Unsuported display by MCUFRIEND_kbv lib
I just bought that display:
3_5-Inch-TFT-Color-Display-Screen-Module
But is not working with any examples and is reported by unsupported 0x2323 id. How could I make it working?
diagnose_TFT_support output:
Diagnose whether this controller is supported
There are FAQs in extras/mcufriend_how_to.txt
tft.readID() finds: ID = 0x2323
MCUFRIEND_kbv version: 2.9.8
This ID is not supported
look up ID in extras/mcufriend_how_to.txt
you may need to edit MCUFRIEND_kbv.cpp
to enable support for this ID
e.g. #define SUPPORT_8347D
New controllers appear on Ebay often
If your ID is not supported
run LCD_ID_readreg.ino from examples/
Copy-Paste the output from the Serial Terminal
to a message in Displays topic on Arduino Forum
or to Issues on GitHub
Note that OPEN-SMART boards have diff pinout
Edit the pin defines in LCD_ID_readreg to match
Edit mcufiend_shield.h for USE_SPECIAL
Edit mcufiend_special.h for USE_OPENSMART_SHIELD_PINOUT
LCD_ID_readreg output:
Read Registers on MCUFRIEND UNO shield
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
reg(0x0000) 00 00	ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 44 80 66	Manufacturer ID
reg(0x0009) 00 00 61 00 00	Status Register
reg(0x000A) 00 08	Get Power Mode
reg(0x000C) 00 66	Get Pixel Format
reg(0x0061) 00 00	RDID1 HX8347-G
reg(0x0062) 00 00	RDID2 HX8347-G
reg(0x0063) 00 00	RDID3 HX8347-G
reg(0x0064) 00 00	RDID1 HX8347-A
reg(0x0065) 00 00	RDID2 HX8347-A
reg(0x0066) 00 00	RDID3 HX8347-A
reg(0x0067) 00 00	RDID Himax HX8347-A
reg(0x0070) 10 10	Panel Himax HX8347-A
reg(0x00A1) 00 83 20 83 20	RD_DDB SSD1963
reg(0x00B0) 10 10	RGB Interface Signal Control
reg(0x00B4) 10 10	Inversion Control
reg(0x00B6) 10 10 10 10 10	Display Control
reg(0x00B7) 10 10	Entry Mode Set
reg(0x00BF) 10 10 10 10 10 10	ILI9481, HX8357-B
reg(0x00C0) 00 0E 0E 0E 0E 0E 0E 0E 0E	Panel Control
reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00	GAMMA
reg(0x00CC) 00 04	Panel Control
reg(0x00D0) 10 1E 1E	Power Control
reg(0x00D2) 10 33 33 33 33	NVM Read
reg(0x00D3) 10 10 94 96	ILI9341, ILI9488
reg(0x00D4) 10 33 33 33	Novatek ID
reg(0x00DA) 10 54	RDID1
reg(0x00DB) 10 90	RDID2
reg(0x00DC) 10 14	RDID3
reg(0x00E0) 00 0F 26 2F 0C 0D 0C 48 44 6A 0A 0D 07 2B 02 0D	GAMMA-P
reg(0x00E1) 00 0E 23 22 04 04 08 24 A6 04 06 05 0F 02 2F 0D	GAMMA-N
reg(0x00EF) 00 80 00 00 60 40	ILI9327
reg(0x00F2) 10 10 10 10 10 10 10 10 10 10 10 10	Adjust Control 2
reg(0x00F6) 10 10 10 10	Interface Control
It looks as if you are reading a 0x10 i.e. bit #4 is set.
I suspect that you have an 0x9486
Of course a bad read could mean a bad write too.
Try tft.begin(0x9486); or tft.begin(0x0090);
Since you have bought from BangGood, tell them you have a bad display. They will refund your purchase.
Did you plug the shield into the Uno ?
Or use trailing wires?
Does your pcb look like the photos in your link?
David.
The connector on UNO board was broken, I fix it and screen is working fine. Thx!
