Before I tried to upload code into my Arduino Mega ADK, I tried to burn the bootloader into the USBasp Programmer using the following steps:
Programmer:"USBasp"
Burn Bootloader
But, I got an Error Message:
Arduino: 1.8.0 (Windows 10), Board: "Arduino Mega ADK"
avrdude: Warning: cannot query manufacturer for device: No such file or directory
avrdude: Warning: cannot query product for device: No such file or directory
avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
Error while burning bootloader.
I've had problems using the libusb-win32 driver that's included with that download with the AVRDUDE 6.3.0 version included with the Arduino AVR Boards included with Arduino IDE 1.6.10 and newer. I solved it by using the libusbK driver instead:
Download Zadig: http://zadig.akeo.ie/ (you'll notice this program is actually recommended on the official USBasp webpage).
Use Zadig to install the libusbK driver.
I can give exact steps for installing the libusbK driver if you need them.
Plug the USBasp in to your computer
Start Zadig
Options > List all devices
Select USBasp from the dropdown menu
Click the down or up arrows on the driver menu until libusbK is selected.
Click "Replace Driver"
A Windows Security dialog will ask you to confirm you want to install the driver. Click "Install".
After the driver installation completes you can close Zadig.
Thank You for the help..! I followed the procedure and the driver got Installed Successfully..!
The driver is located at: C:\libusbK-dev-kit
The Arduino Software is located at: C:\Program Files\Arduino
I tried the USBasp with the Arduino Software. I plugged it in a USB 2.0 port, set the Programmer Option to USBasp.
I used my Mega ADK as the Target Device and tried uploading the Fade Code. The Software displayed the following error message:
Sketch uses 1930 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 8179 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_getsync(): timeout communicating with programmer
does not exist or your board is not connected
Later, I found out that the USBasp was not at all discovered by the Arduino IDE...
The port option in the tools section was inactive...
I re-installed the Arduino Mega ADK Drivers and tried burning the bootloader as you suggested. But all I got was an Error Message saying:
Error while burning Bootloader
I tried uploading the fade sketch and I got this error message:
An error occurred while uploading the sketch
I am not even able to reset the Arduino by pressing the Reset button.
I later turned on the Verbose Output and tried burning the bootloader. I got:
C:\Users\devan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\devan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega2560 -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\devan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done. Thank you.
I also tried uploading the code. I got:
C:\Users\devan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\devan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM3 -b115200 -D -Uflash:w:C:\Users\devan\AppData\Local\Temp\arduino_build_943989/Fade.ino.hex:i
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
Alas, I guess I have roasted my Arduino Mega ADK..!
