Please read part 1 first.
Master (Surface)
#include <RS485_protocol.h>
#include <SoftwareSerial.h>
SoftwareSerial rs485 (10, 11); // rx pin, tx pin
// Pins
int forePort = A0; //Top fore port thruster PIN for analogRead
int foreStar = A1;
int aftPort = A2;
int aftStar = A3;
int portThruster = A4; // Main port drive thruster pin for analogRead
int starThruster = A5;
const byte ENABLE_PIN = 24; // pin used to set hi and low, transmit or rec
const byte LED_PIN = 13;
//Thrust VAriables
int forePortVal = 1100; //testing levels
int foreStarVal = 1200;
int aftPortVal = 1300;
int aftStarVal = 1400;
int portThrusterVal = 1500;
int starThrusterVal = 1600;
byte forePortValHi, foreStarValHi, aftPortValHi, aftStarValHi, portThrusterValHi, starThrusterValHi; // Hibytes for thrust
byte forePortValLo, foreStarValLo, aftPortValLo, aftStarValLo, portThrusterValLo, starThrusterValLo; // Lowbytes for thrust
//Unions for temp humidity and dewpoint
union temperature
float temp;
byte b[4];
} t;
union humidity
float hum;
byte b[4];
} h;
union dewpoint
float dew;
byte b[4];
} d;
//Sensors
int pressureLvl, lightLvl, xAxis, yAxis, zAxis;
float temperature; //for temp and humidity
float humidity;
float dewpoint;
// callback routines
void fWrite (const byte what)
rs485.write (what);
int fAvailable ()
return rs485.available ();
int fRead ()
return rs485.read ();
rs485.begin (57600);
pinMode (ENABLE_PIN, OUTPUT); // driver output enable
pinMode (LED_PIN, OUTPUT); // built-in LED
} // end of setup
//Thurster pot readings and calibration
forePortVal = analogRead(forePort); // Reads the value from the pot to forePortVal
forePortVal = map(forePortVal, 0, 1023, 4000, 8000); // Calibrates the min max from the pot to correspond with servo pulses 1000 to 2000
//will add other 5 pots
//-------------------------Hi Byte Low Byte creation of variables to be sent over to Slave------
forePortValHi = highByte(forePortVal);
forePortValLo = lowByte(forePortVal);
foreStarValHi = highByte(foreStarVal);
foreStarValLo = lowByte(foreStarVal);
aftPortValHi = highByte(aftPortVal);
aftPortValLo = lowByte(aftPortVal);
aftStarValHi = highByte(aftStarVal);
aftStarValLo = lowByte(aftStarVal);
portThrusterValHi = highByte(portThrusterVal);
portThrusterValLo = lowByte(portThrusterVal);
starThrusterValHi = highByte(starThrusterVal);
starThrusterValLo = lowByte(starThrusterVal);
// assemble message
byte msg [] = {
1, // device 1
2, // turn light on
forePortValHi, // first half of forePortValHi
forePortValLo, // second have of level
foreStarValHi,
foreStarValLo,
aftPortValHi,
aftPortValLo,
aftStarValHi,
aftStarValLo,
portThrusterValHi,
portThrusterValLo,
starThrusterValHi,
starThrusterValLo
// send to slave
digitalWrite (ENABLE_PIN, HIGH); // enable sending
sendMsg (fWrite, msg, sizeof msg);
digitalWrite (ENABLE_PIN, LOW); // disable sending
// receive response
byte buf [24];
byte received = recvMsg (fAvailable, fRead, buf, sizeof buf);
digitalWrite (LED_PIN, received == 0); // turn on LED if error
//Create Sensor varaibles from Hi low
pressureLvl = word(buf [2], buf [3]);
lightLvl = word(buf [4], buf [5]);
xAxis = word(buf [6], buf [7]);
yAxis = word(buf [8], buf [9]);
zAxis = word(buf [10], buf [11]);
t.b[0] = buf [12]; // Send bytes from the buffer to the unions
t.b[1] = buf [13];
t.b[2] = buf [14];
t.b[3] = buf [15];
h.b[0] = buf [16];
h.b[1] = buf [17];
h.b[2] = buf [18];
h.b[3] = buf [19];
d.b[0] = buf [20];
d.b[1] = buf [21];
d.b[2] = buf [22];
d.b[3] = buf [23];
temperature = t.temp; // Pull floats from the union
humidity = h.hum;
dewpoint = d.dew;
Serial.print("Pressure Level = ");
Serial.print(pressureLvl);
Serial.print("\t");
Serial.print("Light Level = ");
Serial.print(lightLvl);
Serial.print("\t");
Serial.print("X Axis = ");
Serial.print(xAxis);
Serial.print("\t");
