Upload to Arduino Nano
Here is some more information:
  1. The board I am having trouble with was purchased on 3/24/2021 from Amazon and is an official, genuine Arduino Nano board, not an knockoff. So it should use the standard Arduino installed driver and not the CH340 driver.
When I look at the Device Manager, it shows "Other devices > FT232R USB UART". But I don't think that is the correct driver for the genuine Arduino board from what I gather from a google search. When I try to update the driver, I get the message:
"Windows found drivers for your device but encountered an error while attempting to install them. The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering."
I did a google search to try and troubleshoot and found this (Enable/Disable Device Driver Signing in Windows 10 - Technipages) that said I had to disable Device Driver Signing. When I tried to follow the instructions, I got an error message "An error has occurred setting the element data. The value is protected by Secure Boot policy and cannot be modified or deleted.". So, I am still with trying to get my genuine Arduino Nano to run.
  1. Because I was having so much trouble with the genuine Arduino Nano board, I decided to purchase some Lafvin Nano boards. I was able to install the CH340 drivers and get the Lafvin boards running just fine (can upload and run code). So I am really confused why I can't get the official Arduino Nano board to work.
Desperate for some help. Thanks.
@laurakavanaugh
Official Arduinos have not used the FT232 for a considerable time due to FTDIGATE.
A link to where you purchased it would be useful.
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Hello.
Can take a few moments to Learn and Use The Forum
It will help you get the very best out of the forum in the future.
  • Your OS and version can be valuable information, please include it along with extra security you are using. Antivirus etc.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
laurakavanaugh:
It should be fine. Did you ever try using it?
ballscrewbob:
Official Arduino boards were never affected by "FTDIgate" because Arduino uses genuine FT232R chips. FTDIgate only affected the counterfeit FT232R chips used on some clone boards.
The classic Nano still uses the FT232R chip, just as always. You can check the schematic on the "Documentation" tab of the product page:
