sketch\esp8266-weather-station-color.ino.cpp.o: In function `drawAbout()':
C:\Users\Adm\Documents\Arduino\esp8266-weather-station-color\esp8266-weather-station-color/esp8266-weather-station-color.ino:611: undefined reference to `gmtime'
sketch\esp8266-weather-station-color.ino.cpp.o: In function `getTime(long*)':
libraries\ESP8266_Weather_Station\OpenWeatherMapForecast.cpp.o:(.text._ZN22OpenWeatherMapForecast5valueE6String+0x9e): undefined reference to `gmtime'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
So, it seems to be saying that the function 'gmtime()' is not being found?? How do I solve this issue?
Yes, I appear to have all the necessary libraries installed. Moreover, I have built this same basic project about a year ago, but the supported weather data source changed, so I needed to update the project with the new weather API information. I haven't been able to get this new code compiled.
Check the box next to "Show verbose output during: > compilation
Click "OK"
Sketch > Verify/Compile
After the compilation fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the compilation output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
If the length of the output exceeds the forum's 9000 character limit, save it in a .txt file and post it here as an attachment. If you click the "Reply" button you'll see the "Attachments and other options" link.