Serial.print("y Axis = ");
Serial.print(yAxis);
Serial.print("\t");
Serial.print("Z Axis = ");
Serial.print(zAxis);
Serial.print("\t");
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.print("\t");
Serial.print("Humidity = ");
Serial.print(humidity);
Serial.print("\t");
Serial.print("Dewpoint = ");
Serial.println(dewpoint);
} // end of loop
Slave (ROV)
#include <Sensirion.h>
SoftwareSerial rs485 (10, 11); // rx pin, txpin
// Pins
int pressurePin = A15; // for pressure sensor
int lightPin = A14; // for light levels
const uint8_t dataPin = 9; //data pint for temp and humidity
const uint8_t clockPin = 8; // clock pin for temp and humidity
const int xpin = A3; // x-axis
const int ypin = A2; // y-axis
const int zpin = A1; // z-axis
//Thrust VAriables
int forePortVal, foreStarVal, aftPortVal, aftStarVal, portThrusterVal, starThrusterVal; //thruster variables
//Sensors VAriables
float humidity;
float dewpoint;
Sensirion tempSensor = Sensirion(dataPin, clockPin);
int pressureLvl = 0; // for pressure
int lightLvl = 200; // for light level
int xAxis, yAxis, zAxis;
byte hipressureLvl, lopressureLvl, lolightLvl, hilightLvl, loxAxis, hixAxis, loyAxis, hiyAxis, lozAxis, hizAxis, temperature0, temperature1, temperature2, temperature3, humidity0, humidity1, humidity2, humidity3, dewpoint0, dewpoint1, dewpoint2, dewpoint3;
union temperature
float temp;
byte b[4];
} t;
union humidity
float hum;
byte b[4];
} h;
union dewpoint
float dew;
byte b[4];
} d;
rs485.write (what);
int fAvailable ()
int fRead ()
Serial.begin(115200); // for testing only
rs485.begin (57600); // communication 4 RS485
Serial2.begin(115200); // Pololu Servo controller
digitalWrite (ENABLE_PIN, LOW); // Sets pin to low 4 rs485
//Sensor readings
//Pressure sensor
pressureLvl = analogRead(pressurePin);
//Light levels
lightLvl = analogRead(lightPin);
//temp and humidity
tempSensor.measure(&temperature, &humidity, &dewpoint);
// X Y and Z Axis readings
xAxis = analogRead(xpin);
yAxis = analogRead(ypin);
zAxis = analogRead(zpin);
t.temp = temperature;
h.hum = humidity;
d.dew = dewpoint;
//Hi Lo byte creation
hipressureLvl = highByte(pressureLvl); // splits bytes off
lopressureLvl = lowByte(pressureLvl);
hilightLvl = highByte(lightLvl);
lolightLvl = lowByte(lightLvl);
hixAxis = highByte(xAxis);
loxAxis = lowByte(xAxis);
hiyAxis = highByte(yAxis);
loyAxis = lowByte(yAxis);
hizAxis = highByte(zAxis);
lozAxis = lowByte(zAxis);
//Send sensor readings
byte buf [24];
byte received = recvMsg (fAvailable, fRead, buf, sizeof (buf) - 1);
if (received)
if (buf [0] != 1)
return; // not my device
if (buf [1] != 2)
return; // unknown command
byte msg [] = {
0, // device 0 (master)
3, // turn light on command received
hipressureLvl,
lopressureLvl,
hilightLvl,
lolightLvl,
hixAxis,
loxAxis,
hiyAxis,
loyAxis,
hizAxis,
lozAxis,
t.b[0],
t.b[1],
t.b[2],
t.b[3],
h.b[0],
h.b[1],
h.b[2],
h.b[3],
d.b[0],
d.b[1],
d.b[2],
d.b[3]
delay (1);
forePortVal = word(buf [2], buf[3]); // convert the bytes from master
foreStarVal = word(buf [4], buf[5]);
aftPortVal = word(buf [6], buf[7]);
aftStarVal = word(buf [8], buf[9]);
portThrusterVal = word(buf [10], buf[11]);
starThrusterVal = word(buf [12], buf[13]);
Serial.println(forePortVal); // for testing only
} // end if something received
//Thurster values to Servo Controller
set_target(1, forePortVal);
set_target(2, foreStarVal);
set_target(3, aftPortVal);
set_target(4, aftStarVal);
set_target(5, portThrusterVal);
set_target(6, starThrusterVal);
} // end of main loop
void set_target(unsigned char servo, unsigned int target)
Serial2.write(0xAA); //start byte
Serial2.write(0x0C); //device id
Serial2.write(0x04); //command number
Serial2.write(servo); //servo number
Serial2.write(target & 0x7F);
Serial2.write((target >> 7) & 0x7F);
Thank you
Andrew
