USBSerial not Recognized - Custom ESP32-S3 board
Hello,
I am trying to utilize the USBSerial command on a custom ESP32-S3 board that I made however my ArduinoIDE is not recognizing the existence of USBSerial. I've tested previous version of the esp32 library, but when I go back to far I get some driver errors. I am still able to upload to the board and control other peripherals, but I can't communicate via the Serial Monitor
System Information
MacOS (Silicone M3)
Arduino IDE 2.3.4
esp32 library 3.1.1 -> 2.0.9
Code:
#include <FastLED.h>
#define LED_PIN 2
#define NUM_LEDS 1
#define AIN1 6
#define AIN2 7
#define BIN1 8
#define BIN2 9
CRGB led[NUM_LEDS];
  USBSerial.begin(9600);
Error Message:
/Users/trhussain/Documents/Arduino/sketch_jan11a/sketch_jan11a.ino: In function 'void setup()':
/Users/trhussain/Documents/Arduino/sketch_jan11a/sketch_jan11a.ino:15:3: error: 'USBSerial' was not declared in this scope; did you mean 'Serial'?
   15 |   USBSerial.begin(9600);
      |   Serial
exit status 1
Compilation error: 'USBSerial' was not declared in this scope; did you mean 'Serial'?
Schematic files (pretty sure its nothing with this, I can control the board peripherals fine, but added for posterity sake)
ArduinoIDE Configuration
Let me know if any additional information is required, thanks!
I don't understand what your issue is, the error msg tells you the USBSerial library is missing or you are using the wrong board perhaps, or did you actually mean Serial?
No I meant USBSerial, its a way to use the USB as a serial interface so you don't need the FTDI converter (to my understanding)
Here is the USBSerial.ino file from espressif
I use Serial all the time with the USB, just try it, change USBSerial to Serial.
Here is a discussion thread that seems to have a similar issue with mine(?)
Serial with USB doesnt work for me because (I believe can be wrong) since most boards have a built in FTDI programmer into them, this is a custom board so I need to use USBSerial
SOLVED:
I change by ArduinoIDE Settings to the following
Finally, yes just use the Serial port that happens to be connected via USB. Perfectly NORMAL.
