91,
0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88,
0x48, 0x49, 0x89, 0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83, 0x41, 0x81, 0x80,
0x40
uint16_t CRC16(uint8_t *puchMsg, uint8_t usDataLen) {
unsigned char uchCRCHi = 0xFF; /* high byte of CRC initialized */
unsigned char uchCRCLo = 0xFF; /* low byte of CRC initialized */
unsigned uIndex; /* will index into CRC lookup table */
//while (usDataLen––) /* pass through message buffer */
while (usDataLen--) {
uIndex = uchCRCHi ^ *puchMsg++; /* calculate the CRC */
uchCRCHi = uchCRCLo ^ auchCRCHi[uIndex];
uchCRCLo = auchCRCLo[uIndex];
return (uchCRCHi << 8 | uchCRCLo);
this is the code that I found (both files must be open when you run the code)
#define ID_slave 1 //ID del esclavo (arduino)
#include "modbus_slave_HMI_Samkoon_V1.0.h" //libreria comunicación
void setup (){
Serial.begin(9600); //monitor serial a 9600 baudios
Serial.setTimeout(100); //
pinMode (13, OUTPUT); //LED D1 A LA DIRECCIÓN DE ENTRADA EN COM1 0x0
pinMode (12, OUTPUT); //LED PRUEBA
pinMode (2, INPUT_PULLUP); //BOTÓN DE ENCENDIDO
pinMode (3, INPUT_PULLUP); //BOTÓN DE APAGADO
void loop(){
bool state_0x0 = bitRead_0x(0);
digitalWrite(13,state_0x0); //dirección de estado en 0x0
if(digitalRead(2)==0) bitSet_0x(0); //set
if(digitalRead(3)==0) bitClear_0x(0); //reset
// mostrar datos en display 8888
int var1 = 1234; //mostrar dato
Write_4x(0,var1); //escribir numero Y MOSTRAR
int var2 = Read_4x(1); //escribir datos
if(var2==38){ //si el valor es igual a 38, el led en el pin 12 enciende, si este es diferente al 38, el led pin 12 no encenderá
digitalWrite(12, HIGH); //condicion para valor == "38"
else{
digitalWrite(12, LOW); //condicion para valor diferente de "38", el led no enciende
I just do this by simulation between the HMI kinco GL070E and my arduino UNO by RS232/modbus
BUT!!!!!! it doesn't work physicaly
Add diagram that I used
