I have been having trouble with the serial connection between an Uno and a DY player, so I ran a loopback test last night and I get no response. Not sure if I just need to replace the Uno, or if there are other options. I put a jumper wire between pins 10 and 11 and ran the following code. Also tried pins 12 and 13 adjusting the code to reflect the pin change. It should be noted that I do get "Testing Pins 10/11..." in the serial monitor. Sometimes it prints twice or something like "Tes Pins 10/11..." but no response from the Rx pin. Appreciate any advice.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.begin(9600); // USB Monitor
mySerial.begin(9600); // Software Serial
Serial.println("Testing Pins 10/11...");
mySerial.print("T"); // Send test data out of 11
if (mySerial.available()) {
char c = mySerial.read(); // Read it back into 10
Serial.print("Received: ");
Serial.println(c);
@van_der_decken nailed it, that library is blocking. Here is the part that is getting you:
Transmission (write) is fully blocking:
While a byte is being sent, the CPU is tied up bit-banging each bit at the correct baud rate. Nothing else runs during that time.
You can try the AltSoftSerial or NeoSWerial libraries. The best solution is to use a processor with two asynchronous ports.
Thank you. I found another thread "Loop Back Test - Sticky?" that suggest holding the processor in reset while using terminal. Would this be an effective way of testing Tx Rx on pins 10 & 11?
Hi @analog-ev. I'll provide some sketches you can use to test the basic functionality of the SoftwareSerial interface:
Transmit
# SoftwareSerial Transmit Test
Use for testing SoftwareSerial transmit functionality.
A standard loopback configuration can't be used with SoftwareSerial because it doesn't support transmitting and
receiving data at the same time.
## Circuit
Connect SoftwareSerial TX pin to pin 1 (TX).
## Usage
1. Upload this sketch to the board.
2. Disconnect the USB cable from the board.
3. Connect the SoftwareSerial TX pin to pin 1 on the board (TX)*.
4. Connect the board to your computer with the USB cable.
5. Open Serial Monitor.
6. Select "9600" from the Serial Monitor baud rate menu.
You should now see "Hello, world!" printed at 0.5 Hz to the Serial Monitor output panel.
IMPORTANT: Once you are finished, disconnect the circuit. You must do this before attempting another sketch
upload, as otherwise the circuit may interfere with the upload.
### Footnotes
* This connection may seem wrong, since we must always connect the transmit pin to the receive pin. However, the
"TX" label on pin 1 is in relation to its connection to the board's primary microcontroller. In this case, we are
actually communicating directly between the software serial interface and the board's USB to serial bridge to the PC.
The bridge chip has an RX-TX connection to the board's primary microcontroller, so the pin labeled "TXT" on the board
is actually connected to the RX pin on the bridge chip.
This work is licensed under the CC0 1.0 license:
https://creativecommons.org/publicdomain/zero/1.0/
// See: https://docs.arduino.cc/learn/built-in-libraries/software-serial/
// See: https://docs.arduino.cc/learn/built-in-libraries/software-serial/#limitations-of-this-library
const byte softwareSerialRxPin = 10;
const byte softwareSerialTxPin = 11;
const unsigned int baudRate = 9600;
SoftwareSerial SoftSerial(softwareSerialRxPin, softwareSerialTxPin);
SoftSerial.begin(baudRate);
SoftSerial.println("Hello, world!");
Receive
# SoftwareSerial Receive Test
Use for testing SoftwareSerial receive functionality.
## Usage
3. Connect the SoftwareSerial RX pin to pin 1 on the board (TX).
You should see the onboard LED blink at 0.5 Hz.
unsigned long previousMillis;
byte ledPinState;
pinMode(LED_BUILTIN, OUTPUT);
const char transmitData[] = "hello\r\n";
if (millis() - previousMillis >= 1000) {
previousMillis = millis();
Serial.write(transmitData);
if (SoftSerial.available()) {
delay(10); // Give time for all data to be received.
if (SoftSerial.available() != strlen(transmitData)) {
// Ignore received data of unexpected length.
// Clear the receive buffer.
while (SoftSerial.available()) {
SoftSerial.read();
// Received data has expected length.
char receiveBuffer[sizeof(transmitData) + 1];
SoftSerial.readBytes(receiveBuffer, sizeof(receiveBuffer) - 1);
// Check if received data has correct content.
if (strcmp(receiveBuffer, transmitData) == 0) {
// Toggle the LED state.
if (ledPinState == HIGH) {
ledPinState = LOW;
ledPinState = HIGH;
digitalWrite(LED_BUILTIN, ledPinState);
AN alternative is to add an LCD display to the project and use it to display your messages. Then you can use the one built-in serial interface for other purposes.
The first time I tried the transmit test, I got no response and I lost the USB connection despite removing the jumper as directed. However, I was able to reestablish the USB connection and now the transmit test works. For the receive test, the Tx LED blinks. Seems like pins 10 and 11 are working for the serial connection. Maybe there's an issue with my sketch.
I will show it below. Also, here is how I have the DY player wired (except I'm using the 3.5mm output). I have two players. One has the resisters soldered inline and for the other one I am using a bread board. Both players are able to play a track when shorting Tx and ground.
I probably need to post this as a new question, but I think I found a problem in the sketch where it says serial instead of mySerial. I fixed that but the DY player still doesn't play. Copy and pasting other people's code is not my favorite way of doing things. Here is the updated code:
#include <DYSVAudio5W.h>
#define RX_PIN 10
#define TX_PIN 11
SoftwareSerial mySerial(RX_PIN, TX_PIN);
DYSVAudio5W player(mySerial, 9600, mySerial); //Init
mySerial.begin(9600); //Serial comm to DY Player
player.begin();
player.setVolume(30); // 100% Volume
// Read the value from the potentiometer connected to analog pin A0
int sensorValue = analogRead(A0);
int percentage = map(sensorValue, 0, 1023, 0, 100); // Maps 0-1023 to 0-100
if (percentage < 20) {
player.playTrack(1); //Start playing track 1
} else if (percentage >= 20 && percentage < 40) {
player.playTrack(2); //Start playing track 2
} else if (percentage >= 40 && percentage < 60) {
player.playTrack(3); //Start playing track 3
} else if (percentage >= 60 && percentage < 80) {
player.playTrack(4); //Start playing track 4
} else if (percentage >= 80 && percentage < 100) {
player.playTrack(5); //Start playing track 5
} else if (percentage == 100) {
player.playTrack(6); //Start playing track 6
delay(100); // delay in between reads for stability
Serial1 is the name given to the SoftwareSerial instance used in the example. You gave yours the name mySerial. Try using the syntax from the example but using your name for teh SoftwareSerial instance.
Note that the name appears twice in the example constructor parameters
I should point out that I have no experience of using the library and I am going on what I can see is different in your code
I started tinkering with this again. Updated the code, which hasn't helped. But, I did discover that when I lift the green wire at pin 11 on the Arduino, the DY player starts playing track 1. I thought this would prove something but then I realized it's just shorting Rx on the player to ground which plays the first track by design. I'm wondering if my actual wiring is not in line with the diagram I'm trying to follow, or if it's something else. Also, I added a capacitor which is above my pay grade, but nothing exploded - yet. Below is a drawing of how I have it wired (with the potentiometer) and how it is supposed to be wired. Any help is appreciated.
player.begin();
delay(500); // delay in between reads for stability
You have made a mistake in the wiring of the potential divider.
The 5V output from the Arduino should go to the other end of the 1kΩ resistor. The junction of the 1kΩ and 2kΩ resistors goes to the DY player RX input.
Here is a corrected version of your drawing. The changes are within the yellow circle.
