Arduino: 1.8.9 (Windows 10), Board: "ATmega328, No bootloader, EEPROM not retained, 328PB, BOD 2.7V, LTO disabled, Internal 8 MHz"
C:\Users\e_cha\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\e_cha\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/avrdude.conf -v -patmega328pb -cusbtiny -e -Ulock:w:0x3f:m -Uefuse:w:0b11110101:m -Uhfuse:w:0b11011111:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3-20201216
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\e_cha\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega328PB
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Error while burning bootloader.
New USBTinyISP, it's giving the same error message whether I have it connected to a chip being programmed or not. Has ATTiny2313 and I've downloaded driver from Adafruit. Can anyone tell me what the error code means? And before anyone tells me to upgrade Arduino IDE, any version newer than 1.8.9 does not work with ATTiny10 core at all.
