Some time ago I've bought the Arduino Uno Board, Revision 2 with ATMEGA328P-PU Mircrocontroller, but I never found the time to play with it, until now.
Today I have installed the Arduino IDE Version 1.6.0 (most recent version) on my Windows PC (Windows 7). Installation of the USB driver went well but when I tried to download the Blink program it didn't even compile. I used the Blink program that came with the IDE, right out of the bix without any modifications. If you need the example code, just check "Files->Examples->01 Basics->Blink" but the other examples give the same errors.
I am thankfull for any clue how to solve this problem. Could there be anything wrong with the installation? Any compiler options I don't know about?
Here comes the error error log:
Arduino: 1.6.0 (Windows 7), Platine: "Arduino Uno"
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from Blink.ino:18:
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1167:26: error: 'uint_farptr_t' was not declared in this scope
extern size_t strlen_PF (uint_farptr_t src) ATTR_CONST; /* program memory can't change /
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1168:27: error: 'uint_farptr_t' was not declared in this scope
extern size_t strnlen_PF (uint_farptr_t src, size_t len) ATTR_CONST; / program memory can't change /
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1168:53: error: expected primary-expression before 'len'
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1168:58: error: expression list treated as compound expression in initializer [-fpermissive]
extern size_t strnlen_PF (uint_farptr_t src, size_t len) ATTR_CONST; / program memory can't change */
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1169:37: error: 'uint_farptr_t' has not been declared
extern void *memcpy_PF (void *dest, uint_farptr_t src, size_t len);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1170:37: error: 'uint_farptr_t' has not been declared
extern char *strcpy_PF (char *dest, uint_farptr_t src);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1171:38: error: 'uint_farptr_t' has not been declared
extern char *strncpy_PF (char *dest, uint_farptr_t src, size_t len);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1172:37: error: 'uint_farptr_t' has not been declared
extern char *strcat_PF (char *dest, uint_farptr_t src);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1173:38: error: 'uint_farptr_t' has not been declared
extern size_t strlcat_PF (char *dst, uint_farptr_t src, size_t siz);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1174:38: error: 'uint_farptr_t' has not been declared
extern char *strncat_PF (char *dest, uint_farptr_t src, size_t len);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1175:39: error: 'uint_farptr_t' has not been declared
extern int strcmp_PF (const char *s1, uint_farptr_t s2) ATTR_PURE;
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1176:40: error: 'uint_farptr_t' has not been declared
extern int strncmp_PF (const char *s1, uint_farptr_t s2, size_t n) ATTR_PURE;
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1177:43: error: 'uint_farptr_t' has not been declared
extern int strcasecmp_PF (const char *s1, uint_farptr_t s2) ATTR_PURE;
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1178:44: error: 'uint_farptr_t' has not been declared
extern int strncasecmp_PF (const char *s1, uint_farptr_t s2, size_t n) ATTR_PURE;
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1179:41: error: 'uint_farptr_t' has not been declared
extern char *strstr_PF (const char *s1, uint_farptr_t s2);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1180:38: error: 'uint_farptr_t' has not been declared
extern size_t strlcpy_PF (char *dst, uint_farptr_t src, size_t siz);
/Arduino/hardware/tools/avr/avr/include/avr/pgmspace.h:1181:36: error: 'uint_farptr_t' has not been declared
extern int memcmp_PF(const void *, uint_farptr_t, size_t) ATTR_PURE;
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:23:0,
from Blink.ino:18:
\MinGW\include/ctype.h: In function 'int isalnum(int)':
\MinGW\include/ctype.h:154:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isalnum(int c) {return __ISCTYPE(c, (_ALPHA|_DIGIT));}
\MinGW\include/ctype.h: In function 'int isalpha(int)':
\MinGW\include/ctype.h:155:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isalpha(int c) {return __ISCTYPE(c, _ALPHA);}
\MinGW\include/ctype.h: In function 'int iscntrl(int)':
\MinGW\include/ctype.h:156:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW iscntrl(int c) {return __ISCTYPE(c, _CONTROL);}
\MinGW\include/ctype.h: In function 'int isdigit(int)':
\MinGW\include/ctype.h:157:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isdigit(int c) {return __ISCTYPE(c, _DIGIT);}
\MinGW\include/ctype.h: In function 'int isgraph(int)':
\MinGW\include/ctype.h:158:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isgraph(int c) {return __ISCTYPE(c, (_PUNCT|_ALPHA|_DIGIT));}
\MinGW\include/ctype.h: In function 'int islower(int)':
\MinGW\include/ctype.h:159:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW islower(int c) {return __ISCTYPE(c, _LOWER);}
\MinGW\include/ctype.h: In function 'int isprint(int)':
\MinGW\include/ctype.h:160:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isprint(int c) {return __ISCTYPE(c, (_BLANK|_PUNCT|_ALPHA|_DIGIT));}
\MinGW\include/ctype.h: In function 'int ispunct(int)':
\MinGW\include/ctype.h:161:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW ispunct(int c) {return __ISCTYPE(c, _PUNCT);}
\MinGW\include/ctype.h: In function 'int isspace(int)':
\MinGW\include/ctype.h:162:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isspace(int c) {return __ISCTYPE(c, _SPACE);}
\MinGW\include/ctype.h: In function 'int isupper(int)':
\MinGW\include/ctype.h:163:65: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isupper(int c) {return __ISCTYPE(c, _UPPER);}
\MinGW\include/ctype.h: In function 'int isxdigit(int)':
\MinGW\include/ctype.h:164:66: error: '_imp____mb_cur_max_dll' was not declared in this scope
__CRT_INLINE int __cdecl __MINGW_NOTHROW isxdigit(int c) {return __ISCTYPE(c, _HEX);}
\MinGW\include/ctype.h: In function 'int isblank(int)':
\MinGW\include/ctype.h:169:12: error: '_imp____mb_cur_max_dll' was not declared in this scope
{return (__ISCTYPE(c, _BLANK) || c == '\t');}
