Hi Guy's,
I can get the arduino-webthings example sketch LED to work, but not the LED Lamp on my NodeMCu?
Could this be a result of using the ESP8266 library (2.5.2 on old mac)?
I'm not brilliant at coding, but tried a few thing and got no success.
Can someone give me some pointers in the right direction?
* Simple server compliant with Mozilla's proposed WoT API
* Originally based on the HelloServer example
* Tested on ESP8266, ESP32, Arduino boards with WINC1500 modules (shields or
* MKR1000)
* This Source Code Form is subject to the terms of the Mozilla Public
* License, v. 2.0. If a copy of the MPL was not distributed with this
* file, You can obtain one at http://mozilla.org/MPL/2.0/.
//#define LARGE_JSON_DOCUMENT_SIZE 8192
//#define SMALL_JSON_DOCUMENT_SIZE 2048
#define LARGE_JSON_BUFFERS 1
//#define ARDUINOJSON_USE_LONG_LONG 1
#include <Arduino.h>
#include <Thing.h>
#include <WebThingAdapter.h>
#ifdef ESP32
#include <analogWrite.h>
#endif
const char *ssid = "*****";
const char *password = "*****";
#if defined(LED_BUILTIN)
const int lampPin = LED_BUILTIN;
#else
const int lampPin = 16; // manually configure LED pin
#endif
ThingActionObject *action_generator(DynamicJsonDocument *);
WebThingAdapter *adapter;
const char *lampTypes[] = {"OnOffSwitch", "Light", nullptr};
ThingDevice lamp("urn:dev:ops:my-lamp-1234", "My Lamp", lampTypes);
ThingProperty lampOn("on", "Whether the lamp is turned on", BOOLEAN,
"OnOffProperty");
ThingProperty lampLevel("brightness", "The level of light from 0-100", INTEGER,
"BrightnessProperty");
StaticJsonDocument<256> fadeInput;
JsonObject fadeInputObj = fadeInput.to<JsonObject>();
ThingAction fade("fade", "Fade", "Fade the lamp to a given level",
"FadeAction", &fadeInputObj, action_generator);
ThingEvent overheated("overheated",
"The lamp has exceeded its safe operating temperature",
NUMBER, "OverheatedEvent");
bool lastOn = true;
void setup(void) {
pinMode(lampPin, OUTPUT);
digitalWrite(lampPin, HIGH);
Serial.println("");
Serial.print("Connecting to \"");
Serial.print(ssid);
Serial.println("\"");
#if defined(ESP8266) || defined(ESP32)
WiFi.mode(WIFI_STA);
#endif
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
adapter = new WebThingAdapter("led-lamp", WiFi.localIP());
lamp.description = "A web connected lamp";
lampOn.title = "On/Off";
lamp.addProperty(&lampOn);
lampLevel.title = "Brightness";
lampLevel.minimum = 0;
lampLevel.maximum = 100;
lampLevel.unit = "percent";
lamp.addProperty(&lampLevel);
fadeInputObj["type"] = "object";
JsonObject fadeInputProperties =
fadeInputObj.createNestedObject("properties");
JsonObject brightnessInput =
fadeInputProperties.createNestedObject("brightness");
brightnessInput["type"] = "integer";
brightnessInput["minimum"] = 0;
brightnessInput["maximum"] = 100;
brightnessInput["unit"] = "percent";
JsonObject durationInput =
fadeInputProperties.createNestedObject("duration");
durationInput["type"] = "integer";
durationInput["minimum"] = 1;
durationInput["unit"] = "milliseconds";
lamp.addAction(&fade);
overheated.unit = "degree celsius";
lamp.addEvent(&overheated);
adapter->addDevice(&lamp);
adapter->begin();
Serial.println("HTTP server started");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.print("/things/");
Serial.println(lamp.id);
#ifdef analogWriteRange
analogWriteRange(255);
#endif
// set initial values
ThingPropertyValue initialOn = {.boolean = true};
lampOn.setValue(initialOn);
(void)lampOn.changedValueOrNull();
ThingPropertyValue initialLevel = {.integer = 50};
lampLevel.setValue(initialLevel);
(void)lampLevel.changedValueOrNull();
analogWrite(lampPin, 128);
randomSeed(analogRead(0));
void loop(void) {
adapter->update();
bool on = lampOn.getValue().boolean;
if (on) {
int level = map(lampLevel.getValue().number, 0, 100, 255, 0);
analogWrite(lampPin, level);
analogWrite(lampPin, 255);
if (lastOn != on) {
lastOn = on;
void do_fade(const JsonVariant &input) {
JsonObject inputObj = input.as<JsonObject>();
long long int duration = inputObj["duration"];
long long int brightness = inputObj["brightness"];
delay(duration);
ThingDataValue value = {.integer = brightness};
lampLevel.setValue(value);
int level = map(brightness, 0, 100, 255, 0);
ThingDataValue val;
val.number = 102;
ThingEventObject *ev = new ThingEventObject("overheated", NUMBER, val);
lamp.queueEventObject(ev);
ThingActionObject *action_generator(DynamicJsonDocument *input) {
return new ThingActionObject("fade", input, do_fade, nullptr);
