Hi there,
I wondered if anybody would be able to help resolve an issue with the current code I'm using to run a DFPlayer Mini and 7 segment display (TM1637) from an Uno. The code currently seems to skip through the mp3's really quickly (0.5 - 1 secs of each song).
Video available here:
Also attaching an image of the circuit.
Thanks for taking a look!
L
/* 04_dfplayer_mp3_test_nextbutton
* This is LCBBs basic mp3 test code (based on DRRobot's DFPlayer code) for sequential
* mp3 playing tests and basic functionality. Other related code including more advnaced
* functioanlity and LED track displays can be found at:
* https://github.com/LetsCodeBlacksburg/arduino-mp3-player
* This version cleans up the playback code a bit and adds
* structure for reading buttons and navigating playlists. This
* version is also best suited for tracking the song # for
* displaying on a display device.
* tweeks-pub1@theweeks.org, 2018-06-27
#include "Arduino.h"
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
// LED Display
#include <TM1637Display.h>
// Module connection pins (Digital Pins). Should match your connections.
#define CLK 8
#define DIO 9
#define TEST_DELAY 20
TM1637Display display(CLK, DIO);
boolean leadingZeros = false;
//// HARDWARE SETTINGS/HOOKUPS
// Hardware wiring of DFPlayer
// DFPlay mini --Vcc(1)--RX(2)--TX(3)--DACR(4)--GND(7) +(6) -(8) ... _BUSY
// Arduino 5v 11* 10* A0 GND | | 12*
// \Spkr/
// * requires 1k resisitor
//DFPlayer mp3 player settings
const int ardRX=10; // The arduino software Receive lins (goes to DFPlayer TX)
const int ardTX=11; // The arduino software Transmit line (goes to DFPlayer RX)
const int dfBusy=12; // From DFPlayer pin 16, active low (HIGH != playing sound)
int sndFile=1; // Sound file pointer (all files must start with 0001 format).
// All files assumed to be in dir named "MP3"
int fileCount=12; // Either set the max # of files here, or load
// it from myDFPlayer.readFileCounts()
// NOTE: readFileCounts() also sees deleted files and is less reliable.
// One way to address is by reformatting the SDcard before re-loading musuc.
int setVol=20; //Set volume value (0~30)
// Set up Arduino control buttons to do stuff here (and in setup)
const int buttonNext = 2;
// Software Serial Pins To DFPlayer
SoftwareSerial mySoftwareSerial(10,11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
//// LARGE SETUP BLOCK
void setup(){
// non MP3 stuff
pinMode(buttonNext, INPUT);
display.setBrightness(0xff);
// Set up DFPlay mini
delay(250);
pinMode(ardRX, INPUT);
pinMode(ardTX, OUTPUT);
pinMode(dfBusy, INPUT);
delay(100);
mySoftwareSerial.begin(9600);
delay(100);
Serial.println(F("DFRobot DFPlayer Setup"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
// Check for DFPlay initialization via softserial
if (!myDFPlayer.begin(mySoftwareSerial)) {
// if it did not work
delay(20);
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
// T-SHOOTING
Serial.print("INFO: player state / file counts: ");
Serial.print(myDFPlayer.readState()); //read mp3 state
Serial.print(" / ");
Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
while(true); // Hang forever if error
// if serial setup worked
Serial.println(F("DFPlayer Mini online."));
Serial.println(F("Reinsert SD card to start playing."));
// configure settings
myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
myDFPlayer.volume(setVol); //Set volume value (0~30).
myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
///// Print Status:
Serial.print("SETUP-INFO: player state= ");
Serial.print(" / volume setting(0-30)= ");
Serial.print(myDFPlayer.readVolume()); //read current volume
Serial.print(" / EQ setting= ");
Serial.print(myDFPlayer.readEQ()); //read EQ setting
Serial.print(" / fileCount= ");
//// MAIN LOOP
// If at the last sound file, then loop back to the top (1)
if (sndFile == (fileCount+1) ) {
sndFile = 1;
// Begin playing the next sound file...
Serial.print("************** PLAYING SONG #");
Serial.println(sndFile);
myDFPlayer.playMp3Folder(sndFile);
display.showNumberDec(sndFile, leadingZeros); // This is it
delay(100); // wait to start
// If DFPlayer _BUSY line is active(low), while/scan for button presses.
if (!digitalRead(dfBusy) == true ){
Serial.println("Player _BUSY, still playing...");
Serial.print("Watching for button presses.");
while(!digitalRead(dfBusy) == true ){
int x=x+1;
if(x%50 == 0)
Serial.print("\n");
Serial.print(".");
if(digitalRead(buttonNext) == LOW){ // If detect buttonNext, go to next song.
sndFile++; // Incriment to the next sound file
if(sndFile>fileCount)
sndFile=1;
myDFPlayer.playMp3Folder(sndFile); // Play it (from the MP3 directory)
Serial.print("\nPlaying file # ");
delay(250);
delay(150);
sndFile++; // Increment to the next sound file
//// printDetail()
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
