Uploading error
hello y'all, I was working with a "Bluetooth controlled car" and then I got this error:
El Sketch usa 2048 bytes (6%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 186 bytes (9%) de la memoria dinámica, dejando 1862 bytes para las variables locales. El máximo es 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf1
Failed uploading: uploading error: exit status 1
The code :point_down::
int Pin_Motor_Der_A = 8;
int Pin_Motor_Der_B = 9;
int Pin_Motor_Izq_A = 10;
int Pin_Motor_Izq_B = 11;
int tiempo=0;
  pinMode(Pin_Motor_Der_A, OUTPUT);
  pinMode(Pin_Motor_Der_B, OUTPUT);
  pinMode(Pin_Motor_Izq_A, OUTPUT);
  pinMode(Pin_Motor_Izq_B, OUTPUT);
  if (Serial.available()) {
     char dato= Serial.read();
     if(dato=='a')
        Mover_Adelante();
        tiempo=0;
     else if(dato=='r')
        Mover_Retroceso();
        tiempo=0;
     else if(dato=='d')
        Mover_Derecha();
        tiempo=0;
     else if(dato=='i')
        Mover_Izquierda();
        tiempo=0;
  if(tiempo<200)
    tiempo=tiempo+1;
    Mover_Stop();
  delay(1);
void Mover_Adelante()
  digitalWrite (Pin_Motor_Der_A, HIGH);
  digitalWrite (Pin_Motor_Der_B, LOW);
  digitalWrite (Pin_Motor_Izq_A, HIGH);
  digitalWrite (Pin_Motor_Izq_B, LOW);
void Mover_Retroceso()
  digitalWrite (Pin_Motor_Der_A,LOW );
  digitalWrite (Pin_Motor_Der_B,HIGH );
  digitalWrite (Pin_Motor_Izq_A,LOW );
  digitalWrite (Pin_Motor_Izq_B,HIGH );
void Mover_Derecha()
  digitalWrite (Pin_Motor_Izq_A,HIGH);
  digitalWrite (Pin_Motor_Izq_B,LOW);
void Mover_Izquierda()
  digitalWrite (Pin_Motor_Der_A,HIGH);
  digitalWrite (Pin_Motor_Der_B,LOW);
void Mover_Stop()
  digitalWrite (Pin_Motor_Der_A, LOW);
  digitalWrite (Pin_Motor_Izq_A, LOW);
and I'm using an Arduino Uno
can someone help me? please :pensive::pray:
IMPORTANT UPDATE= I replaced the Uno with an Nano, and then I could upload the code
What board?
Bluetooth controlled car.
You apparently do not have a functional connection between the computer and the car. Or the car is not powered.
If your board only has one UART (e.g. Uno), it can not be shared between Bluetooth (on Tx and Rx) and PC (USB) resulting in upload problems. In that case you will need to disconnect the the Bluetooth module, upload and connect the Bluetooth module again.
But we don't know which board you're using and we don't know your code so it is just a guess.
Arduino Uno
okay, I'll edit the original post :dove:
Hi @solf1. Disconnect the Bluetooth module from the Uno board and then try uploading again. Is the upload successful when you do that?
nope, i tried it :crying_cat_face:
should I burn the bootloader? or what? i dunno what to do
You described the Arduino board you are uploading to as "Uno". Something that can be confusing is there are multiple boards with "UNO" in their name. We need to be certain of exactly which one you have. The reason is that the problem might be caused by the IDE not being correctly configured for your specific board.
Please tell us which of the following boards you are attempting to upload to:
If you aren't sure which one you have, you can provide a picture of the board or a link to the place you bought it from and we'll see if we can identify it.
this one
I'm going to ask you to provide the full verbose output from an upload attempt.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Uncheck the box next to Show verbose output during: ☑ compile in the "Preferences" dialog.
  3. Check the box next to Show verbose output during: ☐ upload.
  4. Click the "OK" button.
    The "Preferences" dialog will close.
  5. Attempt an upload, as you did before.
  6. Wait for the upload to fail.
  7. You will see an "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  8. Open a forum reply here by clicking the "Reply" button.
  9. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  10. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the error output from the upload into the code block.
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the "Reply" button to post the output.
