I am trying to upload the AFMotor.h to my project and it gives me the error message (exit status 1
#endif without #if) I am not sure what this means. I am new at this
Here is the code I am trying to upload. can someone please help me
#define AFMotor_h
#define AFMotor_h
#include <inttypes.h>
#if defined(AVR)
#include <avr/io.h>
//#define MOTORDEBUG 1
#define MICROSTEPS 16 // 8 or 16
#define MOTOR12_64KHZ _BV(CS20) // no prescale
#define MOTOR12_8KHZ _BV(CS21) // divide by 8
#define MOTOR12_2KHZ _BV(CS21) | _BV(CS20) // divide by 32
#define MOTOR12_1KHZ _BV(CS22) // divide by 64
#define MOTOR34_64KHZ _BV(CS00) // no prescale
#define MOTOR34_8KHZ _BV(CS01) // divide by 8
#define MOTOR34_1KHZ _BV(CS01) | _BV(CS00) // divide by 64
#define DC_MOTOR_PWM_RATE MOTOR34_8KHZ // PWM rate for DC motors
#define STEPPER1_PWM_RATE MOTOR12_64KHZ // PWM rate for stepper 1
#define STEPPER2_PWM_RATE MOTOR34_64KHZ // PWM rate for stepper 2
#elif defined(PIC32MX)
// Uncomment the one of following lines if you have put a jumper from
// either pin 9 to pin 11 or pin 10 to pin 11 on your Motor Shield.
// Either will enable PWM for M1
//#define PIC32_USE_PIN9_FOR_M1_PWM
//#define PIC32_USE_PIN10_FOR_M1_PWM
// For PIC32 Timers, define prescale settings by PWM frequency
#define MOTOR12_312KHZ 0 // 1:1, actual frequency 312KHz
#define MOTOR12_156KHZ 1 // 1:2, actual frequency 156KHz
#define MOTOR12_64KHZ 2 // 1:4, actual frequency 78KHz
#define MOTOR12_39KHZ 3 // 1:8, acutal frequency 39KHz
#define MOTOR12_19KHZ 4 // 1:16, actual frequency 19KHz
#define MOTOR12_8KHZ 5 // 1:32, actual frequency 9.7KHz
#define MOTOR12_4_8KHZ 6 // 1:64, actual frequency 4.8KHz
#define MOTOR12_2KHZ 7 // 1:256, actual frequency 1.2KHz
#define MOTOR12_1KHZ 7 // 1:256, actual frequency 1.2KHz
#define MOTOR34_312KHZ 0 // 1:1, actual frequency 312KHz
#define MOTOR34_156KHZ 1 // 1:2, actual frequency 156KHz
#define MOTOR34_64KHZ 2 // 1:4, actual frequency 78KHz
#define MOTOR34_39KHZ 3 // 1:8, acutal frequency 39KHz
#define MOTOR34_19KHZ 4 // 1:16, actual frequency 19KHz
#define MOTOR34_8KHZ 5 // 1:32, actual frequency 9.7KHz
#define MOTOR34_4_8KHZ 6 // 1:64, actual frequency 4.8KHz
#define MOTOR34_2KHZ 7 // 1:256, actual frequency 1.2KHz
#define MOTOR34_1KHZ 7 // 1:256, actual frequency 1.2KHz
// PWM rate for DC motors.
#define DC_MOTOR_PWM_RATE MOTOR34_39KHZ
// Note: for PIC32, both of these must be set to the same value
// since there's only one timebase for all 4 PWM outputs
#define STEPPER1_PWM_RATE MOTOR12_39KHZ
#define STEPPER2_PWM_RATE MOTOR34_39KHZ
#endif
// Bit positions in the 74HCT595 shift register output
#define MOTOR1_A 2
#define MOTOR1_B 3
#define MOTOR2_A 1
#define MOTOR2_B 4
#define MOTOR4_A 0
#define MOTOR4_B 6
#define MOTOR3_A 5
#define MOTOR3_B 7
// Constants that the user passes in to the motor calls
#define FORWARD 1
#define BACKWARD 2
#define BRAKE 3
#define RELEASE 4
// Constants that the user passes in to the stepper calls
#define SINGLE 1
#define DOUBLE 2
#define INTERLEAVE 3
#define MICROSTEP 4
#define LATCH 4
#define LATCH_DDR DDRB
#define LATCH_PORT PORTB
#define CLK_PORT PORTD
#define CLK_DDR DDRD
#define CLK 4
#define ENABLE_PORT PORTD
#define ENABLE_DDR DDRD
#define ENABLE 7
#define SER 0
#define SER_DDR DDRB
#define SER_PORT PORTB
// Arduino pin names for interface to 74HCT595 latch
#define MOTORLATCH 12
#define MOTORCLK 4
#define MOTORENABLE 7
#define MOTORDATA 8
class AFMotorController
public:
AFMotorController(void);
void enable(void);
friend class AF_DCMotor;
void latch_tx(void);
uint8_t TimerInitalized;
class AF_DCMotor
public:
AF_DCMotor(uint8_t motornum, uint8_t freq = DC_MOTOR_PWM_RATE);
void run(uint8_t);
void setSpeed(uint8_t);
private:
uint8_t motornum, pwmfreq;
class AF_Stepper {
public:
AF_Stepper(uint16_t, uint8_t);
void step(uint16_t steps, uint8_t dir, uint8_t style = SINGLE);
void setSpeed(uint16_t);
uint8_t onestep(uint8_t dir, uint8_t style);
void release(void);
uint16_t revsteps; // # steps per revolution
uint8_t steppernum;
uint32_t usperstep, steppingcounter;
private:
uint8_t currentstep;
uint8_t getlatchstate(void);
#endif
