I'm using an ATMega32U4 Pro Micro which has been working just fine for a while now. It no longer works.
Same for the Arduino Nano.
My Arduino Mega does work, however. The other two were both used for serial communication but the Mega was not.
I'm running Arduino 1.8.5. and tried again on 1.8.9.
The program utilises serial communication, if that's of concern.
The USB cables are good, haven't had trouble with them before.
The programs on the boards run.
The IDE even recognises the ports and the boards.
I've even tried plugging it in and uploading immediately to see if that helps.
I've tried all of the programmers but nothing changes.
Unplugging, off then on, restarting, trying different programs... nothing works.
Nothing seems to be working, it just sends this:
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/usr/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
User configuration file is "/Users/usr/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14601
Using Programmer : avr109
Overriding Baud Rate : 57600
and then freezes. No progress at all. The Neopixel ring on my project usually freezes on upload, but it keeps cycling. If I unplug it, it complains the device wasn't found. If I leave it plugged in, after 5-10 minutes the status bar reads Done but the debug readout doesn't change, its still stuck on "Overriding Baud Rate", no progress bars or indication that anything has happened.
I'm really hoping this doesn't mean me having to buy new boards. Any idea how to fix this?
Thanks for the help!
