I've been searching through the forum, but I didn't find any information. Can you use an Atmega328 with UNO bootloader in a Duemilanova board? I own a Duemilanova board, and I can buy Atmegas with the UNO bootloader preloaded, but I don't know if they work with my board.
If you know where I can find some more information, or if it works, it will really help.
Thanks in advance,
Enrique
Nothing on the Duemilanova board would prevent a 328 with a Uno bootloader from functioning properly. You just have to remember to select the Uno board when you want to upload a sketch from the Arduino IDE.
Yes no problem, although make sure you get the latest 'optifix' version. The version that came with my Uno was quite frankly crap, before I found optifix I burnt my Uno with the Duemilanove bootloader because it worked. Once you've done it you need to say the board is a Uno in the IDE which can be a tad confusing.
