Hello,
How to print corretly a String ("ALOE%20BLACC%20%26%20PEGASUS%20") into ALOE BLACC & PEGASUS ?
I haven't found a library.
Thanks
Hello,
Thanks
Write your own parser.
Is it that hard? ESP8266 URL Encode Decode Example | Circuits4you.com
something like this maybe:
char *percent_enc[34] = {"%20", "%22", "%25", "%2D", "%2E", "%3C", "%3E", "%5C", "%5E", "%5F", "%60", "%7B", "%7C", "%7D", "%7E", "%21", "%23", "%24", "%25", "%26", "%27", "%28", "%29", "%2A", "%2B", "%2C", "%2F", "%3A", "%3B", "%3D", "%3F", "%40", "%5B", "%5D"};
char *url_decoded[34] = {" ", "\"", "%", "-", ".", "<", ">", "\\", "^", "_", "`", "{", "|", "}", "~", "!", "#", "$", "%", "&", "'", "(", ")", "*", "+", ",", "/", ":", ";", "=", "?", "@", "[", "]"};
char * pch;
char str[] = "ALOE%20BLACC%20%26%20PEGASUS%20";
Serial.print( "Before Decoding: ");
Serial.println(str);
//iterate through the percent encoding array
for (int i = 0; i < 34; ++i) {
//find first percent url encoding in string
pch = strstr (str, percent_enc[i]);
while ( pch != NULL ) {
//replace url encoding with corresponding character
strncpy (pch, url_decoded[i], strlen(url_decoded[i]));
//remove any remaining characters that were part of the url encoding
memmove(pch + strlen(url_decoded[i]), pch + strlen(percent_enc[i]), strlen(pch + strlen(url_decoded[i])));
//find next percent url encoding in string
Serial.print( "After Decoding: ");
Hope that helps...
Yes perfect, I just need to convert the String into char!! Thanks a lot!
there's already a function for that! ![]()
But %20 will result in 3 characters instead of a space ![]()
Is it easy to add accentued chars ?
éàü:
\xc3\xa9\xc3\xa0\xc3\xbc
because it needs "2 byte" for one char !
not quite following what you mean there but I should think is just a matter of just extending the array in the example code to include those character codes.
"\\xc3\\xa9" for "é" for example.
also please be aware that " \ " should be expressed a " \\ " to be read as the backslash character.
hope that helps...
Yes exactely !
I would write: é = %C3%A9 not slash !
Any idea how to add double (éàü) /triple (€) coded char like:
%C3%A9%C3%A0%C3%BC%E2%82%AC = éàü€
Thanks
did you try adding the respective 'url codes' to the array of the example code as previously suggested?
I would put longer 'url codes' as the beginning of the array, to reduce the risk of misreading which checking the actual url string.
e.g "%3C" -> ''
%C3%A9% -> 'é' //make sure this code is before "%3C" in array since contains the same character
hope that helps...
I'm not sure to add it correctly.
char *percent_enc[36] = {"%20", "%22", "%25", "%2D", "%2E","%C3%A8" "%3C", "%3E", "%5C", "%5E", "%5F", "%60", "%7B", "%7C", "%7D", "%7E", "%21", "%23", "%24", "%25", "%26", "%27", "%28", "%29", "%2A", "%2B", "%2C", "%2F", "%3A", "%3B", "%3D", "%3F", "%40", "%5B", "%5D", "%C3"};
char *url_decoded[36] = {" ", "\"", "%", "-", ".", "è", "<", ">", "\\", "^", "_", "`", "{", "|", "}", "~", "!", "#", "$", "%", "&", "'", "(", ")", "*", "+", ",", "/", ":", ";", "=", "?", "@", "[", "]", "é"};
char * pch;
With:
char str[] = "Premi%C3%A8re";
Before Decoding: Premi%C3%A8re
After Decoding: Premi]%A8re
Instead of Première
works fine for me! ![]()
#define URL_SET 39
struct {
char const *percent_enc;
char const *percent_dec;
} c[URL_SET] = {{"%E2%82%AC", "€"}, {"%C3%A8", "è"}, {"%C3%A9", "é"}, {"%C3%A0", "à"}, {"%C3%BC", "ü"}, {"%20", " "}, { "%22", "\""}, { "%25", "%"}, { "%2D", "-"}, { "%2E", "."}, { "%3C", "<"}, { "%3E", ">"}, { "%5C", "\\"}, { "%5E", "^"}, { "%5F", "_"}, { "%60", "`"}, { "%7B", "{"}, { "%7C", "|"}, { "%7D", "}"}, { "%7E", "~"}, { "%21", "!"}, { "%23", "#"}, { "%24", "$"}, { "%25", "%"}, { "%26", "&"}, { "%27", "'"}, { "%28", "("}, { "%29", ")"}, { "%2A", "*"}, { "%2B", "+"}, { "%2C", ","}, { "%2F", " /"}, { "%3A", ":"}, { "%3B", ";"}, { "%3D", "="}, { "%3F", "?"}, { "%40", "@"}, { "%5B", "["}, { "%5D", "]"}};
char * pch;
//char test_str[] = "ALOE%20BLACC%20%26%20PEGASUS%20";
char test_str[] = "Premi%C3%A8re%20%20%C3%A9%C3%A0%C3%BC%E2%82%AC";
Serial.println(test_str);
for (int i = 0; i < URL_SET; ++i) {
pch = strstr (test_str, c[i].percent_enc);
strncpy (pch, c[i].percent_dec, strlen(c[i].percent_dec));
memmove(pch + strlen(c[i].percent_dec), pch + strlen(c[i].percent_enc), strlen(pch + strlen(c[i].percent_dec)));
Before Decoding: Premi%C3%A8re%20%20%C3%A9%C3%A0%C3%BC%E2%82%AC
After Decoding: Première éàü€
For me too !!! Thanks a lot sherzaad !!!
