uploading problem
Hi all,
I'm new to this and have no idea what I'm doing and wondering if anybody can help?
I did a sketch and it verified OK when uploading it to the uno it hangs up and comes up with a error message. the uno board is selected and on the uno the green light does not come on any ideas?
Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
Sketch uses 1,200 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2,033 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\.\COM1": Access is denied.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe8
enabled in File > Preferences.
thanks,
It probably was expecting another USB port. Try to select another com.
I've tried other usb ports but no luck, I tried to change the port in the software but it will only look at com1.
I am new at this and had similar problem - today. I am using a Uno board from China which I got off eBay. I found if I install these drivers (on Windows 7) it fixed the problem.
(I needed to use the driverset64 exe by copying it into the main folder).
Hope this helps but note I am far from an expert!.
Rob
