USB serial port works but doesn't - any ideas? (solved)
I have a adafruit feather M0 board running some very basic serial port code. Just repeatedly transmit "hello world".
All this works in the Arduino IDE serial port monitor.
If I bootload the processor and use a 3rd party serial program (I've tried several, Termite, Terminal, QT serial port example). I cannot view the serial coming from the feather to the windows 10 machine. I can transmit data from Window to the M0 and it does understand it (code to receive a character and change the blink rate of the led). (so sort of working)
Now here's the weird thing. If I bootload then check the serial with the IDE serial monitor then close the IDE serial monitor and open one of the 3rd party terminal programs - it works.
In summary - it works fine with the IDE serial monitor but not with a 3rd party terminal program - unless I first run the IDE serial monitor and then everything is fine.
Any ideas?
(deleted)
In your terminal programs, try turning off Hardware Flow control. And if an option exists, set DTR high or active.
Thank you gbafamily for the DTR clue. If I manually set (or include after the serial open in Qt) the DTR to true - then I start seeing all of the serial coming from the Arduio to the host windows machine.