Perfect sherzaad!
i just noticed if the text is long it will be cut. Where is the limitation ?
Try with:
char str[] = "Dr%C3%B4le%20d'%C3%A9poque%20%3A%20Nahum%20Frenck%2C%20p%C3%A9diatre%20et%20th%C3%A9rapeute%20de%20famille%3B%20Dr%C3%B4le%20d'%C3%A9poque%20%3A%20Nahum%20Frenck%2C%20p%C3%A9diatre%20et%20th%C3%A9rapeute%20de%20famille%3B";
Thanks
not sure what you mean...
#define URL_SET 40
struct {
} c[URL_SET] = {{"%E2%82%AC", "€"}, {"%C3%A8", "è"}, {"%C3%A9", "é"}, {"%C3%A0", "à"}, {"%C3%B4", "ô"}, {"%C3%BC", "ü"}, {"%20", " "}, { "%22", "\""}, { "%25", "%"}, { "%2D", "-"}, { "%2E", "."}, { "%3C", "<"}, { "%3E", ">"}, { "%5C", "\\"}, { "%5E", "^"}, { "%5F", "_"}, { "%60", "`"}, { "%7B", "{"}, { "%7C", "|"}, { "%7D", "}"}, { "%7E", "~"}, { "%21", "!"}, { "%23", "#"}, { "%24", "$"}, { "%25", "%"}, { "%26", "&"}, { "%27", "'"}, { "%28", "("}, { "%29", ")"}, { "%2A", "*"}, { "%2B", "+"}, { "%2C", ","}, { "%2F", " /"}, { "%3A", ":"}, { "%3B", ";"}, { "%3D", "="}, { "%3F", "?"}, { "%40", "@"}, { "%5B", "["}, { "%5D", "]"}};
char * pch;
//char test_str[] = "Premi%C3%A8re%20%20%C3%A9%C3%A0%C3%BC%E2%82%AC";
char test_str[] = "Dr%C3%B4le%20d'%C3%A9poque%20%3A%20Nahum%20Frenck%2C%20p%C3%A9diatre%20et%20th%C3%A9rapeute%20de%20famille%3B%20Dr%C3%B4le%20d'%C3%A9poque%20%3A%20Nahum%20Frenck%2C%20p%C3%A9diatre%20et%20th%C3%A9rapeute%20de%20famille%3B";
//Serial.print( "Before Decoding: ");
//Serial.println(test_str);
Drôle d'époque : Nahum Frenck, pédiatre et thérapeute de famille; Drôle d'époque : Nahum Frenck, pédiatre et thérapeute de famille;
bear in mind that this code can be quite memory intensive and if you create too long strings and/or decoding sets, you may very well run out of memory!
Thanks sherzaad!
After some tests (downloading the code many times). Your code is working well but sometimes the RS232 output is truncked (always at the same place:
After Decoding: Drôle d'époque : Nahum Frenck, pédiatre et thérapeute de famille; Drôle d'époque : Nahum Frenck, pédiatre et thérapeute de famil), rarely the output is complete!!! Tried with lower/higher baud rate, no change. Added Serial.flush(); no change.
The problem is on the serial side! (I'm Using Teensy 3.2)
I tried to expand the serial buffer: https://forum.pjrc.com/threads/54773-Inreasing-USB-Serial-Buffer-Teensy-3-2?p=194517&viewfull=1#post194517
no change ! Strange !!!
the issue seems hardware specific then...
I'm using a uno and so far its be outputing correctly. not really familiar with the teeny series unfortunately.
updated IDE and it works.
With the new one 1.8.19 some warnigs appears
warning: ISO C++ forbids converting a string constant to 'char*'
But until now, it works.
